Thema: Programm will nicht so wie ich--> bitte Fehlersuche
    Pforzheim
    Hallo Leute,
    ich habe hier mal folgenden code zusammengeschrieben:
    $regfile = "m32def.dat"
    $crystal = 4000000
    $baud = 9600
    Rem   Portb.4 = 1 --> Motor links vor
    Rem   Portb.5 = 1 --> Motor links rück
    Rem   Portb.6 = 1 --> Motor rechts vor
    Rem   Portb.7 = 1 --> Motor links rück
    Config Portb = Output
    Config Portd = Input
    Config Portc = Input
       ' Alles Weiß --> vorwärts
       If Pinc.2 = 1 Then
          If Pind.2 = 0 And Pind.3 = 0 And Pind.4 = 0 And Pind.5 = 0 And Pind.6 = 0 Then
          Portb.4 = 1
          Portb.5 = 0
          Portb.6 = 1
          Portb.7 = 0
          End If
          If Pind.2 = 0 And Pind.3 = 0 And Pind.4 = 0 And Pind.5 = 0 And Pind.6 = 1 Then
          Portb.4 = 1
          Portb.5 = 0
          Portb.6 = 0
          Portb.7 = 1
          End If
          If Pind.2 = 0 And Pind.3 = 0 And Pind.4 = 0 And Pind.5 = 1 And Pind.6 = 1 Then
          Portb.4 = 1
          Portb.5 = 0
          Portb.6 = 0
          Portb.7 = 0
          End If
          If Pind.2 = 0 And Pind.3 = 0 And Pind.4 = 0 And Pind.5 = 1 And Pind.6 = 0 Then
          Portb.4 = 1
          Portb.5 = 0
          Portb.6 = 0
          Portb.7 = 0
          End If
          If Pind.2 = 0 And Pind.3 = 0 And Pind.4 = 1 And Pind.5 = 1 And Pind.6 = 0 Then
          Portb.4 = 1
          Portb.5 = 0
          Portb.6 = 1
          Portb.7 = 0
          End If
          If Pind.2 = 0 And Pind.3 = 0 And Pind.4 = 1 And Pind.5 = 0 And Pind.6 = 0 Then
          Portb.4 = 1
          Portb.5 = 0
          Portb.6 = 1
          Portb.7 = 0
          End If
          If Pind.2 = 0 And Pind.3 = 1 And Pind.4 = 1 And Pind.5 = 0 And Pind.6 = 0 Then
          Portb.4 = 1
          Portb.5 = 0
          Portb.6 = 1
          Portb.7 = 0
          End If
          If Pind.2 = 0 And Pind.3 = 1 And Pind.4 = 0 And Pind.5 = 0 And Pind.6 = 0 Then
          Portb.4 = 0
          Portb.5 = 0
          Portb.6 = 1
          Portb.7 = 0
          End If
          If Pind.2 = 1 And Pind.3 = 1 And Pind.4 = 0 And Pind.5 = 0 And Pind.6 = 0 Then
          Portb.4 = 0
          Portb.5 = 0
          Portb.6 = 1
          Portb.7 = 0
          End If
          If Pind.2 = 1 And Pind.3 = 0 And Pind.4 = 0 And Pind.5 = 0 And Pind.6 = 0 Then
          Portb.4 = 0
          Portb.5 = 1
          Portb.6 = 1
          Portb.7 = 0
          End If
          If Pind.2 = 1 And Pind.3 = 1 And Pind.4 = 1 And Pind.5 = 1 And Pind.6 = 1 Then
          Portb.4 = 0
          Portb.5 = 1
          Portb.6 = 0
          Portb.7 = 1
          End If
       End If
       If Pinc.2 = 0 Then
          Portb.4 = 0
          Portb.5 = 0
          Portb.6 = 0
          Portb.7 = 0
       End If
    Es ist ein code für einen Liniensucher mit CNY70 sensoren.
    Jetzt habe ich aber folgendes Problem:
    Es funktioniert nur bei komplett schwarzem untergrund richtig(die räder drehen rückwärts).
    bei weissem untergrund schalten die motoren willkürlich durch die gegend.
    Habe die pins an portd.2 bis portd.6 wärend dem weissen untergrund mal gemessen: die scheinnen irre schnell zwischen hi und low zu schalten...
    Habe ich im code was vergessen? Ist er selbst fehlerhaft?
    Bitte um mithilfe.
    MfG Ich
    http://www.lorenzschulz.de/Roboter.html
    Erlangen
    mmmh interessanter programmierstil
    nein spass bei seite wo sind nun die Sensoren dran? an pind 2-6 oder nur einer an pinc.2 ?
    du könntest als erstes mal versuchen die if abfrage mit waitms 100 zb zu entprellen vielleicht hilft das weiter.
    die schaltung für die cny 70 sind soweit ok?
    Und schalte doch mal die internen Pullups ein, möglicherweise hängt der Pin in der Luft bei weißem Grund?
    Portc=&B11111111
    Portd=&B11111111
    (Nach dem Config .... =Input)
    Grüße
    Torsten
    Pforzheim
    Das mit den pullups habe ich in meiner schaltung berücksichtigt (10kOhm an Vcc). Die schaltung ist auch i.O. ich kann die Sensoren abgleichen und bekomme ohne das Programm auch saubere high/low signale bei sw/ws übergang.
    die 100ms bewirken nur, dass die motoren nicht so schnell schalten, sondern ruckartig.
    Danke aber trotzdem
    Noch welche vorschläge?
    MfG Ich
    Pforzheim
    Bin grad am fehler suchen, wollte mal fragen ob mir jemand bestätigen kann, dass die schaltschwelle zwischen HI und LOW beim ATMEGA32 bei 1,35V liegt?
    Erlangen
    sers
    also meines wissens nach ist alles über 4,2 volt high.
