hallo, bei folgendem Code sollte eigentlich je nach gedrückter Taste ne
LED unterschiedlich oft angehen. Tut sie aber nicht
Was ist da los?
$regfile = "m32def.dat"
$framesize = 32
$swstack = 32
$hwstack = 32
$crystal = 1000000
Config Portc.0 = Output
Config Porta = Input
Porta = 1
Config Portb = Input
Portb = 1
Dim Taste As Integer
Dim Taste2 AS Word
Dim J AS Integer
J = 0
Declare Sub ausgeben(byval impulse As Integer)
  Taste = 0
  if Pinb.0 = 1 Then
    Portc.0 = 1
    Taste = 4
  elseif Pinb.1 = 1 Then
    Portc.0 = 1
    Taste = 3
  elseif Pinb.2 = 1 Then
    Portc.0 = 1
    Taste = 2
  elseif Pinb.3 = 1 Then
    Portc.0 = 1
    Taste = 1
  elseif Pinb.4 = 1 Then
    Portc.0 = 1
    Taste = 8
  elseif Pinb.5 = 1 Then
    Portc.0 = 1
    Taste = 7
  elseif Pinb.6 = 1 Then
    Portc.0 = 1
    Taste = 6
  elseif Pinb.7 = 1 Then
    Portc.0 = 1
    Taste = 5
  'elseif Pina.0 = 1 Then
  '  Portc.0 = 1
  '  Taste2 = "="
  'elseif Pina.1 = 1 Then
  '  Portc.0 = 1
  '  Taste2 = "C"
  elseif Pina.2 = 1 Then
    Portc.0 = 1
    Taste = 0
  elseif Pina.3 = 1 Then
    Portc.0 = 1
    Taste = 9
  'elseif Pina.4 = 1 Then
  '  Portc.0 = 1
  '  Taste2 = "+"
  'elseif Pina.5 = 1 Then
  '  Portc.0 = 1
  '  Taste2 = "-"
  'elseif Pina.6 = 1 Then
  '  Portc.0 = 1
  '  Taste2 = "*"
  'elseif Pina.7 = 1 Then
  '  Portc.0 = 1
  '  Taste2 = "/"
  end if
  if Taste = 0 then
    'des geits itt
  else
    call ausgeben (Taste)
  end if
End
Sub ausgeben(byval Impulse As Byte) 'Schrittmotor links drehen
  For J = 1 To Impulse
    Portc.0 = 1
    waitms 200
    Portc.0 = 0
    waitms 200
  Next
End Sub
fat32
