Problem mit Echtzeituhr
Ich habe folgenden Sourcecode geschrieben (Die echtzeituhrteile sind von nem beispiel):
'declare used subs
Declare Sub Settime(byval S As Byte , Byval M As Byte , Byval H As Byte , Byval D As Byte , Byval Month As Byte)
Declare Sub Gettime
'declare vairables
Dim S As Byte , M As Byte , H As Byte , D As Byte , Month As Byte
Dim Sets As Byte , Setm As Byte , Seth As Byte , Setmode As Byte
Dim Wm As Byte , Yd As Byte
Config Portb = Input
Portb.3 = 1
Portb.2 = 1
Portb.1 = 1
Portb.0 = 1
Sets = 0
Setm = 0
Seth = 0
Setmode = 1
If Pinb.1 = 0 Then
Setmode = Setmode + 1
If Setmode = 4 Then
Setmode = 1
End If
End If
If Setmode = 1 Then
If Pinb.3 = 0 Then
Sets = Sets + 1
If Sets = 60 Then
Sets = 0
End If
End If
Elseif Setmode = 2 Then
If Pinb.3 = 0 Then
Setm = Setm + 1
If Setm = 60 Then
Setm = 0
End If
End If
Else
If Pinb.3 = 0 Then
Seth = Seth + 1
If Seth = 24 Then
Seth = 0
End If
End If
End If
If Setmode = 1 Then
If Pinb.2 = 0 Then
If Sets = 0 Then
Sets = 60
End If
Sets = Sets - 1
End If
If Pinb.2 = 0 Then
If Setm = 0 Then
Setm = 60
End If
Setm = Setm - 1
End If
Else
If Pinb.2 = 0 Then
If Seth = 0 Then
Seth = 24
End If
Seth = Seth - 1
End If
End If
Waitms 200
Print "Setmode: " ; Setmode
Print Seth ; ":" ; Setm ; ":" ; Sets
Loop Until Pinb.0 = 0
Call Settime(sets , Setm , Seth , 1 , 1) 'set time
Call Gettime 'get time
Waitms 1000
End
Sub Gettime
Dim Dum As Byte
I2cstart 'generate start
I2cwbyte &HA0 'write addres of PCF8583
I2cwbyte 2 'select second register
I2cstart 'generate repeated start
I2cwbyte &HA1 'write address for reading info
I2crbyte S , Ack 'read seconds
I2crbyte M , Ack 'read minuts
I2crbyte H , Ack 'read hours
I2crbyte Yd , Ack 'read year and days
I2crbyte Wm , Nack 'read weekday and month
I2cstop 'generate stop
Print "Time " ;
Print Bcd(h) ; ":" ; Bcd(m) ; ":" ; Bcd(s)
Print "Day : " ; Bcd(yd) ; " Month : " ; Bcd(wm)
End Sub
Sub Settime(s As Byte , M As Byte , H As Byte , D As Byte , Month As Byte)
'values are stored as BCD values so convert the values first
S = Makebcd(s) 'seconds
M = Makebcd(m) 'minuts
H = Makebcd(h) 'hours
D = Makebcd(d) 'days
Month = Makebcd(month) 'months
I2cwbyte &HA0 'write address
I2cwbyte 0 'select control register
I2cwbyte 8 'set year and day bit for masking
I2cwbyte &HA0 'write mode
I2cwbyte 2 'select seconds Register
I2cwbyte S 'write seconds
I2cwbyte M 'write minuts
I2cwbyte H 'write hours
I2cwbyte D 'write days
I2cwbyte Month 'write months
I2cstop
End Sub
Jetzt hab ich folgendes problem, wenn ich zie Uhrzeit eingestellt habe, werden falsche Werte in die Uhr übernommen z.B. 150. Woran kann das liegen? Ich kenne mich in bascom noch nicht so gut aus.
