AT24C08 Schreiben und Lesen
Habe ein AT24C08 EEPROM
das beispiel von Bascom funz auch
Declare Sub Write_eeprom(byval Adres As Byte , Byval Value As Byte)
Declare Sub Read_eeprom(byval Adres As Byte , Value As Byte)
Const Addressw = 174 'slave write address
Const Addressr = 175 'slave read address
Dim B1 As Byte , Adres As Byte , Value As Byte , I As Byte 'dim byte
For I = 0 To 255
Cls
Locate 1 , 1
Call Write_eeprom(i , I) : Lcd "Write:" ; I 'write value of three to address 1 of EEPROM
Locate 2 , 1
Call Read_eeprom(i , Value) : Lcd "Read:" ; Value
Waitms 50
Next
'-------- now write to a PCF8474 I/O expander -------
I2csend &H40 , 255 'all outputs high
I2creceive &H40 , B1 'retrieve input
Print "Received data " ; B1 'print it
End
Rem Note That The Slaveaddress Is Adjusted Automaticly With I2csend & I2creceive
Rem This Means You Can Specify The Baseaddress Of The Chip.
'sample of writing a byte to EEPROM AT2404
I2cstart 'start condition
I2cwbyte Addressw 'slave address
I2cwbyte Adres 'asdress of EEPROM
I2cwbyte Value 'value to write
I2cstop 'stop condition
Waitms 10 'wait for 10 milliseconds
End Sub
'sample of reading a byte from EEPROM AT2404
I2cstart 'generate start
I2cwbyte Addressw 'slave adsress
I2cwbyte Adres 'address of EEPROM
I2cstart 'repeated start
I2cwbyte Addressr 'slave address (read)
I2crbyte Value , Nack 'read byte
I2cstop 'generate stop
End Sub
Aber hier kann ich ja nur ein Byte schreiben also 0-255.
Wie kann ich den ganzen EEPROM von 8KByte nutzen?
