gehts so nicht?
# makefile, written by guido socher
MCU=atmega32
CC=avr-gcc
OBJCOPY=avr-objcopy
# optimize for size:
CFLAGS=-g -mmcu=$(MCU) -Wall -Wstrict-prototypes -Os -mcall-prologues
all: test.hex
help:
@echo "Usage: make all|load|load_pre|rdfuses|wrfuse1mhz|wrfuse4mhz|wrfusecrystal"
@echo "Warning: you will not be able to undo wrfusecrystal unless you connect an"
@echo " external crystal! uC is dead after wrfusecrystal if you do not"
@echo " have an external crystal."
test.hex : test.out
$(OBJCOPY) -R .eeprom -O ihex test.out test.hex
test.out : test.o
$(CC) $(CFLAGS) -o test.out -Wl,-Map,test.map test.o -lm
test.o : test.c
$(CC) $(CFLAGS) -Os -c test.c
load: test.hex
./prg_load_uc test.hex
# here is a pre-compiled version in case you have trouble with
# your development environment
load_pre: test_pre.hex
loaduisp: test.hex
./prg_load_uc -u test.hex
load_preuisp: test_pre.hex
# fuse byte settings:
# Atmel AVR ATmega8
# Fuse Low Byte = 0xe1 (1MHz internal), 0xe3 (4MHz internal), 0xe4 (8MHz internal)
# Fuse High Byte = 0xd9
# Factory default is 0xe1 for low byte and 0xd9 for high byte
# Check this with make rdfuses
rdfuses:
./prg_fusebit_uc -r
# use internal RC oscillator 1 Mhz
wrfuse1mhz:
./prg_fusebit_uc -w 1
# use internal RC oscillator 4 Mhz
wrfuse4mhz:
./prg_fusebit_uc -w 4
# use external 3-8 Mhz crystal
# Warning: you can not reset this to intenal unless you connect a crystal!!
wrfusecrystal:
@echo "Warning: The external crystal setting can not be changed back without a working crystal"
@echo " You have 3 seconds to abort this with crtl-c"
@sleep 3
./prg_fusebit_uc -w 0
clean:
rm -f *.o *.map *.out *t.hex
JUHUUUUUUU! Jetzt gehts. Du hast mir aber vorhin die falsche Zeile gesagt an die ich das anhängen soll. Du hast die darunter angegeben.
neja, das wäre jetzt jedefalls gelöst.
Danke für die Mühe und die Ausdauer !!!
jagdfalke
