Thema: 4x 7Segment mit multiplex und NUR 5 ausgängen
Baum-Darstellung
    So hab mal wieder n paar fragen:
    ich möchte wie der titel ja schon sagt eine 4 stellige 7 segment anzeige mittels multiplexverfahren ansteuern.
    hab jetzt schon ziemlich viel darüber gelesen aber das beste beispiel ist glaub ich das in den sampels von proteus.
    Tiny 15 - Test of ADC - also include multiplex display driver.
    ; Specify Device.
    .device ATTINY15
    ; I/O Register Definitions
    .equ    SREG    =$3F
    .equ    GIMSK   =$3B
    .equ    GIFR    =$3A
    .equ    TIMSK   =$39
    .equ    TIFR    =$38
    .equ    MCUCR   =$35
    .equ    TCCR0   =$33
    .equ    TCNT0   =$32
    .equ    TCCR1   =$30
    .equ    TCNT1   =$2F
    .equ    OCR1A   =$2E
    .equ    OCR1B   =$2D
    .equ    PORTB   =$18
    .equ	DDRB	=$17
    .equ    ACSR    =$08
    .equ    ADMUX   =$07
    .equ    ADCSR   =$06
    .equ    ADCH    =$05
    .equ    ADCL    =$04
    ; Variable Declarations
    .def temp     = r16
    .def isrsreg  = r18
    .def isrtemp1 = r19
    .def isrtemp2 = r20
    .def cseg     = r21
    .def seg0     = r22
    .def seg1     = r23
    .def seg2     = r24
    .def seg3     = r25
    .cseg					; CODE segment.
    ;Interrupt Vectors
    .org 0
    	rjmp init			;Reset
    	reti				;INT 0
    	reti				;Pin Change
    	reti				;Output compare
    	reti				;Timer 1
    	rjmp tov0			;Timer 0
    	reti				;EEPROM ready
    	reti				;Analog Comparator
    	reti				;ADC Complete
    ;Initialization
    init:   ldi r16,$1F		; 5 bits are outputs
    	out DDRB,r16   		; set portb bit 0 for outputs to display
    	ldi r16,3		; Timer 0 rolls over at 1.6MHz/256/64 = 97Hz
    	out TCCR0,r16
    	ldi r16,$02		; Enable TOVF0
    	out TIMSK,r16
    	ldi cseg,$01		; Start at segment
    	sei			; Enable Interrupts
    	ldi r16,$8E		; Enable, ADIE, Prescale = 1/64
    	out ADCSR,r16
    	ldi r16,0		; Select ADC0 as input, VCC as VREF
    	out ADMUX,r16
    loop:	ldi r16,$20		; Sleep enable, idling mode
    	out MCUCR,r16
    	sleep			; Wait for a timer 0 interrupt
    	cpi cseg,8		; Wait for write to MS segment
    	breq loop
    	ldi r16,$28		; Sleep enable, ADC low noise mode
    	out MCUCR,r16
    	sleep			; Wait for ADC to convert
    	in r0,ADCL		; Read the converted value
    	in r1,ADCH
    ;Convert and display value for output
    ;Start value taken to be in r1:r0
    	clr r4			;Count result
    dc1a:	mov r2,r0		;Subtract 1000's
    	mov r3,r1
            ldi r16,$e8
            sub r2,r16
            ldi r16,$3
            sbc r3,r16
            brcs dc1b
        	inc r4
        	mov r0,r2
        	mov r1,r3
        	rjmp dc1a		; Go again
    dc1b:   mov seg0,r4		; Store result
    	clr r4
    dc2a:	mov r2,r0		;Subtract 100's
    	mov r3,r1
            ldi r16,100
            sub r2,r16
            clr r16
            sbc r3,r16
            brcs dc2b
        	inc r4
        	mov r0,r2
        	mov r1,r3
        	rjmp dc2a		; Go again
    dc2b:   mov seg1,r4		; Store result
    	clr r4
    dc3a:	mov r2,r0		;Subtract 10's
            ldi r16,10
            sub r2,r16
            brcs dc3b
        	inc r4
        	mov r0,r2
        	rjmp dc3a		; Go again
    dc3b:   mov seg2,r4		; Store result
    	mov seg3,r0    		; The units are trivial
    	rjmp loop		; Go again
    ;Timer 0 interrupt - display driver
    tov0:	in isrsreg,SREG		; Preserver sreg
    	clr isrtemp1		; Blank the display
    	out PORTB,isrtemp1
    	lsr cseg		; Advance segment selector address
    	brcc tov0_1
    	ldi cseg,0x08		; Reset to seg 3
    tov0_1: out PORTB,cseg		; Drive the latch
    	sbrc cseg,3		; Select byte to output
    	mov isrtemp1,seg3
    	sbrc cseg,2
    	mov isrtemp1,seg2
    	sbrc cseg,1
    	mov isrtemp1,seg1
    	sbrc cseg,0
    	mov isrtemp1,seg0
    	ldi isrtemp2,$10	;Bit 4 is set to enable the 7447
    	or isrtemp1,isrtemp2
    	sbi PORTB,4		;Pre Assert PB4
    	out PORTB,isrtemp1	;Drive the segment value onto the display
    	out SREG,isrsreg
    	reti
    hier wird das eigentliche "datensignal" und die auswahl der anzeige mit nur 5 pins erreicht dh datensignal und steuersignal sind gemischt. Dementsprechend find ich die programmierung schwierig.
    kann mir mal irgendjemand den asm code in verständliches C übersetzen?
    oder mir verständlich machen wie ich dieses "muster" ausgebe?
    im anhang seht ihr das datensignal wenn 0001 ausgegeben wird(von oben: PINB0 , PINB1 , PINB2 , PINB3 , dann 3 pins des signals hinterm d-flipflop, und PINB4 also clock)
    so hab da mal angefangen nen code zammen zu basteln und zwar gehts mir um die erste ziffer also hier mal das ganze um eine 0 zu übertragen:
    include <stdio.h>
    #include <avr/io.h>
    #include <avr/interrupt.h>
    #include <avr/signal.h>
    #include <math.h>
    #include <avr/delay.h>
    int main(void);
    char Convert2PacketBCD(char value);
    SIGNAL (SIG_OUTPUT_COMPARE0)
    char temp1;
    		PORTB=0b00000000;
    		PORTB=0b10000001;
    		temp1=Convert2PacketBCD(0x00);
    		temp1&=0x0F;
    		temp1|=0b10000000;
    		PORTB = temp1;
         unsigned char result;
         result = value % 10;
         result += (value - result)/10 * 0x10;
         return result;
    int main(void) {
    	DDRB =0xff;
    	PORTB=0x00;
    	TCCR0= 0x02;
    	TIMSK=0x02;
    	sei();
    	while (1) {
    	return 0;
    wieso bekomme ich innerhalb der int routine schon 2 pulse??? also ganz unten ist mein clock. naja bekomm zwar ne null allerdings auch noch ne 1 wegen den pulsen
    na bin für jede menge anregungen dankbar
    antworten kann ich heut leider nicht mehr höchstens zu später stunde..
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken mylogic.jpg   multiplex_logic.jpg   multiplex_circuit.jpg
