Ergebnis 1 bis 3 von 3
Thema: UART zwischen Atmega32 und ATmega8
    Dortmund
    für meinen Bot muss ich eine Kommunikation via UART atmega8 (hardware UART) und atmega 32 (software uart) aufbauen. Nur richtig funktionieren tuts nicht. Ich poste mal den Code beider Seiten. Wenn ich den atmega8 einfach so die Motoren einschalten lasse, funktioniert es aber.
    $regfile = "m32def.dat"
    $crystal = 16000000
    Config Portc.1 = Output
    Config Portd.2 = Output
    Config Portd.7 = Output
    Config Portd.6 = Output
    Open "comd.7:9600,8,n,1" For Input As #1
    Open "comd.6:9600,8,n,1" For Output As #2
    Dim Entfernung As Integer
    Dim Motorspeedright As Byte
    Dim Motorspeedleft As Byte
    Dim Directionright As String * 3
    Dim Directionleft As String * 3
    Motorspeedright = 100
    Motorspeedleft = 100
    Directionright = "Rwd"
    Directionleft = "Rwd"
    Waitms 500
    Portc.1 = 1
    Waitms 00
    Portc.1 = 0
    Print #2 , Motorspeedright
    Waitms 1
    Print "tschacka 1"
    Print #2 , Motorspeedleft
    Waitms 1
    Print "tschacka 2"
    'Print #2 , Directionright
    Waitms 1
    Print "tschacka 3"
    'Print #2 , Directionleft
    Waitms 1
    Print "tschacka 4"
    End
    $regfile = "m8def.dat"
    $crystal = 1000000
    Dim A As Bit
    Dim B As Bit
    Dim C As Bit
    Dim D As Bit
    Config Portc.0 = Output
    Config Portc.2 = Output
    Config Portc.3 = Output
    Config Portb.1 = Output
    Config Portb.2 = Output
    Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 1
    Input Motorspeedright
    Input Motorspeedleft
    'Input Directionright
    'Input Directionleft
    'If Directionright = "Fwd" Then
    'A = 0
    'B = 1
    'End If
    'If Directionright = "Rwd" Then
    'A = 1
    'B = 0
    'End If
    'If Directionright = "Stop" Then
    'A = 0
    'B = 0
    'End If
    'If Directionleft = "Fwd" Then
    'C = 0
    'D = 1
    'End If
    'If Directionleft = "Rwd" Then
    'C = 1
    'd = 0
    'End If
    'If Directionleft = "Stop" Then
    'C = 0
    'D = 0
    'End If
    Compare1a = Motorspeedright
    Compare1b = Motorspeedleft
    Portc.0 = 0      'A
    Portc.1 = 1      'B
    Portc.2 = 0      'C
    Portc.3 = 1      'D
    End
    Die Motoren laufen beim UART nicht an, klicken aber einmal und lassen sich per Hand kaum noch drehen. Das klicken führe ich auf eine kleine Bewegung des Ankers zurück, die Bremsung interpretiere ich so, dass Strom durchfließt, aber anscheinend irgendwie nicht genug. Was hab ich denn falsch gemacht?
    EDIT: Der UART funktioniert aber. Wenn ich den Stecker abnehme klicken die Motoren nicht mehr.
    o
    L_
    OL
    ich kann dir mal mein musterrobbi-code geben. ich empfange die seriellen daten über interrupt. der code funktioniert auf dem AVR32 :
    $Regfile =  "M32def.dat"
    $Crystal = 8000000
    $HWStack = 32
    $SWStack = 32
    $FrameSize = 64
    $Baud = 19200
    Dim M_wert_a As Byte , M_wert_b As Byte
    Dim Text As String * 16
    Declare Sub Robby_vor()
    Declare Sub Robby_zurueck()
    Declare Sub Robby_links()
    Declare Sub Robby_rechts()
    Declare Sub Robby_links_drehen()
    Declare Sub Robby_rechts_drehen()
    Declare Sub Robby_aus()
    Declare Sub L293_pin()
    declare sub empfang()
    Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear down , Compare B Pwm = Clear down , Prescale = 256
    Start Timer1
    config int2=rising
    On Int2 Int2_int
    Enable Interrupts
    Enable Int2
    Open "comb.2:9600,8,n,1" For Input As #1
    Call L293_pin()
    do
       waitms 300
    loop
    End
    Int2_int:
       Disable Int2
       Enable Interrupts
       input #1, text
       waitms 10
       call empfang()
       enable int2
    Return
    sub empfang()
     If Text = "vor" Then
       M_wert_a = 100
       M_wert_b = 100
       Call Robby_vor()
     End If
     If Text = "zurueck" Then
       M_wert_a = 100
       M_wert_b = 100
       Call Robby_zurueck()
     End If
     If Text = "links" Then
       M_wert_a = 60
       M_wert_b = 60
       Call Robby_links()
     End If
     If Text = "rechts" Then
       M_wert_a = 60
       M_wert_b = 60
       Call Robby_rechts()
     End If
     If Text = "stop" Then
      Call Robby_aus()
     End If
    end sub
    Sub L293_pin()
       Ddrc.2 = 1
       Ddrc.3 = 1
       Ddrc.4 = 1
       Ddrc.5 = 1
       Ddrd.4 = 1
       Ddrd.5 = 1
    End Sub
    Sub Robby_vor()
        Portc.2 = 0    'rechter motor
        Portc.3 = 1
        Portd.5 = 1
        Portc.4 = 0    'linker motor
        Portc.5 = 1
        Portd.4 = 1
        Pwm1a = M_wert_a
        Pwm1b = M_wert_b
    End Sub
    Sub Robby_zurueck()
        Portc.2 = 1    'rechter motor
        Portc.3 = 0
        Portd.5 = 1
        Portc.4 = 1     'linker motor
        Portc.5 = 0
        Portd.4 = 1
        Pwm1a = M_wert_a
        Pwm1b = M_wert_b
    End Sub
    Sub Robby_links()
        Portc.2 = 0
        Portc.3 = 1
        Portd.5 = 1
        Portc.4 = 0
        Portc.5 = 0
        Portd.4 = 0
        Pwm1a = M_wert_a
        Pwm1b = 0
    End Sub
    Sub Robby_rechts()
        Portc.2 = 0
        Portc.3 = 0
        Portd.5 = 0
        Portc.4 = 0
        Portc.5 = 1
        Portd.4 = 1
        Pwm1a = 0
        Pwm1b = M_wert_b
    End Sub
    Sub Robby_aus()
        Portc.2 = 0
        Portc.3 = 0
        Portd.4 = 0
        Portc.4 = 0
        Portc.5 = 0
        Portd.5 = 0
        Pwm1a = 0
        Pwm1b = 0
    End Sub
        Portc.2 = 1
        Portc.3 = 0
        Portd.5 = 1
        Portc.4 = 0
        Portc.5 = 1
        Portd.4 = 1
        Pwm1a = M_wert_a
        Pwm1b = M_wert_b
    End Sub
        Portc.2 = 0
        Portc.3 = 1
        Portd.5 = 1
        Portc.4 = 1
        Portc.5 = 0
        Portd.4 = 1
        Pwm1a = M_wert_a
        Pwm1b = M_wert_b
    End Sub
    Dortmund
    ja, das hat mir schon weitergeholfen, auf die idee mit text bin ich gar nicht gekommen. Danke!
    o
    L_
    OL
