Programmierungsproblem mit dem I²C-BUS LC-DISPLAY C-CONTROL
ich bin Schüler und habe mir das I²C-BUS LC-DISPLAY C-CONTROL I bei Conrad bestellt (http://www.conrad.de/goto.php?artikel=198330) und versucht es mit meinem atmega32 und einem Quarz von 16MHz zum Laufen zu bringen. Scl(Portc.0) und Sda(Portc.1) sind genauso wie V+ und Gnd angeschlossen.
Zum Programmieren habe ich mir die Lcd_i2c.lib heruntergeladen (http://www.mcselec.com/index.php?opt...d=82&Itemid=57) und das beiligende Demoprogramm so umgeschrieben:
$regfile = "m32def.dat"
$crystal = 16000000
$lib "Lcd_i2c.lib"                                          'My i2c driver for the LCD
Config I2cdelay = 1
Const Pcf8574_lcd = &H40                                    'Defines the address of the I/O expander for LCD
Config Scl = Portc.0                                        'Configure i2c SCL
Config Sda = Portc.1                                        'Configure i2c SDA
Dim _lcd_e As Byte                                          'Needed to control 4 line LCD
'_lcd_e = 128 select E1, 64 select E2, 192 select both (for CLS or DefLCDChar etc.)
_lcd_e = 128                                                'Upper half of 4-line display is selected
'Here the LCD test program that is included in BASCOM follows
'and at the end there is a demo of the keyboard scan routine
Dim A As Byte
Config Lcd = 16 * 2                                         'configure lcd screen
'other options are 16 * 4 and 20 * 4, 20 * 2 , 16 * 1a
'When you dont include this option 16 * 2 is assumed
'16 * 1a is intended for 16 character displays with split addresses over 2 lines
'$LCD = address will turn LCD into 8-bit databus mode
'       use this with uP with external RAM and/or ROM
'       because it aint need the port pins !
' Put your own strings here
Cls                                                         'clear the LCD display
Lcd "Hello world."                                          'display this at the top line
Wait 1
Lowerline                                                   'select the lower line
Wait 1
Lcd "Shift this."                                           'display this at the lower line
Wait 1
For A = 1 To 10
   Shiftlcd Right                                           'shift the text to the right
   Waitms 250                                               'wait a moment
Next
For A = 1 To 10
   Shiftlcd Left                                            'shift the text to the left
Next
Locate 2 , 1                                                'set cursor position
Lcd "*"                                                     'display this
Wait 1                                                      'wait a moment
Shiftcursor Right                                           'shift the cursor
Lcd "@"                                                     'display this
Home Upper                                                  'select line 1 and return home
Lcd "Replaced."                                             'replace the text
Cursor Off Noblink                                          'hide cursor
Cursor On Blink                                             'show cursor
Display Off                                                 'turn display off
Display On                                                  'turn display on
End
 Außer der Beleuchtung funktioniert nichts. Kein Cursur etc. ...
Auch mit einem an ein Display mit 16 * 2 angepassten Code, den ich aus dem Buch "Roboter selbst bauen" (http://books.google.de/books?id=tjUA...bauen#PPA59,M1) entnommen habe,  tut sich nichts.
Vielleicht hatte jemand das selbe Problem und hat es gelöst ?
Ich würde mich über Lösungen, Raschläge oder Fragen über Unklarheiten freuen ...
Gruß,
Markus
