[SOLVED] Keine Digital Display Ausgabe der Encoder
Nabend!
Habe seit Gestern meinen eigenen RP6. Wie jeder Anfänger (sollte) habe ich die Anleitung gelesen, alles installiert und das Testprogramm durchlaufen lassen. Leider kommt bei Test 8:
### ATTENTION!!! DANGER!!! WARNING!!!
Make sure that the RP6 can __NOT__ move!
The caterpillar tracks should __NOT__ touch the ground!
(hold it in your hands for example...)
THE RP6 WILL START MOVING FAST! YOU CAN DAMAGE IT IF YOU DO NOT
MAKE SURE THAT IT CAN __NOT__ MOVE!
Make sure both crawler tracks are FREE RUNNING! DO NOT BLOCK THEM!
--> OTHERWISE THE TEST WILL FAIL!
### Enter "x" and hit return when TO START this test!
### Make sure the RP6 can not move!
# x
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 003 |IR: 002 |UB: 07.67V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 002 |IR: 002 |UB: 07.67V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 004 |IR: 002 |UB: 07.67V
Speed Left: OK
Speed Right: OK
T: 020 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 003 |IR: 002 |UB: 07.67V
T: 020 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 004 |IR: 002 |UB: 07.67V
T: 020 |VL: 000 |VR: 000 |PL: 010 |PR: 010 |IL: 011 |IR: 013 |UB: 07.63V
T: 020 |VL: 000 |VR: 000 |PL: 020 |PR: 020 |IL: 021 |IR: 021 |UB: 07.62V
T: 020 |VL: 000 |VR: 000 |PL: 030 |PR: 030 |IL: 027 |IR: 025 |UB: 07.61V
T: 020 |VL: 000 |VR: 000 |PL: 050 |PR: 050 |IL: 031 |IR: 030 |UB: 07.59V
T: 020 |VL: 000 |VR: 000 |PL: 060 |PR: 060 |IL: 033 |IR: 037 |UB: 07.59V
T: 020 |VL: 000 |VR: 000 |PL: 070 |PR: 070 |IL: 038 |IR: 043 |UB: 07.58V
T: 020 |VL: 000 |VR: 000 |PL: 080 |PR: 080 |IL: 041 |IR: 047 |UB: 07.57V
T: 020 |VL: 000 |VR: 000 |PL: 090 |PR: 090 |IL: 041 |IR: 051 |UB: 07.56V
T: 020 |VL: 000 |VR: 000 |PL: 106 |PR: 107 |IL: 055 |IR: 057 |UB: 07.53V
T: 020 |VL: 000 |VR: 000 |PL: 120 |PR: 120 |IL: 058 |IR: 064 |UB: 07.49V
T: 020 |VL: 000 |VR: 000 |PL: 130 |PR: 130 |IL: 066 |IR: 076 |UB: 07.49V
T: 020 |VL: 000 |VR: 000 |PL: 140 |PR: 140 |IL: 067 |IR: 077 |UB: 07.49V
T: 020 |VL: 000 |VR: 000 |PL: 150 |PR: 150 |IL: 074 |IR: 083 |UB: 07.47V
####### ERROR Left ########
####### ERROR Right #######
####### !!! WARNING WARNING WARNING !!! #######
####### !!! TEST FINISHED WITH ERRORS !!! #######
#### Please check motor and encoder assembly! ###
#### And also check Sensors for defects! ###
Enter any character to continue!
Nun hab ich das Forum und die Herstellerseite durchsucht und bin auf die Encoder Kalibrierung gestoßen. Klang logisch also habe ich sofort begonnen das auszuführen.
Beim Encoder Duty-Cycle Test bekomme ich diese Ergebnisse:
Encoder Duty Cycle test
THE RP6 CAN START MOVING VERY FAST! YOU CAN DAMAGE IT IF YOU DO NOT
Speed regulation is disabled - the motors get constant Power!
This allows you to adjust the small potis on the Encoders
to set the duty cycle properly.Optimal is a a duty cycle
of 50% - check this with the waveform displays in the RP6Loader Software.
On/Off time of the signal should be as equal as possible.
Usage: Enter PWM values like:
0, 25, 94, 100, 120 (LIMITED MAXIMUM!!!) and hit Enter!
Enter "end" or "x" and hit return when you want to stop the test!
Enter "fwd", "bwd", "l" or "r" to change motor turning direction!
The test is running already, you can Enter PWM values now!
# 50
--> Change speed to:50
P: 050 |VL: 000 |VR: 000 |IL: 009 |IR: 010 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.63V
SPEED LEFT IS TOO LOW!!!!
SPEED RIGHT IS TOO LOW!!!!
P: 050 |VL: 000 |VR: 000 |IL: 029 |IR: 028 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.59V
P: 050 |VL: 000 |VR: 000 |IL: 032 |IR: 032 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.60V
P: 050 |VL: 000 |VR: 000 |IL: 030 |IR: 033 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.60V
P: 050 |VL: 000 |VR: 000 |IL: 028 |IR: 033 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.60V
P: 050 |VL: 000 |VR: 000 |IL: 028 |IR: 032 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.60V
P: 050 |VL: 000 |VR: 000 |IL: 029 |IR: 032 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.60V
P: 050 |VL: 000 |VR: 000 |IL: 030 |IR: 032 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.59V
P: 050 |VL: 000 |VR: 000 |IL: 031 |IR: 033 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.60V
P: 050 |VL: 000 |VR: 000 |IL: 031 |IR: 034 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.59V
P: 050 |VL: 000 |VR: 000 |IL: 030 |IR: 036 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.59V
P: 050 |VL: 000 |VR: 000 |IL: 030 |IR: 037 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.59V
P: 050 |VL: 000 |VR: 000 |IL: 029 |IR: 036 |DCL: -1:-1 |DCR: -1:-1 |UB: 07.59V
Jetzt habe ich leider das Problem, dass der RP6Loader (bei Displays) keine Messergebnisse für die Encoder ausgibt. Spannung wird angezeigt (variiert auch bei Start der Motoren). Weder Geschwindigkeit, noch die Distanz und viel wichtiger das Waveform Display für die Encoder geben einen Pixel von sich.
Ich habe mir bereits das Video für die Kalibrierung angesehen und meine Wohnung auf tiefschwarze Nacht verdunkelt.
Im Moment verwende ich
Windows 7 x64 Home Premium
Aktuellen RP6Loader (1.4c) + Examples
Aktuelle Java (6u22)
Ich hab das ganze bereits unter Linux (Ubuntu 10.4 86x64) getestet und bekomme das gleiche Problem.
Ich hab mir auch schon gedacht ob es an meinem Dualmonitor-Aufbau liegt aber war leider auch nicht der Fall.
So nachdem ich nun nichts mehr gefunden habe, seid ihr an der Reihe :)
Vielen Dank im Vorraus!
