Thema: Compiler findet Labels nicht???
    Göppingen
    Ich habe von den Bascom Demos ein Beispiel zum DS1307 folgenden Code:
    '                           DS1307.BAS
    ' shows how to use the ds1307 clock on the 2313 futurlec board
    ' it also shows the CONFIG CLOCK=USER option
    $regfile = "2313def.dat"
    $crystal = 8000000
    $baud = 19200
    $lib "mcsbyte.lbx"                                          ' for smaller code
    $lib "ds1307clock.lib"                                      ' modified lib
    'configure the scl and sda pins
    Config Sda = Portd.6
    Config Scl = Portd.5
    'address of ds1307
    Const Ds1307w = &HD0                                        ' Addresses of Ds1307 clock
    Const Ds1307r = &HD1
    Config Clock = User                                         ' this will dim the bytes automatic
    'dim other needed variables
    Dim Weekday As Byte
    Print "DS1307"
    Waitms 100
    ' assigning the time will call the SetTime routine
    Time$ = "23:58:59"                                          ' to watch the day changing value
    Date$ = "11-13-02"                                          ' 13 november 2002
      Print "Date Time : " ; Date$ ; " " ; Time$
      Waitms 500
    End
    'called from ds1307clock.lib
    Getdatetime:
      I2cstart                                                  ' Generate start code
      I2cwbyte Ds1307w                                          ' send address
      I2cwbyte 0                                                ' start address in 1307
      I2cwbyte Ds1307r                                          ' send address
      I2crbyte _sec , Ack
      I2crbyte _min , Ack                                       ' MINUTES
      I2crbyte _hour , Ack                                      ' Hours
      I2crbyte Weekday , Ack                                    ' Day of Week
      I2crbyte _day , Ack                                       ' Day of Month
      I2crbyte _month , Ack                                     ' Month of Year
      I2crbyte _year , Nack                                     ' Year
      I2cstop
      _sec = Makedec(_sec) : _min = Makedec(_min) : _hour = Makedec(_hour)
      _day = Makedec(_day) : _month = Makedec(_month) : _year = Makedec(_year)
    Return
    Setdate:
      _day = Makebcd(_day) : _month = Makebcd(_month) : _year = Makebcd(_year)
      I2cwbyte 4                                                ' starting address in 1307
      I2cwbyte _day                                             ' Send Data to SECONDS
      I2cwbyte _month                                           ' MINUTES
      I2cwbyte _year                                            ' Hours
      I2cstop
    Return
    Settime:
      _sec = Makebcd(_sec) : _min = Makebcd(_min) : _hour = Makebcd(_hour)
      I2cwbyte 0                                                ' starting address in 1307
      I2cwbyte _sec                                             ' Send Data to SECONDS
      I2cwbyte _min                                             ' MINUTES
      I2cwbyte _hour                                            ' Hours
      I2cstop
    Return
    Funktioniert!
    Wenn ich den Code nun 1 zu 1 in ein bestehendes Projekt stecke bekomme ich folgende Errors:
    Error 61:
    Line: 696
    Label not Found:
    _PRINTLONG
    Error 61:
    Line: 696
    Label not Found:
    _PRINTSDECW
    Error 61:
    Line: 696
    Label not Found:
    _PRINTLONG
    Error 61:
    Line: 696
    Label not Found:
    _PRINTLONG
    Line 695 ist die Letzte Zeile in dem Projekt. (kommentar)
    Was ist da los?
    Mfg
    Wien
    Ich glaub, das solltest du mal auskommentieren.
    $lib "mcsbyte.lbx"
    mfg robert
    Göppingen
    Der Fehler ist weg
    Danke
    Tobi
    In der Nähe von Hannover
    Was macht man denn wenn man zB RC5 benutzen möchte?
    Habe den Fehler nämlich auch
    Wien
    Öööhmm, inwiefern hängt das zusammen ?
    mfg robert
    Ich hatte gedacht, dass man die mcsbyte.lbx für die RC5 funktion braucht.
    Hab den RC5 Code hier im Forum nur damit gefunden.
    Hab aber eben rausgefunden, dass man sie nicht braucht
    Bringt mich aber zu der Frage wozu denn nun da ist?
    Aus dem Bascom Manual:
    'when only bytes are used, use the following lib for smaller code
    $lib "mcsbyte.lib"
    Genaueres ab Seite 694
    Detlef
    Danke für die Antwort
