fehler in einfachem fahrprogramm und ich finde ihn nicht :(
In dem Programm stimmt noch was nicht, make all gibt mir folgendes aus:
RP6Base_hinundher.c: In function 'Batt':
RP6Base_hinundher.c:33: error: expected '(' before '{' token
RP6Base_hinundher.c:80: warning: 'main' is normally a non-static function
RP6Base_hinundher.c:92:3: warning: no newline at end of file
RP6Base_hinundher.c:92: error: expected declaration or statement at end of input
make: *** [RP6Base_hinundher.o] Fehler 1
// Cruise Behaviour:
#include "RP6RobotBaseLib.h"
#define IDLE 0
#define TURN_SPEED 50
#define MOVE_SPEED 100
#define MOVE_FORWARDS 1
void behaviour_cruise(void)
uint8_t turn_direction = LEFT;
setLEDs(0b100100);
move(MOVE_SPEED, FWD, DIST_MM(2000), BLOCKING);
rotate(TURN_SPEED, turn_direction, 102, BLOCKING);
move(MOVE_SPEED, FWD, DIST_MM(100), BLOCKING);
rotate(TURN_SPEED, RIGHT, 102, BLOCKING);
// akku_load:
void Batt(void)
setStopwatch1(400);
while
startStopwatch1();
if(getStopwatch1() > 300)
writeString_P("\nADC Akku: Voll");
writeInteger(adcBat, DEC);
writeChar('\n');
if(adcBat > 900)
setLEDs(0b001001);
writeString_P("\nADC Akku: >9V");
else if(adcBat < 901 && adcBat > 800)
writeString_P("\nADC Akku: >8V");
statusLEDs.LED4 = !statusLEDs.LED4;
statusLEDs.LED1 = !statusLEDs.LED1;
updateStatusLEDs();
else if(adcBat < 801 && adcBat > 700)
setLEDs(0b000001);
writeString_P("\nADC Akku: >7V");
else if(adcBat < 701 && adcBat > 590)
updateStatusLEDs();
writeString_P("\nADC Akku: Leer");
else if(adcBat < 591 && adcBat > 500)
writeString_P("\nADC Akku: Laden!");
powerOFF();
setStopwatch1(0);
int main (void)
initRobotBase();
startStopwatch1();
powerON();
while(true)
task_RP6System();
Batt();
behaviour_cruise();
return 0;
