Thema: SHT11 - instabile Messwerte
    Hannover
    Guten Abend zusammen!
    Habe mir vor einiger Zeit den Luftfeuchtigkeits und Temperatursensor zugelegt.
    Nun habe ich zum Test einfach mal die Zeilen von der Mcselec-Homepage in meinen Mega32 geladen.
    Leider bekomme ich sich ständig ändernde Werte auf dem Display angezeigt.
    Sie schwanken bis zu knapp 1°C.
    Kann sich da jemand einen reim drauf machen?
    Anbei poste ich mal den Code:
    $regfile = "m32def.dat"
    $crystal = 8000000
    Config Lcd = 20 * 4
    Cursor Off
    Cls
    Dim Ctr As Byte
    Dim Dataword As Word
    Dim Command As Byte
    Dim Dis As String * 20
    Dim Calc As Single
    Dim Calc2 As Single
    Dim Rhlinear As Single
    Dim Rhlintemp As Single
    Dim Tempc As Single
    Dim Tempf As Single
    Const C1 = -4
    Const C2 = 0.0405
    Const C3 = -0.0000028
    Const T1c = .01
    Const T2 = .00008
    Const T1f = .018
    Sck Alias Portb.0
    Dataout Alias Portb.1
    Datain Alias Pinb.1
    Redled Alias Portb.2
    Declare Sub Getit()
    Ddrb = &B11111111                                           'all port b are output
    Config Pinb.0 = Output                                      'sck
    Config Pinb.1 = Output                                      'datain
    Waitms 12
    'reset the serial communications first, it is easily confused!
    Set Dataout
    For Ctr = 1 To 12
     Set Sck
     Waitus 2
     Reset Sck
     Waitus 2
    Next Ctr
    Do                                                          'continually read the tempfature and humidity
     Command = &B00000011
     Call Getit                                                 'Get the temperature, puts result in "dataword" for us
     Tempf = T1f * Dataword
     Tempf = Tempf - 40
     Tempc = T1c * Dataword                                     'get celcius for later calculations and for "the rest of the world"
     Tempc = Tempc - 40
     Dis = Fusing(tempc , "###.##")
     Locate 1 , 1
     Lcd "Temp = " ; Dis ; " (F)"
     Command = &B00000101
     Call Getit                                                 'get the humidity
     Calc = C2 * Dataword
     Calc2 = Dataword * Dataword                                'that "2" in the datasheet sure looked like a footnote for a couple days, nope it means "squared"!
     Calc2 = C3 * Calc2
     Calc = Calc + C1
     Rhlinear = Calc + Calc2
     'Dis = Fusing(rhlinear , "##.##")
     'Print "Humidity adjusted for linear = " ; Dis
     Calc = T2 * Dataword
     Calc = Calc + T1c
     Calc2 = Tempc - 25
     Calc = Calc2 * Calc
     Rhlintemp = Calc + Rhlinear
     Dis = Fusing(rhlintemp , "##.##")
     Locate 2 , 1
     Lcd "Humidity = " ; Dis
     Wait 3
    Sub Getit()
     Local Datavalue As Word
     Local Databyte As Byte
     'start with "transmission start"
     Set Sck
     Reset Dataout
     Reset Sck
     Set Sck
     Set Dataout
     Reset Sck
     'now send the command
     Shiftout Dataout , Sck , Command , 1
     Ddrb = &B11111101                                          'datain is now input
     Config Pinb.1 = Input                                      'datain
     Set Sck                                                    'click one more off
     Reset Sck
     Waitus 10                                                  'no idea why, but it doesn't work without it!
     Bitwait Pinb.1 , Reset                                     'wait for the chip to have data ready
     Shiftin Datain , Sck , Databyte , 1                        'get the MSB
     Datavalue = Databyte
     Ddrb = &B11111111
     Reset Dataout                                              'this is the tricky part- Lot's of hair pulling- have to tick the ack!
     Set Sck
     Reset Sck
     Shiftin Datain , Sck , Databyte , 1                        'get the LSB
     Shift Datavalue , Left , 8
     Datavalue = Datavalue Or Databyte
     'don't tick the clock or ack since we don't need the CRC value, leave it hanging!
     Dataword = Datavalue
     Ddrb = &B11111111
     Reset Dataout
     Set Sck
     Reset Sck
     Shiftin Datain , Sck , Databyte , 1                        'not using the CRC value for now- can't figure it out! Anybody know how to impliment?
     'Print "CRC value was - " ; Databyte
     Ddrb = &B11111111
     Set Dataout
     Set Sck
     Reset Sck
    End Sub
    End
    End
    Hat diesen Sensor vielleicht schonmal jemand erfolgreich ausgewertet?
    Vielen Dank
    Marten83
    Ichtershausen
    Bis jetzt noch nicht, aber ich habe mir mal ein Muster bestellt und will das in den nächsten Tagen mal testen. Da er sich nicht mit dem I²C Protokoll verträgt muss ich da noch etwas an meiner Schaltung herum bauen, da der SHT11 nicht an den I²C-bUs des AVR passt.
    hallo
    na so ein zufall
    hab heut meinen sht75 in betrieb genommen.
    konnte aber keine starken schwankungen wahrnehmen
    hab schon dazu in https://www.roboternetz.de/phpBB2/vi...=306344#306344
    gepostet!
    @darxon
    hast du dir ein gratis muster bestellt oder wie?!
    wollt mir auch ein paar gratis pca8574 über nxp bestellen aber irgendwie kenn ich mich da nicht aus ob das auch nach österreich funktioniert.
    piri
    meine aktuellen Projekte
    Sternenhimmel
    http://www.roboternetz.de/phpBB2/viewtopic.php?t=31439
    BuBoter - Roboter mit Antikolision
    http://www.roboternetz.de/phpBB2/viewtopic.php?t=31632
    Ichtershausen
    Ja ich habe ein Gratis ;uster bestellt. HAbe es aber über die Firma gemacht. Da wittert man bei Sensirion immer das größe Geschäft und liefert prompt.
