Epson Helikopter mit Kamera 8,6 Gramm
Der neue Epson Helikopter mit 8,6 Gramm, mit Kamera und 3 min Flugzeit war heute in den Nachrichten,
(die Meldung gibt es sicher auch auf deutsch.)
Es gibt ihn mit Kabel oder auch mit Akku, die Meldungen sind nicht ganz eindeutig.
http://www.spacedaily.com/2004/04081....o233utvm.html
Seiko Epson unveils latest mini robot helicopter
TOKYO (AFP) Aug 18, 2004
Japanese company Seiko Epson said Wednesday it has developed a mini helicopter that is the lightest of its kind and can be used for lifesaving and surveillance.
The 'iFR-II' robot chopper is equipped with a camera and can transmit still images, said the company, a leading ink-jet printer maker.
The prototype aircraft is larger than its predecessor, the 'iFR', but weighs less at 8.6 grams (0.30 ounces) without its polymer-lithium battery compared with the earlier model's 10 grams.
Seiko Epson Corp. claims this makes it the world's lightest robot helicopter, which is not for commercial use as yet.
The company said the lighter weight was made possible by developing a new gyro-sensor which is just a fifth the weight of the one mounted on the prototype. Gyro-sensors give devices high-performance motion correction and stability.
The company said the latest model had no cord and thus had a wider flight range compared with the previous model unveiled in November, which was operated by remote control with a 1.5-meter-long (5.0-foot-long) cable connected to an electric generator.
