ich habe ein LCD von Optrex DMF5006NY-FW.
Zum testen habe ich es an meine Atmega8 geklemmt und folgenden Code verwendet:
Das ist einfach nur das Testbeispiel. Leider ist das Display grösser als 128 x 64, vieleicht 240 x 128 Pixel genau weis ich das nicht. (ich kann sie ja mal zählen)Code:'-------------------------------------------------------------------- ' SED.BAS ' demonstrates the SED based graphical display support '-------------------------------------------------------------------- 'some routines to control the display are in the glcdSED.lib file $regfile = "m8def.dat" 'ATmega8-Deklarationen $crystal = 1000000 'Quarz: 3,6864 MHz $lib "glcdSED.lbx" 'First we define that we use a graphic LCD Config Graphlcd = 128 * 64sed , Dataport = Portd , Controlport = Portc , Ce = 5 , Cd = 4 , Wr = 3 , Rd = 2 , Reset = 1 'The dataport is the portname that is connected to the data lines of the LCD 'The controlport is the portname which pins are used to control the lcd 'CE =CS Chip Enable/ Chip select 'CD=A0 Data direction 'WR= Write 'RD=Read 'RESET = reset 'Dim variables (y not used) Dim X As Byte , Y As Byte 'clear the screen 'Cls Lcd "wer" 'specify the font we want to use 'Setfont Font16x16 For X = 0 To 140 Pset X , 20 , 255 ' set the pixel Next Line(0 , 0) -(23 , 27) , 255 Pset 10 , 10 , 1 'You can use locate but the columns have a range from 1-132 'When you want to show somthing on the LCD, use the LDAT command 'LCDAT Y , COL, value 'Locate 1 , 1 Lcd "123" 'lcdat accepts an additional param for inversing the text Lcdat 2 , 1 , "123" , 1 ' will inverse the text 'Now use a different font 'Setfont Font8x8 'since the 16*16 font uses 2 rows, show on row 3 'Lcdat 3 , 1 , "123" 'End 'end program 'Optional try this out by unremarking the block remarks 'draw a line Line(0 , 0) -(128 , 64) , 1 'Line(0 , 64) -(128 , 0) , 1 'check for circles Wait 2 Display Off Wait 2 Display On 'use glcdcmd to send a control byte to the display Glcdcmd &HA7 ' reverse display Wait 1 Glcdcmd &HA6 ' normal display 'adjust contrast For X = 0 To 63 Glcdcmd &H81 ' electronic volume (contrast) Glcdcmd X ' higher means more contrast Waitms 100 Next 'you could display a picture too 'Showpic 8 , 8 , Plaatje End 'end of block remark on line above 'we need to include the font files '$include "font8x8.font" '$include "font16x16.font" 'Plaatje: 'include the picture data '$bgf "smile.bgf"
Der Anzeigebereich ist 120mm x 75mm.
Im Beispiel und in der Hilfe steht für den SED Chipsatz muss man 128 x 64 benutzen.
Nun meine Frage wie soll das gehen wen das Display grösser ist, es zeigt nix an nur wenn das Programm läuft tauchen kurz weiße Linien auf die aber gleich wieder verschwinden. Bei erneuten Reset des Atmega 8 kommt das selbe wieder.
Ich habe folgende Pinbelegung für das LCD mir zusammen gesucht
- 1. D0
2. D1
3. D2
4. D3
5. D4
6. D5
7. D6
8. D7
9. CS (Ce)
10. A0 (Cd)
11. WR
12. RD
13. RES (Reset)
14. Vdd (+5V)
15. Vss (GND )
16. Vcont (10K mittlerer Pin am Potentiometer)
17. Vee (negativ voltage)
18. SEL1
Kann mir jemand helfen ich wies nicht mehr weiter, ich sitz daran schon seit ein paar Tagen und komme nicht voran!!!
Zitieren
Lesezeichen
