Ergebnis 1 bis 10 von 13
Thema: LCD Problem
    Villach
    LCD Problem
    Mein LCD will leider nicht funktionieren. hab schon den ganzen tag herumprobiert, alles nachgemessen, internetrecherche,...
    Nun genaueres:
    *Linux (kanotix)
    *kontrollerlab,avrgcc, make,avrdude
    *selbstgemachtes board, mega16@16MHz
    *4bit,4*16 lcd; MC1604C-SYL
    *peter fleury lcd lib
    sourcecode:
    #include <avr/io.h>
    #include <stdlib.h>
    #include "lcd.h"
    int main (void) {
    /* Initialisiere Display, Cursor aus */
        lcd_init(LCD_DISP_ON_CURSOR_BLINK);
    /* loesche das LCD Display und Cursor auf 1 Zeile, 1 Spalte */
        lcd_clrscr();
    /* String auf Display anzeigen */
        lcd_puts("My Name is Thomas!");
       while(1) {
    lcd.h
    #ifndef LCD_H
    #define LCD_H
     Title	:   C include file for the HD44780U LCD library (lcd.c)
     Author:    Peter Fleury <pfleury@gmx.ch>  http://jump.to/fleury
     File:	    $Id: lcd.h,v 1.13.2.2 2006/01/30 19:51:33 peter Exp $
     Software:  AVR-GCC 3.3
     Hardware:  any AVR device, memory mapped mode only for AT90S4414/8515/Mega
     @defgroup pfleury_lcd LCD library
     @code #include <lcd.h> @endcode
     @brief Basic routines for interfacing a HD44780U-based text LCD display
     Originally based on Volker Oth's LCD library,
     changed lcd_init(), added additional constants for lcd_command(),
     added 4-bit I/O mode, improved and optimized code.
     Library can be operated in memory mapped mode (LCD_IO_MODE=0) or in
     4-bit IO port mode (LCD_IO_MODE=1). 8-bit IO port mode not supported.
     Memory mapped mode compatible with Kanda STK200, but supports also
     generation of R/W signal through A8 address line.
     @author Peter Fleury pfleury@gmx.ch http://jump.to/fleury
     @see The chapter Interfacing a HD44780 Based LCD to an AVR
          on my home page.
    #if (__GNUC__ * 100 + __GNUC_MINOR__) < 303
    #error "This library requires AVR-GCC 3.3 or later, update to newer AVR-GCC compiler !"
    #endif
    #include <inttypes.h>
    #include <avr/pgmspace.h>
     *  @name  Definitions for MCU Clock Frequency
     *  Adapt the MCU clock frequency in Hz to your target.
    #define XTAL 16000000              /**< clock frequency in Hz, used to calculate delay timer */
     * @name  Definition for LCD controller type
     * Use 0 for HD44780 controller, change to 1 for displays with KS0073 controller.
    #define LCD_CONTROLLER_KS0073 0  /**< Use 0 for HD44780 controller, 1 for KS0073 controller */
     *  @name  Definitions for Display Size
     *  Change these definitions to adapt setting to your display
    #define LCD_LINES           4     /**< number of visible lines of the display */
    #define LCD_DISP_LENGTH    16     /**< visibles characters per line of the display */
    #define LCD_LINE_LENGTH  0x40     /**< internal line length of the display    */
    #define LCD_START_LINE1  0x00     /**< DDRAM address of first char of line 1 */
    #define LCD_START_LINE2  0x40     /**< DDRAM address of first char of line 2 */
    #define LCD_START_LINE3  0x14     /**< DDRAM address of first char of line 3 */
    #define LCD_START_LINE4  0x54     /**< DDRAM address of first char of line 4 */
    #define LCD_WRAP_LINES      0     /**< 0: no wrap, 1: wrap at end of visibile line */
    #define LCD_IO_MODE      1         /**< 0: memory mapped mode, 1: IO port mode */
    #if LCD_IO_MODE
     *  @name Definitions for 4-bit IO mode
     *  Change LCD_PORT if you want to use a different port for the LCD pins.
     *  The four LCD data lines and the three control lines RS, RW, E can be on the
     *  same port or on different ports.
     *  Change LCD_RS_PORT, LCD_RW_PORT, LCD_E_PORT if you want the control lines on
     *  different ports.
     *  Normally the four data lines should be mapped to bit 0..3 on one port, but it
     *  is possible to connect these data lines in different order or even on different
     *  ports by adapting the LCD_DATAx_PORT and LCD_DATAx_PIN definitions.
    #define LCD_PORT         PORTC        /**< port for the LCD lines   */
    #define LCD_DATA0_PORT   LCD_PORT     /**< port for 4bit data bit 0 */
    #define LCD_DATA1_PORT   LCD_PORT     /**< port for 4bit data bit 1 */
    #define LCD_DATA2_PORT   LCD_PORT     /**< port for 4bit data bit 2 */
    #define LCD_DATA3_PORT   LCD_PORT     /**< port for 4bit data bit 3 */
    #define LCD_DATA0_PIN    2            /**< pin for 4bit data bit 0  */
    #define LCD_DATA1_PIN    3            /**< pin for 4bit data bit 1  */
    #define LCD_DATA2_PIN    4            /**< pin for 4bit data bit 2  */
    #define LCD_DATA3_PIN    5            /**< pin for 4bit data bit 3  */
    #define LCD_RS_PORT      LCD_PORT     /**< port for RS line         */
    #define LCD_RS_PIN       7            /**< pin  for RS line         */
    #define LCD_RW_PORT      PORTB        /**< port for RW line         */
    #define LCD_RW_PIN       4           /**< pin  for RW line         */
    #define LCD_E_PORT       LCD_PORT     /**< port for Enable line     */
    #define LCD_E_PIN        6            /**< pin  for Enable line     */
    #elif defined(__AVR_AT90S4414__) || defined(__AVR_AT90S8515__) || defined(__AVR_ATmega64__) || \
          defined(__AVR_ATmega8515__)|| defined(__AVR_ATmega103__) || defined(__AVR_ATmega128__) || \
          defined(__AVR_ATmega161__) || defined(__AVR_ATmega162__)
     *  memory mapped mode is only supported when the device has an external data memory interface
    #define LCD_IO_DATA      0xC000    /* A15=E=1, A14=RS=1                 */
    #define LCD_IO_FUNCTION  0x8000    /* A15=E=1, A14=RS=0                 */
    #define LCD_IO_READ      0x0100    /* A8 =R/W=1 (R/W: 1=Read, 0=Write   */
    #else
    #error "external data memory interface not available for this device, use 4-bit IO port mode"
    #endif
     *  @name Definitions for LCD command instructions
     *  The constants define the various LCD controller instructions which can be passed to the
     *  function lcd_command(), see HD44780 data sheet for a complete description.
    /* instruction register bit positions, see HD44780U data sheet */
    #define LCD_CLR               0      /* DB0: clear display                  */
    #define LCD_HOME              1      /* DB1: return to home position        */
    #define LCD_ENTRY_MODE        2      /* DB2: set entry mode                 */
    #define LCD_ENTRY_INC         1      /*   DB1: 1=increment, 0=decrement     */
    #define LCD_ENTRY_SHIFT       0      /*   DB2: 1=display shift on           */
    #define LCD_ON                3      /* DB3: turn lcd/cursor on             */
    #define LCD_ON_DISPLAY        2      /*   DB2: turn display on              */
    #define LCD_ON_CURSOR         1      /*   DB1: turn cursor on               */
    #define LCD_ON_BLINK          0      /*     DB0: blinking cursor ?          */
    #define LCD_MOVE              4      /* DB4: move cursor/display            */
    #define LCD_MOVE_DISP         3      /*   DB3: move display (0-> cursor) ?  */
    #define LCD_MOVE_RIGHT        2      /*   DB2: move right (0-> left) ?      */
    #define LCD_FUNCTION          5      /* DB5: function set                   */
    #define LCD_FUNCTION_8BIT     4      /*   DB4: set 8BIT mode (0->4BIT mode) */
    #define LCD_FUNCTION_2LINES   3      /*   DB3: two lines (0->one line)      */
    #define LCD_FUNCTION_10DOTS   2      /*   DB2: 5x10 font (0->5x7 font)      */
    #define LCD_CGRAM             6      /* DB6: set CG RAM address             */
    #define LCD_DDRAM             7      /* DB7: set DD RAM address             */
    #define LCD_BUSY              7      /* DB7: LCD is busy                    */
    /* set entry mode: display shift on/off, dec/inc cursor move direction */
    #define LCD_ENTRY_DEC            0x04   /* display shift off, dec cursor move dir */
    #define LCD_ENTRY_DEC_SHIFT      0x05   /* display shift on,  dec cursor move dir */
    #define LCD_ENTRY_INC_           0x06   /* display shift off, inc cursor move dir */
    #define LCD_ENTRY_INC_SHIFT      0x07   /* display shift on,  inc cursor move dir */
    /* display on/off, cursor on/off, blinking char at cursor position */
    #define LCD_DISP_OFF             0x08   /* display off                            */
    #define LCD_DISP_ON              0x0C   /* display on, cursor off                 */
    #define LCD_DISP_ON_BLINK        0x0D   /* display on, cursor off, blink char     */
    #define LCD_DISP_ON_CURSOR       0x0E   /* display on, cursor on                  */
    #define LCD_DISP_ON_CURSOR_BLINK 0x0F   /* display on, cursor on, blink char      */
    /* move cursor/shift display */
    #define LCD_MOVE_CURSOR_LEFT     0x10   /* move cursor left  (decrement)          */
    #define LCD_MOVE_CURSOR_RIGHT    0x14   /* move cursor right (increment)          */
    #define LCD_MOVE_DISP_LEFT       0x18   /* shift display left                     */
    #define LCD_MOVE_DISP_RIGHT      0x1C   /* shift display right                    */
    /* function set: set interface data length and number of display lines */
    #define LCD_FUNCTION_4BIT_1LINE  0x20   /* 4-bit interface, single line, 5x7 dots */
    #define LCD_FUNCTION_4BIT_2LINES 0x28   /* 4-bit interface, dual line,   5x7 dots */
    #define LCD_FUNCTION_8BIT_1LINE  0x30   /* 8-bit interface, single line, 5x7 dots */
    #define LCD_FUNCTION_8BIT_2LINES 0x38   /* 8-bit interface, dual line,   5x7 dots */
    #define LCD_MODE_DEFAULT     ((1<<LCD_ENTRY_MODE) | (1<<LCD_ENTRY_INC) )
     *  @name Functions
     @brief    Initialize display and select type of cursor
     @param    dispAttr \b LCD_DISP_OFF display off\n
                        \b LCD_DISP_ON display on, cursor off\n
                        \b LCD_DISP_ON_CURSOR display on, cursor on\n
                        \b LCD_DISP_ON_CURSOR_BLINK display on, cursor on flashing
     @return  none
    extern void lcd_init(uint8_t dispAttr);
     @brief    Clear display and set cursor to home position
     @param    void
     @return   none
    extern void lcd_clrscr(void);
     @brief    Set cursor to home position
     @param    void
     @return   none
    extern void lcd_home(void);
     @brief    Set cursor to specified position
     @param    x horizontal position\n (0: left most position)
     @param    y vertical position\n   (0: first line)
     @return   none
    extern void lcd_gotoxy(uint8_t x, uint8_t y);
     @brief    Display character at current cursor position
     @param    c character to be displayed
     @return   none
    extern void lcd_putc(char c);
     @brief    Display string without auto linefeed
     @param    s string to be displayed
     @return   none
    extern void lcd_puts(const char *s);
     @brief    Display string from program memory without auto linefeed
     @param    s string from program memory be be displayed
     @return   none
     @see      lcd_puts_P
    extern void lcd_puts_p(const char *progmem_s);
     @brief    Send LCD controller instruction command
     @param    cmd instruction to send to LCD controller, see HD44780 data sheet
     @return   none
    extern void lcd_command(uint8_t cmd);
     @brief    Send data byte to LCD controller
     Similar to lcd_putc(), but without interpreting LF
     @param    data byte to send to LCD controller, see HD44780 data sheet
     @return   none
    extern void lcd_data(uint8_t data);
     @brief macros for automatically storing string constant in program memory
    #define lcd_puts_P(__s)         lcd_puts_p(PSTR(__s))
    #endif //LCD_H
    Pinbelegung:
    RS: pc7
    rw: pb4
    en: pc6
    d4-7: pc2-5
    Problem:
    Am LCD werden wenn ich den kontrast erhöhe die 1. und 3. zeile dunkel angezeigt.
    Es soll jedoch ein text angezeigt werden.
    Lg
    Thomas
    Pasching OÖ
    Ich nehme an das das Display HD44780 kompatibel ist.
    Die dunklen Zeilen deuten auf eine fehlende/fehlgeschlagene Initialisierung hin.
    Villach
    Ich bin mir nicht mal sicher ob das das lcd ist, denn bei Farnell gibs unter dieser bezeichnung eines mit farbe
    Das MC1604 hab ich als anleitung bei alldatasheet gefunden aber da stimmen die maße nicht.
    http://de.farnell.com/jsp/search2/br...questid=276742
    Das display wird jedoch initialisiert im code. warum ist der fehler dann noch immer da?
    lg
    Thomas
    Pasching OÖ
    Wenn es richtig initialisiert wird sollten alle Zeilen dunkel werden wenn du am Kontrast drehst, wenn der Code richtig abläuft heisst es ja nicht das er auf dem LCD funktioniert.
    Es könnte auch ein LCD mit zwei Kontroller sein, die haben dann allerdings 16 Anschlusspin ohne der Beleuchtung.
    Hubert
    Villach
    also ich hab 16 anschlusspins. hintergrundbeleuchtung hab ich denn die ist angeschlossen und eingeschalten. nachdem das display ja was anzeigt müssten die leitungen vcc, vdd, vo (contrast) auch richtig sein.
    Nürnberg
    Moin,
    hatte das gleiche Problem mit meinem Display! Hatte weder mit der Source von Fleury noch mit der von Vajk erfolg! Irgendwann habe ich dann in meinem Datenblatt entdeckt das ich 2 Treiber auf dem LCD habe! Hbae dann die Header entsprechend angepasst! (Geht P.Fleury überhaupt mit 2 Treibern?), und jetzt gehts!
    Was mich lange aufgehalten hat ist das ich trotz zweier Treiber nur einen Enable-Pin habe! Schicke jetzt auf ein und denselben Pin Enable SIgnale und des geht!
    Da du dein LCD an PORT C angeschlossen hast musst du möglicherweise noch JTAG deaktivieren das es geht!
    Viel ERfolg!
    Mich hat es viel Zeit und noch mehr Nerven gekostet!
    Ich bin keine Signatur ich mach hier nur sauber
    Villach
    Hi nochmal.
    Hier mein Datenblatt:
    http://www.farnell.com/datasheets/61714.pdf
    irgendwie blick ich da nicht so durch. das nächste problem ist. es steht MC1604-SYL hinten am Display drauf, doch es ist grün und nicht so wie am foto bei farnell.
    http://at.farnell.com/jsp/search2/br...questid=311220
    lg
    Thomas
    Dietfurt
    @Superhirn
    Hast Du auch die JTAGEN Fuse des ATMEGA 16 abgeschaltet - das war bei mir das Problem, das ich fand nachdem ich das Zeug 3x Auseinadergenommen hab.
    Die bei ATMEL spinnen auch ein wenig - schalten das JTAG bei Auslieferung ein !
    Villach
    JTAG ist abgeschaltet. Im anhang ist meine derzeitige fusebitconfiguration.
    Mein Quarz ist 16MHz.
    Das JTAG aktiviert ist ist für manche siche schon von vorteil, denn es gibt ja doch leute die sich das leisten können bzw eins selber baun und dann brauchen sie nicht zuerst ISP dass alles geht.
    lg
    Thomas
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken bildschirmphoto2_654.png
    Pasching OÖ
    Nach meiner Liste arbeitetst du mit Internem Oszillator 1MHZ
    Das Häckchen gehört nur bei CKSEL0
    Schau mal hier:
    palmavr.sourceforge.net/cgi-bin/fc.cgi
