Thema: Probleme mit Steuerprogramm für 104x7 Pixel LED-Anzeige
    Neuer Benutzer
    Hallo zusammen , das ist mein erster Post hier.
    Zu meine Problem ich hab hier Zuhaus eine LED-Anzeige liegen für die ich ein Steuerprogramm geschrieben habe.
    Wenn ich Zeilen einzeln anspreche funktioniert das auch so wie es soll , nur sobald ich alle Zeilen anspreche "flackert" jede zweite Zeile.
    Vieleicht sehr ihr da in meinem Programmcode ihrgend etwas was man anders machen sollte.
    main.c
    int main(void)
    	init_display();
    	printf("Programm gestartet !\n");
    uint8_t text[7][56] =
    {{0,0,1,1,1,1,1,1,0,0,1,1,1,1,0,0,1,1,1,1,0,0,1,1,1,1,1,0,0,0,0,0,0,0,0,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
    ,{0,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,1,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
    ,{0,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,1,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
    ,{0,0,0,0,0,1,0,0,0,0,1,1,1,0,0,0,0,1,1,0,0,0,0,0,1,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
    ,{0,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
    ,{0,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,0,0,0,0,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
    ,{0,0,0,0,0,1,0,0,0,0,1,1,1,1,0,0,1,1,1,1,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}	};
    	while(1)
    		uint8_t i;
    		for(i=0;i<7;i++)
    			anzeigen(text[i],i);
    	return 0;
    led.c
    7 Zeilen
    8 Spalten
    14 Segmente:
      0| x x x x x x x x
    Z 1| x x x x x x x x
    e 2| x x x x x x x x
    i 3| x x x x x x x x
    l 4| x x x x x x x x
    e 5| x x x x x x x x
    n 6| x x x x x x x x
       | 0 1 2 3 4 5 6 7 . . .
           Spalten
    PORTA
    PA0 Clock
    PA1 Daten
    PA2 Enable Zeilen
    PA3-PA5 Binär Zeile 1-7
    #include <io.h>
    #include <stdlib.h>
    #include <stdio.h>
    #include <util/delay.h>
    #define CHECKBIT(ADDRESS,BIT) (ADDRESS & (1<<BIT))
    #define SETBIT(ADDRESS,BIT) (ADDRESS |= (1<<BIT))
    #define CLEARBIT(ADDRESS,BIT) (ADDRESS &= ~(1<<BIT))
    #define TOGGLEBIT(ADDRESS, BIT) ((ADDRESS) ^= (1 << (BIT)))
    #define MAX_ZEICHEN 56
    #define CLOCK PA0
    #define DATEN PA1
    #define ENABLE PA2
    #define ZEILE2_0 PA3
    #define ZEILE2_1 PA4
    #define ZEILE2_2 PA5
    void init_display()
    	// Pin 0 bis 5 als Ausgangdefinieren
    	DDRA = (1<<DDA0) | (1<<DDA1) | (1<<DDA2) | (1<<DDA3) | (1<<DDA4) | (1<<DDA5);
    	CLEARBIT(PORTA,ENABLE);// Enable auf 0 setzen  -> Zeilen deaktiviert.
    	CLEARBIT(PORTA,CLOCK); // Clock auf 0
    	CLEARBIT(PORTA,DATEN); // Daten auf 0
    	SETBIT(PORTA,ZEILE2_0); //1
    	CLEARBIT(PORTA,ZEILE2_1); //0  Zeile 0 ausgewählt
    	CLEARBIT(PORTA,ZEILE2_2); //0
    void select_zeile(uint8_t zeile)
    	if(zeile == 0)
    	if(zeile == 1)
    	CLEARBIT(PORTA,ZEILE2_0); //0
    	SETBIT(PORTA,ZEILE2_1); //1  Zeile 1 ausgewählt
    	if(zeile == 2)
    	SETBIT(PORTA,ZEILE2_1); //1  Zeile 2 ausgewählt
    	if(zeile == 3)
    	CLEARBIT(PORTA,ZEILE2_1); //0  Zeile 3 ausgewählt
    	SETBIT(PORTA,ZEILE2_2); //1
    	if(zeile == 4)
    	CLEARBIT(PORTA,ZEILE2_1); //0  Zeile 4 ausgewählt
    	if(zeile == 5)
    	CLEARBIT(PORTA,ZEILE2_0);//0
    	SETBIT(PORTA,ZEILE2_1); //1  Zeile 5 ausgewählt
    	if(zeile == 6)
    void anzeigen(uint8_t data[], uint8_t zeile)
    	uint8_t k;
    	//Daten in Register laden
    	for (k = MAX_ZEICHEN; k!=0; k--)
    		if (data[k] !=0) 				//Welchen Status hat das nächste Bit
    			SETBIT(PORTA,DATEN); 		//PORT high, falls Bit == 1;
    		else
    			CLEARBIT(PORTA,DATEN); 		//PORT low, sonst
    		SETBIT(PORTA,CLOCK);  			//CLOCK AN, Pegel übernehmen
    		_delay_us(20);
    		CLEARBIT(PORTA,CLOCK);	  		//CLOCK AUS
    	//Zeile wählen und anzeigen
    	select_zeile(zeile);			//Zeile wählen
    	_delay_ms (20);
    	SETBIT(PORTA,ENABLE);			//Gewählte Zeile einschalten
    	_delay_ms (20);
    	CLEARBIT(PORTA,ENABLE);			//Gewählte Zeile ausschalten
    Es funktioniert alles soweit, es geht halt nur um "logischefehler" die ich so nicht sehe.
    Wäre nett wenn sich das mal jemand mit mehr ahnung als ich ansehen könnte.
    flacker.. kann gut sein das es vom Mikrocontroller her kommt, vielleicht wenn du die daten schneller raustaktest?
    Neuer Benutzer
    Das hab ich schon probiert , naja flackern is vieleicht etwas blöd beschrieben , es ist mehr so das jede zweite zeile immer um 2-3 pixel nach links oder rechts springt.
    der einfachste fehler wäre, es stimmt z.b. ein nuller nicht in deiner textmatrix?
    dass du dich da vielleicht vertan hast?
