Hi Leuts,
bastle grad bissl mit den Directsr rum.
Bis jetzt gehts ganz gut aber das Original Microsoft Voice geht wesentlich besser als das mit VB ?! Ist aber das gleiche Modul.
Hier mal etwas Code zum Basteln.
Code:Option Explicit
'-------------------------------api declares-----------------------------------
Private Declare Function ShellExecute Lib "shell32.dll" _
Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, _
ByVal lpFile As String, ByVal lpParameters As String, _
ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
Private Sub Command1_Click()
Select Case Command1.Caption
Case "Disable"
DirectSR1.Deactivate
Command1.Caption = "Enable"
Label1 = "Disabled"
Case "Enable"
DirectSR1.Activate
Command1.Caption = "Disable"
Label1 = "Ready"
End Select
End Sub
Private Sub Command2_Click()
DirectSS1.Speak Format(Time, "hh:mm")
End Sub
Private Sub DirectSR1_PhraseFinish(ByVal flags As Long, ByVal beginhi As Long, _
ByVal beginlo As Long, ByVal endhi As Long, ByVal endlo As Long, _
ByVal Phrase As String, ByVal parsed As String, ByVal results As Long)
'MsgBox "in the phrasefinish"
Dim sFile As String
Dim noth As Long
'MsgBox Phrase, , "The Phrase is: "
Select Case Phrase
Case "Notepad"
sFile = "\system32\notepad.exe"
noth = ShellExecute(0, "OPEN", Environ("SystemRoot") & sFile, "", "", 1)
Case "Volume"
sFile = "\system32\sndvol32.exe"
Case "Media Player:"
sFile = "C:\Program Files\Windows Media Player\mplayer2.exe"
noth = ShellExecute(0, "OPEN", sFile, "", "", 1)
Case "Time"
End Select
If Phrase <> "" Then
Text1.Text = "Matched word is " & Phrase
'DirectSR1.LastHeard = ""
Else
Text1.Text = "No word matched"
End If
'DirectSR1.Activate
End Sub
Private Sub Form_Load()
Dim retval As Integer
DirectSR1.GrammarFromString "[Grammar]" + vbNewLine + _
"type=cfg" + vbNewLine + _
"[<start>]" + vbNewLine + _
"<start>=Web Browser" + vbNewLine + _
"<start>=Notepad" + vbNewLine + _
"<start>=Visual Basic" + vbNewLine + _
"<start>=Calculator" + vbNewLine + _
"<start>=Time" + vbNewLine
DirectSR1.Activate
End Sub
Also man könnte da schon viel machen ála Roboter und in Verbindung Directss :-)
Hier noch die Links für die benötigten Komponeten.
http://download.microsoft.com/downlo...I4SDKSUITE.exe
http://download.microsoft.com/downlo...peechsdk51.exe
Würd mich freuen wenn da mehr interesse hätten ;-)
by Ulli
PS: geht nur in English
