Ergebnis 1 bis 4 von 4
Thema: _ML16 Fehler
    _ML16 Fehler
    Hey Leute,
    ich bekomme beim Compilen immer einen Fehler mit _ML16
    "Label not found[_ML16" Was kann ich dagegen tun?
    Placa
    Schifferstadt
    ohne Code kann man da nicht viel dazu sagen. Den müsstest Du schon mit reinstellen.
    mfg Kay
    $regfile = "m168def.dat"
    $regfile = "M32def.dat" ' chip
    $crystal = 16000000 ' frequenz
    $baud = 19200 ' baud rate
    $hwstack = 32 ' default use 32 for the hardware stack
    $swstack = 10 ' default use 10 for the SW stack
    $framesize = 40 ' default use 40 for the frame space
    $lib "I2C_TWI.LBX"
    Config Scl = Portc.0 ' we need to provide the SCL pin name
    Config Sda = Portc.1 ' we need to provide the SDA pin name
    Config Twi = 100000 ' wanted clock frequency
    'Twbr = 12 'bit rate register 'will set TWBR and TWSR
    'Twsr = 0 'pre scaler bits
    Config Lcdpin = Pin , Db4 = Portb.3 , Db5 = Portb.2 , Db6 = Portb.1 , Db7 = Portb.0 , E = Portb.5 , Rs = Portb.7 ' Pinbelegung "LCD-Port)"
    Config Lcd = 20 * 4a , Chipset = Ks077 ' LCD 204 DIP 20x4
    'Config Lcd = 16 * 2 , Chipset = Dogm163v5 , Contrast = &H702 ' EA DOGM162W-A
    Config Portb = Output
    Config Lcdbus = 4
    Config Portc.6 = Output 'Toggle bei jeder Messung die LED C.6
    Config Portc.7 = Output 'Temperatur unter 0 °C LED C.7
    '******************************* VARIABLES *******************************'
    Dim ___lcdno As Bit
    Dim I2c_byte As Byte
    Dim Loops1 As Byte
    Dim Count As Byte
    Dim Slope As Byte
    Dim Temp1 As Integer
    Dim Temp2 As Integer
    Dim Temp3 As Integer
    Dim Temp_cor As Integer
    Dim Temp3_s As String * 16
    Dim Temp_c As Integer
    Dim Ds1621_i2c_address As Integer
    Dim Ds1621_i2c_r_address As Integer
    Config I2cdelay = 800
    Initlcd
    Deflcdchar 1 , 3 , 3 , 32 , 32 , 32 , 32 , 32 , 32 ' replace ? with number (0-7)
    Cls
    Cursor Off Noblink 'hide cursor
    '******************************** PROGRAM ********************************'
    '***** Innen
    Temp_c_loop:
    Ds1621_i2c_address = 144
    Ds1621_i2c_r_address = 145
    Temp_cor = 0
    Gosub Get_ds1621_temperature
    Print "oben"
    Print "Temp1" ; " " ; Temp1 ; " " ; "Temp2" ; " " ; Temp2 ; " " ; "Temp3" ; " " ; Temp3 ; " " ; "Temp_c" ; " " ; Temp_c 'Test auf das Terminal
    Print " "
    Temp1 = Temp_c / 10 'get hundreds tens ones xxx,'
    Temp1 = Abs(temp1)
    Temp2 = Temp_c / 10 'get 1/10 ,x'
    Temp2 = Temp2 * 10
    Temp2 = Temp_c - Temp2
    Temp2 = Abs(temp2)
    Temp3 = Temp1 * 10
    Temp3 = Temp3 + Temp2
    Temp3 = Temp3 + Temp_cor ' fuer den Korrekturfaktor
    Temp3_s = Str(temp3) ' der Formatbefehl erfordert einen String
    Toggle Portc.6 'Toggle bei jeder Messung
    Locate 1 , 1
    If Temp_c < 0 Then Lcd "-"; 'print "-" if temp_c is negative'
    Locate 1 , 2
    Lcd Format(temp3_s , "00.0") ; Chr(1) ; "C Innen" 'print xxx.x C Wohnraum'
    Print "unten"
    Print " "
    Wait 1
    'Goto Temp_c_loop ' nur bei einer Temperatur
    '***** Aussen
    'Temp_c_loop:
    Ds1621_i2c_address = 146
    Ds1621_i2c_r_address = 147
    Temp_cor = 0
    Temp1 = Abs(temp1)
    Temp2 = Temp2 * 10
    Temp2 = Abs(temp2)
    Temp3 = Temp1 * 10
    Temp3 = Temp3 + Temp2 ' fuer den Korrekturfaktor
    Locate 2 , 1
    Locate 2 , 2
    If Temp1 < 10 Then
    Lcd " " ; Format(temp3_s , "0.0") ; Chr(1) ; "C Aussen" ' unter 10 C print x.x C Aussen'
    Else ' über 10 C print xx.x C Aussen'
    Lcd Format(temp3_s , "00.0") ; Chr(1) ; "C Aussen"
    End If
    'Print "Temp1" ; " " ; Temp1 ; " " ; "Temp2" ; " " ; Temp2 ; " " ; "Temp3" ; " " ; Temp3 'Test auf das Terminal
    Wait 1
    Goto Temp_c_loop
    '****************************** SUBROUTINES ******************************'
    Get_ds1621_temperature:
    For Loops1 = 1 To 2
    Ds1621_start_convert:
    I2cstart
    I2cwbyte Ds1621_i2c_address
    I2cwbyte &HEE
    I2cstop
    Waitms 25
    Ds1621_check_conversion_done:
    I2cstart
    I2cwbyte &HAC
    I2cstop
    Waitms 25
    I2cstart
    I2cwbyte Ds1621_i2c_r_address
    I2crbyte I2c_byte , Nack
    I2cstop
    Waitms 25
    Temp1 = I2c_byte And 1
    Temp2 = I2c_byte And 128
    If Temp1 = 1 Then If Temp2 = 128 Then Goto Ds1621_check_conversion_done
    Ds1621_read_temp:
    I2cstart
    I2cwbyte &HAA
    I2cstop
    Waitms 25
    I2cstart
    I2crbyte Temp_c , Nack
    If Temp_c > 127 Then Temp_c = Temp_c + &HFF00
    Temp_c = Temp_c * 100
    Ds1621_read_count:
    I2cstart
    I2cwbyte &HA8
    I2cstop
    Waitms 25
    I2cstart
    I2crbyte Count , Nack
    I2cstop
    Waitms 25
    Ds1621_read_slope:
    I2cstart
    I2cwbyte &HA9
    I2cstop
    Waitms 25
    I2cstart
    I2crbyte Slope , Nack
    I2cstop
    Waitms 25
    Temp1 = Count * 100
    Temp2 = Slope * 100
    Temp2 = Temp2 - Temp1
    Temp1 = Temp2 / Slope
    Temp_c = Temp_c - 25
    Temp_c = Temp_c + Temp1
    Temp_c = Temp_c / 10 'get rid of last digit xxxxx becomes xxxx'
    I2cstop
    Next
    Return
    Das ist der Code, ist für die Abfrage des Temp Sens auf i2c. Ist aus nem anderen Thread. Habe gelesen das hat was mit der mcs lib zu tun. Könnte die jemand vllt uppen?
    Placa
    Kann niemand seine MCS.LBX für mich hochladen aus dem Lib Ordner? Würde mich freuen sonst komm ich leider nicht weiter! Danke
    Placa
