Thema: ATtiny 2313 Einstellung
    in der Bascom Samples ist ein VU Meter mit Bargraphanzeige
    zu finden. Leider noch mit ein AT90S2313 declariert.
    Der ATtiny2313 will nicht mit den Einstellungen.Ich nehme mal an
    der Comperator muss neu definiert werden.
    Wie kriege ich den Code zum laufen
    'name                     : BG30dB_LED.bas
    'copyright                : (c) 1995-2005, MCS Electronics
    'purpose                  : create a logarithmic LED bar graph dB (VU) meter
    'micro                    : AT90S2313-10
    'suited for demo          : yes
    'commercial addon needed  : no
    'use in simulator         : possible
    ' Author     : Ger langezaal
    '---[ Small program description ]-----------------------------------------------
    ' This program is written to create a logarithmic LED bar graph dB (VU) meter
    ' with peak-hold and drop-down. Scale range is 30dB in 3dB steps.
    ' Log conversion is done with the analog comparator on a RC discharge curve.
    ' C1 is charged each 4mS with PB0 as output on a Timer0 Interrupt.
    ' Then PB0 is set to AIN0 (analog comparator +input) Timer1 is reset
    ' and start counting, C1 will be discharged by R1.
    ' Timer1 is counting until AIN0 < AIN1.
    ' Analog Comparator Output = ACSR bit 5.
    ' Timer1 value is in T1 stored for calculation.
    ' Display mode is set with PD6 (pin 11).
    '   1 = bar mode
    '   0 = dot mode  (for low current applications)
    '---[ LED to AVR connections ]--------------------------------------------------
    '     AVR      Resistor   Cathode   dB
    '  Port pin      Ohm      LED nr   Scale
    '  PD5   9   >--[680]-->   11       +6
    '  PD4   8   >--[680]-->   10       +3
    '  PD3   7   >--[680]-->    9        0
    '  PD2   6   >--[680]-->    8       -3
    '  PD1   3   >--[680]-->    7       -6
    '  PD0   2   >--[680]-->    6       -9
    '  PB7  19   >--[680]-->    5      -12
    '  PB6  18   >--[680]-->    4      -15
    '  PB5  17   >--[680]-->    3      -18
    '  PB4  16   >--[680]-->    2      -21
    '  PB3  15   >--[680]-->    1      -24
    '  PB2  14   >--[680]-->    0     infinit
    ' All LED Anodes to +5 Volt
    '---[ Analog comparator inputs ]------------------------------------------------
    '  Meter DC input >-------[ R2 ]-------> PB1 (AIN1 pin 13)
    '             GND <---------||-----
    '                           C2
    '                      ---[ R1 ]---
    '             GND <----|          |----> PB0 (AIN0 pin 12)
    '                           C1
    ' R1 = 10k 5%
    ' R2 = 10k
    ' C1 = 47nF 5%
    ' C2 = 47nF
    '---[ DC input versus Timer1 and Led position ]---------------------------------
    ' Measured Timer1 values for calculation:
    ' DC input = 3500mV  Timer1 =  192   ( +6dB)
    ' DC input =  312mV  Timer1 = 1544   (-15dB)   21dB = factor 11.22
    ' 21dB = 1543 - 192 = 1351 Timer1 counts
    '  3dB = 1351 / 7 = 193 Timer1 counts
    '  Input mv    Timer1   LED pos  dB scale
    '    3500        192      11       +6
    '    2477        385      10       +3
    '    1753        578       9        0
    '    1241        771       8       -3
    '     879        965       7       -6
    '     622       1158       6       -9
    '     440       1351       5      -12
    '     312       1544       4      -15
    '     220       1737       3      -18
    '     156       1930       2      -21
    '     110       2123       1      -24
    '    <110      >2123       0     infinit
    '---[ Compiler and hardware related statements ]--------------------------------
    $regfile = "2313def.dat"                                    'register file for AT90S2313
    $crystal = 10000000                                         '10MHz crystal
    $hwstack = 32                                               ' default use 32 for the hardware stack
    $swstack = 10                                               'default use 10 for the SW stack
    $framesize = 40                                             'default use 40 for the frame space
    Ddrb = &B11111100                                           'PB0 and PB1 are analog inputs
    Portb.0 = 0                                                 'disable input pullup
    Portb.1 = 0                                                 'disable input pullup
    Ddrd = &B10111111                                           'config PD6 as input
    Portd = &B11111111                                          'output high and enable input pullup
    Acsr.7 = 0                                                  'enable analog comparator ACSR bit 7 = 0
    '---[ Variables ]---------------------------------------------------------------
    Dim Peak_pos As Byte
    Dim Peak_hold As Byte
    Dim Drop_hold As Byte
    Dim Led_pos As Word
    Dim Bar_pattern As Word
    Dim T1 As Word
    '---[ Constants ]---------------------------------------------------------------
    Const Peak_hold_time = 200
    Const Drop_down_time = 40
    Const Led_max = 11                                          'Led 0 - 11
    Const T1_fs = 192                                           'full scale Timer1 value
    Const T1_step = 193                                         '3dB step Timer1 value
    Const T1_range = T1_step * Led_max + T1_fs                  'Calculate Timer1 range
    Displ_mod Alias Pind.6                                      'display mode 1 = Dot 0 = Bar
    Ac_out Alias Acsr.5                                         'analog comparator output = ACSR bit 5
    '---[ Timer Configuration ]-----------------------------------------------------
    Config Timer0 = Timer , Prescale = 256                      'On Interrupt Timer
    Config Timer1 = Timer , Prescale = 8                        'R/C Timer
    Config Watchdog = 1024                                      'reset after 1 Sec no reset watchdog
    Enable Interrupts
    Enable Timer0
    Enable Timer1
    On Timer0 Dc_input_sample                                   'on overflow timer0 jump to label
    Timer0 = 0
    Timer1 = 0
    Start Timer0
    Start Timer1
    anbei mal den "kopf" des Code's
    Ist ja in den Samples zu finden
    Wigbert
    Bei mir kompiliert Bascom es, wenn ich bei $regfile = "ATtiny2313.DAT" eintrage.
    Was läuft denn nicht?
    Wenn das Herz involviert ist, steht die Logik außen vor! \/
    naja, und die Fuses mußt du logischerweise auf externen Quarz setzen...
    Bei mir kompiliert Bascom es auch mit
    "attiny2313.dat"Sorry, hätte ich hinschreiben können
    Das ist ja das Problem. Sim. auch nichts zu sehen
    aber es leuchtet keine LED bei NF am Eingang
    Mit dem AT90S2313 alles Wunderbar,richtiges "Mäusekino"
    Der Tiny taktet auch mit 10 Mhz. Also Fuse richtig.(Haken in Sut0)
    Die Pins sind doch identisch. Zig mal so gemacht.
    Dieses Rgister setzen:
    Acsr.7 = 0
    'enable analogcomparatorACSR bit 7 = 0
    Ac_out Alias Acsr.5
    können die so bleiben.Kann im DBL nichts negatives erkennen.
    Wigbert
    ich habe festgestellt das der Watchdog mit den Tiny nicht funktioniert.
    Also mit dem AT90S2313 wird die Schleife regelmässig geresettet.
    Was der Tiny nicht macht.Was muss ich beim Tiny mit dem Watchdog
    machen.
    Wigbert
    Ich würde zu Testzwecken mal den Watchdog rausnehmen. Meinen M 644 bekomme ich nur mit Watchdog zum laufen, wenn ich am Anfang des Codes den Watchdog abschalte, denn dafür bleiben nur 4 Takte Zeit. Dann muss der Watchdog regelmäßig zurückgesetzt werden, wenn er aktiviert ist. Ich mache das immer in der Hauptschleife.
    $asm
    Wdt_off:
    ; Turn off global interrupt
    cli
    ; Reset Watchdog Timer
    wdr
    ; Clear WDRF in MCUSR
    in r16, MCUSR
    andi r16, wdrf;(0xff & (WDRF))
    Out Mcusr , R16
    ; Write logical one to WDCE and WDE
    ; Keep old prescaler setting to prevent unintentional time-out
    in r16, WDTCSR
    ori r16,wdce; (1<<WDCE) | (1<<WDE)
    Out Wdtcsr , R16
    ; Turn off WDT
    ldi r16,wde; (0<<WDE)
    Out Wdtcsr , R16
    $end Asm
    Watchdog initialisierung beim Mega 644.
    Der Watchdog ist es wohl auch nicht.
    Ich hab ihn mal komplett raus genommen und der AT90S2313
    resettet sich immer noch regelmäßig.
    Der ATtiny läuft einfach durch. Kann ich das irgendwie Debuggen?
    Wie sehe ich ob Timer arbeiten?
    Es ist zum Kotz...
    Wigbert
    Hallo Leute,
    hab den Fehler gefunden. Der Attiny kennt den Befehl:
    'Start Timer0
    'Start Timer1
    nicht
    und muss entfernt werden
    peterfido dank dir für den Code.
    Wigbert
