hi leute ich schreib mal den quellcode....hab nen atmega8 und passendes board mit RN-Funk ...hab allerdings ein problem mit der anzahl der messwerte pro sekunde.. nun meine frage geht das irgendwie schneller?
Code:$regfile = "m8def.dat" $hwstack = 82 $framesize = 68 $swstack = 68 $crystal = 16000000 'Quarzfrequenz $baud = 19200 Config Adc = Single , Prescaler = Auto , Reference = Avcc Timsk = &B00100101 Mcucr = &B00001010 Gicr = &B11000000 Sreg = &B10000000 Tccr1b = &B11000010 Config Pinc.0 = Input Config Pinc.1 = Input Config Pinc.2 = Input Config Pinc.3 = Input Config Pind.0 = Input Config Pind.2 = Input Config Pind.3 = Input Const Ref = 4950 / 1023 Const Zei = 1 / 0.0156 Dim A As Integer Dim I As Integer Dim Volt As Long Dim D As Long Dim W As Long Config Single = Scientific , Digits = 1 On Timer0 Aus On Int0 Ir0 'Portd pin3 Config Timer1 = Timer , Capture Edge = Rising , Noise Cancel = 0 , Prescale = 1024 Config Timer0 = Timer , Prescale = 1024 Stop Timer1 Stop Timer0 Dim Test As Integer Do For I = 0 To 3 Start Adc W = Getadc(i) Volt = W * Ref Print ; I ; " " ; Volt Waitms 30 Next I 'D = D * Zei Loop End Aus: A = A + 1 Return Ir0: Stop Timer1 D = Timer1 Timer1 = 0 Print "4 " ; D Start Timer1 Return
Zitieren
Lesezeichen
