Ergebnis 1 bis 7 von 7
Thema: help on gameboy asuro project!
    allo!
    ich bin franzosich und ich spreche nicht gut deustsch!
    so i can speak english or french!
    i can not reach to understand every thing on your forum.
    I found some interresting project but there's alway only a part.
    For example, i want to make use a gameboy camera but i found no program for using this and no librairy.
    before all i didn't found explication how to plug it on ausro I2C connector.
    Please help me.
    thanx
    Milda
    this also will be hard, i dont think that anybody really made it work. some people had a few trys, but in the end, nobody really made it work completely. (as far as i know)
    Read... or die.
    ff.mud.de:7600
    what do you want to do with your camera?
    do you want to evaluate the signal with asuro, or do you want to send it to the computer?
    for the first ist not possible. (the atmega8 is too bad)
    for the second you can use a normal radio observation camera
    qu'est-ce que tu veux faire avec ton camera?
    est ce-que tu veux exploites le signal ou est-ce que tu veux envoye lui `a l'ordinateur?
    le premier n'est pas possible (l'atmega8 est trop mal)
    par le deuxieme tu peux utiliser une normale camera de monitorage
    uff. das ist anstrengend. aber manchmal lohnt es sich doch im g8-bayern zu wohnen.
    in fact i want use camera to send back the signal by a bluethoot module and make computer recognize some shape.
    Computer is the master and asuro the slave.
    is the bluetooth modem only to send the signal to the computer or should asuro be able to communicate with it.
    it think that won't be possible. you would need a better µc.
    Milda
    the bluetooth project should be possible, but the thing with the camera will be very complicatted, because the µC iis much too weak for calculating the whole picture or even finding shapes in it.
    Read... or die.
    ff.mud.de:7600
    Maybee it would be easier too use a small camera with radio link
    You attach its reciever to your TV Card and send all information using the IR Link
    On the other hand there are several disatvantages
    * The Camera is very expensive (about 50€)
    * Most cameras require 12 Volts for Operation
    If you use a GB Cam Module (1 and 2)
    you have to buy a bluethooth module (even expensive) and a second µC to do the communication between the bluethooth-module camera-module and ASURO.
    This should be usefull
    1 http://www.kreatives-chaos.com/artik...oykamera-modul
    2 http://www.seattlerobotics.org/encod...205/gbcam.html
    3 http://www.seattlerobotics.org/encod...cle3/index.php
    4 http://sourceforge.net/projects/opencvlibrary/
