gehts so nicht?
Code:# makefile, written by guido socher MCU=atmega32 CC=avr-gcc OBJCOPY=avr-objcopy # optimize for size: CFLAGS=-g -mmcu=$(MCU) -Wall -Wstrict-prototypes -Os -mcall-prologues #------------------- all: test.hex #------------------- help: @echo "Usage: make all|load|load_pre|rdfuses|wrfuse1mhz|wrfuse4mhz|wrfusecrystal" @echo "Warning: you will not be able to undo wrfusecrystal unless you connect an" @echo " external crystal! uC is dead after wrfusecrystal if you do not" @echo " have an external crystal." #------------------- test.hex : test.out $(OBJCOPY) -R .eeprom -O ihex test.out test.hex test.out : test.o $(CC) $(CFLAGS) -o test.out -Wl,-Map,test.map test.o -lm test.o : test.c $(CC) $(CFLAGS) -Os -c test.c #------------------ load: test.hex ./prg_load_uc test.hex # here is a pre-compiled version in case you have trouble with # your development environment load_pre: test_pre.hex ./prg_load_uc test.hex # loaduisp: test.hex ./prg_load_uc -u test.hex # here is a pre-compiled version in case you have trouble with # your development environment load_preuisp: test_pre.hex ./prg_load_uc -u test.hex #------------------- # fuse byte settings: # Atmel AVR ATmega8 # Fuse Low Byte = 0xe1 (1MHz internal), 0xe3 (4MHz internal), 0xe4 (8MHz internal) # Fuse High Byte = 0xd9 # Factory default is 0xe1 for low byte and 0xd9 for high byte # Check this with make rdfuses rdfuses: ./prg_fusebit_uc -r # use internal RC oscillator 1 Mhz wrfuse1mhz: ./prg_fusebit_uc -w 1 # use internal RC oscillator 4 Mhz wrfuse4mhz: ./prg_fusebit_uc -w 4 # use external 3-8 Mhz crystal # Warning: you can not reset this to intenal unless you connect a crystal!! wrfusecrystal: @echo "Warning: The external crystal setting can not be changed back without a working crystal" @echo " You have 3 seconds to abort this with crtl-c" @sleep 3 ./prg_fusebit_uc -w 0 #------------------- clean: rm -f *.o *.map *.out *t.hex #-------------------
Zitieren
Lesezeichen
