Programierhilfe für linienverfolgung
Hey
ich habe folgendes Problem, nämlich das wenn ich das linienfolgeprogramm:
// Program used by "myIrAsuro" in qualifying for competition
// "Parallel Slalom" of RobotChallenge 2007 in Vienna (24th march):
// http://www.robotchallenge.at
// Time 10.1s for 354cm, that is speed 35.05cm/s (best was 60.00 cm/s).
// myIrAsuro has reduction of 1:12.5 (Asuro standard is 1:25), see:
// https://www.roboternetz.de/phpBB2/ze...ag.php?t=28876
// The entries 0xFF for both SPEED values below will work on
// a standard Asuro with speed < 0.5m/s.
// The value for THRESHOLD must be changed if no IR-FrontLED
// with white shield is used, see:
// https://www.roboternetz.de/phpBB2/ze...ag.php?t=29109
// Robot will have to be placed on the line for starting!
// After starting the StatusLED of Asuro will blink [ready].
// After (any) switch is pressed both BackLED's turn on [steady].
// Releasing the switch will start the Robot [go].
#include <asuro.h>
#define OFF_LEFT -1
#define ON_LINE 0
#define OFF_RIGHT +1
#define SPEED 0xdF // 0xFF
#define SPEED1 0xbF // 0xFF
#define SPEED2 0x00
#define THRESHOLD 1100
void RaceStart(void); // blink until any switch is pressed,
// then wait until switch is released
int main(void)
unsigned int sum,data[2];
int position = ON_LINE;
Init();
RaceStart();
FrontLED(ON);
MotorDir(FWD,FWD);
MotorSpeed(SPEED,SPEED);
while (1) // state machine: position on/off the line
LineData(data);
sum = data[LEFT] + data[RIGHT];
if (sum>=THRESHOLD) // not on the line
if (position==ON_LINE) // switch state if previously on the line
position = (data[LEFT]<data[RIGHT]) ? OFF_RIGHT : OFF_LEFT;
BackLED( (position==OFF_LEFT)?ON:OFF, (position==OFF_RIGHT)?ON:OFF );
else // on the line
if (position!=ON_LINE) // switch state if previously not on the line
position = ON_LINE;
BackLED(OFF,OFF);
if (position==ON_LINE) { MotorSpeed(SPEED,SPEED); } // full FWD
else if (position==OFF_RIGHT) { MotorSpeed(SPEED2,SPEED1); } // turn left
else if (position==OFF_LEFT) { MotorSpeed(SPEED1,SPEED2); } // turn right
while (1); // code unreachable
return 0;
void RaceStart(void) // blink until any switch is pressed,
{ // then wait until switch is released
uint8_t t1, t2;
unsigned int col=OFF;
while (1) // blinking StatusLED until any switch is pressed
t1 = PollSwitch();
t2 = PollSwitch();
if (t1==t2)
if (t1)
break;
else
col ^= GREEN;
StatusLED(col);
Msleep(50);
StatusLED(OFF); // turn off StatusLED and ...
BackLED(ON,ON); // ... turn on both BackLED's
while (1) // wait until switch is released
t1 = PollSwitch();
t2 = PollSwitch();
if (t1==t2)
if (!t1)
break;
Msleep(50);
BackLED(OFF,OFF); // turn off BackLED's indication start of race
compilieren will kommt folgender error:
Zitat:
> "C:\Asuro_src\Progs\Drei\Test-all.bat"
C:\Asuro_src\Progs\Drei>make all
set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c \
| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \
[ -s asuro.d ] || rm -f asuro.d
set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=Linie.lst Linie.c \
| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > Linie.d; \
[ -s Linie.d ] || rm -f Linie.d
-------- begin --------
avr-gcc --version
avr-gcc (GCC) 4.1.1 (WinAVR 20070122)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=Linie.lst Linie.c -o Linie.o
In file included from ./asuro.h:34,
from Linie.c:25:
c:/winavr/bin/../avr/include/avr/signal.h:36:2: warning: #warning "This header file is obsolete. Use <avr/interrupt.h>."
Linie.c: In function 'main':
Linie.c:58: error: 'LEFT' undeclared (first use in this function)
Linie.c:58: error: (Each undeclared identifier is reported only once
Linie.c:58: error: for each function it appears in.)
Linie.c:58: error: 'RIGHT' undeclared (first use in this function)
Linie.c: In function 'RaceStart':
Linie.c:114: warning: implicit declaration of function 'Msleep'
make: *** [Linie.o] Error 1
> Process Exit Code: 2
was mach ich falsch.
Ach jaich hab mir die lib 2.7 installiert(*.exe) kann es vieleicht daran liegen das ich deswegen noch was einstellen muss?
