Ergebnis 1 bis 3 von 3
Thema: DS18S20 -> 850 Grad Celsius ???
    Schifferstadt
    habe einen DS18S20 an Portb.0 meines mega32 hängen. Folgendes Programm gibt mir als Temperatur immer 850 aus:
    '--- Controller ---
    $regfile = "m32def.dat"
    $crystal = 16000000
    $baud = 4800
    $hwstack = 32
    $swstack = 10
    $framesize = 40
    '--- Grafikroutine ---
    $lib "glcdKS108.lib"
    '--- DS18S20 ---
    Config 1wire = Portb.0
    '--- Declare Subs ---
    Declare Sub Init
    Declare Sub Convallt
    Declare Function Decigrades(byval Sc(9) As Byte) As Integer
    '--- Dims ---
    Dim B As Byte
    Dim W As Word
    Dim Dg As Integer
    Dim Min1 As Integer
    Dim Min2 As Integer
    Dim Max1 As Integer
    Dim Max2 As Integer
    Dim Dsid1(8) As Byte
    Dim Sc(9) As Byte
    '--- Grafikdisplay ---
    Config Graphlcd = 128 * 64sed , Dataport = Porta , Controlport = Portc , Ce = 1 , Ce2 = 0 , Cd = 2 , Rd = 3 , Reset = 4 , Enable = 5
    Cls
    Showpic 0 , 0 , Lcdblank
    Setfont Font6x8
    Lcdat 2 , 32 , "Sensorcheck"
    Line(0 , 20) -(128 , 20 ) , 1
    Wait 1
    '--- Sensor ---
    Setfont Kayfont5x5
    Dsid1(1) = 1wsearchfirst()
    If Dsid1(8) = Crc8(dsid1(1) , 7) Then
       Lcdat 4 , 2 , "CRC OK Sensor"
       Wait 1
       For B = 1 To 8
          Lcdat 5 , 2 , Hex(dsid1(b))
       Next
    End If
    '--- Main Hauptprogramm ---
    Main:
     Call Convallt                                              ' "Convert ALL T on the 1w-bus"
      Waitus 200 : Waitus 200 : Waitus 200 : Waitus 200         'if you use 2-wire, could be reduced to 200us
      1wverify Dsid1(1)                                         'Issues the "Match ROM "
      Locate 1 , 1
      If Err = 1 Then
        Lcdat 6 , 2 , "Err "                                    'Err = 1 if something is wrong
      Elseif Err = 0 Then                                       'lcd " Sensor found"
        1wwrite &HBE
        Sc(1) = 1wread(9)                                       'read bytes into array
        If Sc(9) = Crc8(sc(1) , 8) Then
           Dg = Decigrades(sc(9))
           Lcdat 7 , 2 , Dg
        End If
      End If
      Wait 1
    Goto Main
    '--- Temperatur konvertieren ---
    Sub Convallt
       1wreset                                                  ' reset the bus
       1wwrite &HCC                                             ' skip rom
       1wwrite &H44                                             ' Convert T
    End Sub
    '--- Funktion zum auslesen des Temperatursensors ---
    Dim Tmp As Byte , T As Integer , T1 As Integer
       Tmp = Sc(1) And 1                                        ' 0.1C precision
          If Tmp = 1 Then Decr Sc(1)
          T = Makeint(sc(1) , Sc(2))
          'Print Hex(t)
          'Print T
          T = T * 50                                            'here we calculate the 1/10 precision like
          T = T - 25                                            'DS18S20 data sheet
          T1 = Sc(8) - Sc(7)
          T1 = T1 * 100
          T1 = T1 / Sc(8)
          T = T + T1
          Decigrades = T / 10
    'As integer, this routine gives T*10, with 1/10 degree precision
    End Function
    '--- Includes ---
    $include "kayfont5x5.font"
    $include "font6x8.font"
    '--- Bilder ---
    Lcdblank:
    $bgf "lcdblank.bgf"
    Die ID bekomme ich angezeigt. Hab 2 DS18S20 ausprobiert. Am Datenausgang habe ich einen 4,7k Pullup. Vielleicht sitz ich ja auch nur auf der Leitung. Vielleicht kann mir ja jemand von Euch helfen.
    mfg Kay
    Schifferstadt
    also ich bin jetzt soweit, das ich auf die Hardware tippe. Habe gerade noch 2 andere Codes probiert und ich erhalte immer 850. Aber was kann man Hardwaremäßig falsch machen ? Pullup is dran. +5V und GND is dran.
    mfg Kay
    Schifferstadt
    hat sich geklärt. Habe 2 DS18S20P erhalten. Die gehen nur mit Parasite Power. Werde mir morgen mal 2 normale holen.
    mfg Kay
