Hallo Leute
Bitte um Hilfe!!
Bin gerade am Umsteigen von Bascom auf C
Habe leider derzeit Probleme mit den Makefile!
Habe das zuerst mal das originale Makfile mit "Mfile" probiert
Funktionierte leider nicht .
Dann habe ich eine Makefile von den Demo Programmen probiert.
Inzwischen läuft zumindest die Compilierung und ich konnte mein kleines Versuchsprogramm im AVR Studio simulieren.
Dieses Makfile schaute so aus:
PRG            = Meines
OBJ            = Meines.o
#MCU_TARGET     = at90s2313
#MCU_TARGET     = at90s2333
#MCU_TARGET     = at90s4414
#MCU_TARGET     = at90s4433
#MCU_TARGET     = at90s4434
#MCU_TARGET     = at90s8515
#MCU_TARGET     = at90s8535
#MCU_TARGET     = atmega128
#MCU_TARGET     = atmega1280
#MCU_TARGET     = atmega1281
MCU_TARGET     = atmega16
#MCU_TARGET     = atmega163
#MCU_TARGET     = atmega164p
#MCU_TARGET     = atmega165
#MCU_TARGET     = atmega165p
#MCU_TARGET     = atmega168
#MCU_TARGET     = atmega169
#MCU_TARGET     = atmega169p
#MCU_TARGET     = atmega32
#MCU_TARGET     = atmega324p
#MCU_TARGET     = atmega325
#MCU_TARGET     = atmega3250
#MCU_TARGET     = atmega329
#MCU_TARGET     = atmega3290
#MCU_TARGET     = atmega48
#MCU_TARGET     = atmega64
#MCU_TARGET     = atmega640
#MCU_TARGET     = atmega644
#MCU_TARGET     = atmega644p
#MCU_TARGET     = atmega645
#MCU_TARGET     = atmega6450
#MCU_TARGET     = atmega649
#MCU_TARGET     = atmega6490
#MCU_TARGET     = atmega8
#MCU_TARGET     = atmega8515
#MCU_TARGET     = atmega8535
#MCU_TARGET     = atmega88
#MCU_TARGET     = attiny2313
#MCU_TARGET     = attiny24
#MCU_TARGET     = attiny25
#MCU_TARGET     = attiny26
#MCU_TARGET     = attiny261
#MCU_TARGET     = attiny44
#MCU_TARGET     = attiny45
#MCU_TARGET     = attiny461
#MCU_TARGET     = attiny84
#MCU_TARGET     = attiny85
#MCU_TARGET     = attiny861
OPTIMIZE       = -O2
DEFS           =
LIBS           =
# You should not have to change anything below here.
CC             = avr-gcc
# Override is only needed by avr-lib build system.
override CFLAGS        = -g -Wall $(OPTIMIZE) -mmcu=$(MCU_TARGET) $(DEFS)
override LDFLAGS       = -Wl,-Map,$(PRG).map
OBJCOPY        = avr-objcopy
OBJDUMP        = avr-objdump
all: $(PRG).elf lst text eeprom
$(PRG).elf: $(OBJ)
	$(CC) $(CFLAGS) $(LDFLAGS) -o $@ $^ $(LIBS)
# dependency:
clean:
	rm -rf *.o $(PRG).elf *.eps *.png *.pdf *.bak
	rm -rf *.lst *.map $(EXTRA_CLEAN_FILES)
lst:  $(PRG).lst
%.lst: %.elf
	$(OBJDUMP) -h -S $< > $@
# Rules for building the .text rom images
text: hex bin srec
hex:  $(PRG).hex
bin:  $(PRG).bin
srec: $(PRG).srec
%.hex: %.elf
	$(OBJCOPY) -j .text -j .data -O ihex $< $@
%.srec: %.elf
	$(OBJCOPY) -j .text -j .data -O srec $< $@
%.bin: %.elf
	$(OBJCOPY) -j .text -j .data -O binary $< $@
# Rules for building the .eeprom rom images
eeprom: ehex ebin esrec
ehex:  $(PRG)_eeprom.hex
ebin:  $(PRG)_eeprom.bin
esrec: $(PRG)_eeprom.srec
%_eeprom.hex: %.elf
	$(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O ihex $< $@
%_eeprom.srec: %.elf
	$(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O srec $< $@
%_eeprom.bin: %.elf
	$(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O binary $< $@
# Every thing below here is used by avr-libc's build system and can be ignored
# by the casual user.
FIG2DEV                 = fig2dev
EXTRA_CLEAN_FILES       = *.hex *.bin *.srec
dox: eps png pdf
eps: $(PRG).eps
png: $(PRG).png
pdf: $(PRG).pdf
%.eps: %.fig
	$(FIG2DEV) -L eps $< $@
%.pdf: %.fig
	$(FIG2DEV) -L pdf $< $@
%.png: %.fig
	$(FIG2DEV) -L png $< $@
Jetzt möchte ich aber gerne das schreiben in den AVR auch gleich mit dem "AVRDUDE" erledigen lassen.
Habe dafür die beiden Zeilen für AVRDUDE von den Hilfen hier im Netz dazugefügt.
AVRDUDE_PROGRAMMER= stk200
AVRDUDE_PORT =lpt1
Leider rührt sich da aber nix
Jetzt habe ich mal wieder das Originale File Von "MFILE" probiert und
meine Werte dazu geändert
c-File = Meines.c
STK200 /LPT1
Ist in der zweiten Teil (Nachrichtentext zu lang )
Es kommt dann immer die Meldung:
No rule to make target 'obj/main.o' needed by 'Meines.elf'. STop
Bitte um Hilfe!
Habe das Forum durchgeschaut , aber dazu leider nicht viel gefunden
(nur Standardeinstellungen für das Makfile von File-Name und Prozessor..)
Gibt es vielleicht irgendwo ein gute beschreibung für Makile's in deutsch?
l.G. Roberto
