Problem beim Compilieren
Wenn ich mein Programm Compiliere
$regfile = "M32def.dat"
$crystal = 8000000
$baud = 9600
declare sub Read1820
declare sub CRCit
declare sub Temperature
dim bd(9) as byte
dim i as byte , tmp as byte
dim CRC as byte
dim T as integer , T1 as integer
dim v as byte
Config Lcdpin = Pin , Db4 = Porta.2 , Db5 = Porta.3 , Db6 = Porta.4 , Db7 = Porta.5 , E = Porta.1 , Rs = Porta.0
Config Lcd = 16 * 4
Config 1wire = Portd.2
cursor off noblink
cls
Locate 1 , 1 : Lcd "Brutkasten"
locate 2 , 1 : lcd "T="
do
Temperature
waitms 250
loop
End
sub Temperature ' actual measuring
1wwrite &hcc : 1wwrite &h44 ' start measure
waitms 300 ' wait for end of conversion
Read1820 ' read 9 bytes
if Err = 1 then ' if there is no sensor
locate 2 , 4 : lcd "-- " ' we put "-- " on LCD
else
if CRC = 0 then ' sensor present, check CRC
locate 2 , 4 : lcd T ' CRC OK, print T*10 on LCD
else
locate 2 , 4 : lcd "** " ' CRC NOT OK, "** " on LCD
end if
end if
end sub
sub Read1820 ' reads sensor ans calculate
' T for 0.1 C
1wreset ' reset the bus
1wwrite &hcc ' read internal RAM
1wwrite &Hbe ' read 9 data bytest
bd(1) = 1wread(9) ' read bytes in array
CRCit ' ckeck CRC
if CRC = 0 then ' if is OK, calculate for
tmp = bd(1) and 1 ' 0.1C precision
if tmp = 1 then decr bd(1)
T = makeint(bd(1) , bd(2))
T = T * 50 : T = T - 25 : T1 = bd(8) - bd(7) : T1 = T1 * 100
T1 = T1 / bd(8) : T = T + T1 : T = T / 10
end if
end sub
sub CRCit ' calculate 8 bit CRC
' bigger but faster
CRC = 0 ' needs a 256 elements table
for i = 1 to 9
tmp = CRC xor bd(i)
CRC = lookup(tmp , crc8)
next
end sub
crc8:
data 0 , 94 , 188 , 226 , 97 , 63 , 221 , 131 , 194 , 156
data 126 , 32 , 163 , 253 , 31 , 65 , 157 , 195 , 33 , 127
data 252 , 162 , 64 , 30 , 95 , 1 , 227 , 189 , 62 , 96
data 130 , 220 , 35 , 125 , 159 , 193 , 66 , 28 , 254 , 160
data 225 , 191 , 93 , 3 , 128 , 222 , 60 , 98 , 190 , 224
data 2 , 92 , 223 , 129 , 99 , 61 , 124 , 34 , 192 , 158
data 29 , 67 , 161 , 255 , 70 , 24 , 250 , 164 , 39 , 121
data 155 , 197 , 132 , 218 , 56 , 102 , 229 , 187 , 89 , 7
data 219 , 133 , 103 , 57 , 186 , 228 , 6 , 88 , 25 , 71
data 165 , 251 , 120 , 38 , 196 , 154 , 101 , 59 , 217 , 135
Data 4 , 90 , 184 , 230 , 167 , 249 , 27 , 69 , 198 , 152
Data 122 , 36 , 248 , 166 , 68 , 26 , 153 , 199 , 37 , 123
data 58 , 100 , 134 , 216 , 91 , 5 , 231 , 185 , 140 , 210
data 48 , 110 , 237 , 179 , 81 , 15 , 78 , 16 , 242 , 172
data 47 , 113 , 147 , 205 , 17 , 79 , 173 , 243 , 112 , 46
data 204 , 146 , 211 , 141 , 111 , 49 , 178 , 236 , 14 , 80
data 175 , 241 , 19 , 77 , 206 , 144 , 114 , 44 , 109 , 51
data 209 , 143 , 12 , 82 , 176 , 238 , 50 , 108 , 142 , 208
data 83 , 13 , 239 , 177 , 240 , 174 , 76 , 18 , 145 , 207
data 45 , 115 , 202 , 148 , 118 , 40 , 171 , 245 , 23 , 73
data 8 , 86 , 180 , 234 , 105 , 55 , 213 , 139 , 87 , 9
data 235 , 181 , 54 , 104 , 138 , 212 , 149 , 203 , 41 , 119
data 244 , 170 , 72 , 22 , 233 , 183 , 85 , 11 , 136 , 214
data 52 , 106 , 43 , 117 , 151 , 201 , 74 , 20 , 246 , 168
data 116 , 42 , 200 , 150 , 21 , 75 , 169 , 247 , 182 , 232
data 10 , 84 , 215 , 137 , 107 , 53
Schreibt er immer
Error:999 Line: 94 DEMO/BETA only supports 2048 bytes of code
an was kann das liegen
und wie kann ich es beheben?
Danke [/code]
Ich glaube die Fehlermeldung ist klar. Du scheinst die Demo-Version von BASCOM-AVR zu verwenden und diese ist auf maximal 2KB erzeugten Code begrenzt. Dein Programm erzeugt 2144 Bytes Programmcode
Du hast nun 2 Möglichkeiten:
Entweder die Programmgröße auf dieses Limit reduzieren oder die Voll-Version zu kaufen. Ich würde Dir zu letzterem raten, da BASCOM-AVR ein sehr guten Preis/Leistungsverhältnis hat und für jeden, der ATMEL AVR Prozessoren mit der Programmsprache BASIC programmieren will es meines Erachtens der beste Compiler ist.
in der neuesten Bascom Demoversion ist die Beschränkung auf 4 KB angehoben worden. (Steht so wenigstens in der History.txt)
Vielleicht reichen dir ja erst einmal 4 KB..
außerdem geht folgende Zeile zB. nicht:
"T = T * 50 : T = T - 25 : T1 = bd(Cool - bd(7) : T1 = T1 * 100 "
Bei Bascom mußt du leider immer alles schön einzeln und hintereinander machen.
Also x=b*c / d
geht nicht
Hilfsvariable= b*c
x= hilfsvariable / c
das geht.
Christopher
Diese Zeile wird vom Compiler akzeptiert, da die einzelnen Statements mit Doppelpunkt voneinander getrennt sind. Dieses Forum ersetzt allerdings manche Kombinationen mit ) wie bei bd(x) mit Smileys und beim rauskopieren und einfügen in die BASCOM-AVR wird dadurch der Code verändert, was wiederum Compiler-Fehler generiert.
Füg mal
$lib "mcsbyteint.LBX"
im Listing mit ein. Also so...
$crystal = 8000000
$baud = 9600
declare sub CRCit
Es kann sein, das du damit unter die 2kb-Grenze kommst.
