So mein Odometrietest geht jetz endlich. Es kommt aber etwas net so gutes bei raus.
Was könnte das bedeuten? Eingebaut müssten beide richtig sein. Bobbenach außen, rot = Diode 13&14, weiß = Transistor 11&12.Code:+00113 +00114 -Finished- KCKCKCKCKCKCKCKCKCK LoggingOdometers V1.0 (2006-05-21, Arexx-Henk) Left Odometer +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +0011 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +0011 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 Right Odometer +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +0011 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +0011 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 +00116 Left min/max, right min/max values +00116 +00116 +00116 +00116 -Finished-
Es können doch nicht beide kapput sein.
Hat jemand ne Idee nach was man noch kucken könnte. Alles was in der Anleitung steht habe ich schon geprüft.
Zitieren
Lesezeichen
