Ergebnis 1 bis 6 von 6
Thema: RP6Loader streikt!
    RP6Loader streikt!
    meine Fehlermeldung die ich erhalte, wenn ich den rp6loader starten will
    was kann ich dagegen tun?
    Jemand ne Idee?
    RP6Loader log file
    SystemLogger started at: Thu Apr 10 12:25:07 CEST 2008 (1207823107881)
    JVM System Information:
    java.runtime.name	=	Java(TM) SE Runtime Environment
    sun.boot.library.path	=	C:\Programme\Java\jre1.6.0_05\bin
    java.vm.version	=	10.0-b19
    java.vm.vendor	=	Sun Microsystems Inc.
    java.vendor.url	=	http://java.sun.com/
    path.separator	=	;
    java.vm.name	=	Java HotSpot(TM) Client VM
    file.encoding.pkg	=	sun.io
    sun.java.launcher	=	SUN_STANDARD
    user.country	=	DE
    sun.os.patch.level	=	Service Pack 2
    java.vm.specification.name	=	Java Virtual Machine Specification
    user.dir	=	C:\RP6Loader
    java.runtime.version	=	1.6.0_05-b13
    java.awt.graphicsenv	=	sun.awt.Win32GraphicsEnvironment
    java.endorsed.dirs	=	C:\Programme\Java\jre1.6.0_05\lib\endorsed
    os.arch	=	x86
    java.io.tmpdir	=	C:\DOKUME~1\ANTIVA~1\LOKALE~1\Temp\
    line.separator	=
    java.vm.specification.vendor	=	Sun Microsystems Inc.
    user.variant	=
    os.name	=	Windows XP
    sun.jnu.encoding	=	Cp1252
    java.library.path	=	C:\WinAVR-20071221\bin;C:\WinAVR-20071221\utils\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;\bin;.\lib
    java.specification.name	=	Java Platform API Specification
    java.class.version	=	50.0
    sun.management.compiler	=	HotSpot Client Compiler
    os.version	=	5.1
    user.home	=	C:\Dokumente und Einstellungen\antivalent
    user.timezone	=	Europe/Berlin
    java.awt.printerjob	=	sun.awt.windows.WPrinterJob
    file.encoding	=	Cp1252
    java.specification.version	=	1.6
    java.class.path	=	C:\RP6Loader\RP6Loader_lib.jar
    user.name	=	antivalent
    java.vm.specification.version	=	1.0
    java.home	=	C:\Programme\Java\jre1.6.0_05
    sun.arch.data.model	=	32
    user.language	=	de
    java.specification.vendor	=	Sun Microsystems Inc.
    awt.toolkit	=	sun.awt.windows.WToolkit
    java.vm.info	=	mixed mode, sharing
    java.version	=	1.6.0_05
    java.ext.dirs	=	C:\Programme\Java\jre1.6.0_05\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
    sun.boot.class.path	=	C:\Programme\Java\jre1.6.0_05\lib\resources.jar;C:\Programme\Java\jre1.6.0_05\lib\rt.jar;C:\Programme\Java\jre1.6.0_05\lib\sunrsasign.jar;C:\Programme\Java\jre1.6.0_05\lib\jsse.jar;C:\Programme\Java\jre1.6.0_05\lib\jce.jar;C:\Programme\Java\jre1.6.0_05\lib\charsets.jar;C:\Programme\Java\jre1.6.0_05\classes
    java.vendor	=	Sun Microsystems Inc.
    file.separator	=	\
    java.vendor.url.bug	=	http://java.sun.com/cgi-bin/bugreport.cgi
    sun.io.unicode.encoding	=	UnicodeLittle
    sun.cpu.endian	=	little
    sun.desktop	=	windows
    sun.cpu.isalist	=	pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
    JVM Memory Information:
    Free: 4149880 (4052 Kb)
    Max: 66650112 (65088 Kb)
    Total: 5177344 (5056 Kb)
    Global->Init
    RP6Loader Version: 1.1c
    Last build: 25.05.2007
    Global->loadConfig
    Global->loadLocalizedText
    Global->loadBoardLibrary
    Linkage error (Thu Apr 10 12:25:08 CEST 2008) : Could not load D2XX libraries!
    Is the driver installed properly and the correct JD2XX.dll file in the RP6Loader ./lib folder?
    java.lang.UnsatisfiedLinkError: C:\RP6Loader\lib\JD2XX.dll: Can't find dependent libraries
    	at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    	at java.lang.ClassLoader.loadLibrary0(Unknown Source)
    	at java.lang.ClassLoader.loadLibrary(Unknown Source)
    	at java.lang.Runtime.loadLibrary0(Unknown Source)
    	at java.lang.System.loadLibrary(Unknown Source)
    	at jd2xx.JD2XX.<clinit>(JD2XX.java:534)
    	at cls.c.<init>(Unknown Source)
    	at cls.Y.e(Unknown Source)
    	at cls.Y.<init>(Unknown Source)
    	at de.dsh.rp6loader.Init.<init>(Unknown Source)
    	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
    	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
    	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
    	at java.lang.reflect.Constructor.newInstance(Unknown Source)
    	at java.lang.Class.newInstance0(Unknown Source)
    	at java.lang.Class.newInstance(Unknown Source)
    	at de.dsh.rp6loader.Init.main(Unknown Source)
    ERROR (43)  ||| Loading D2XX Drivers failed!
    See RP6Loader_logfile.log for more details!
    RP6Loader will now try to use Comport mode!
    Loading D2XX Drivers failed! --> Trying to use RXTX instead!
    OS:W32
    Initializing native communication library: JD2XX
    Stable Library
    Native lib Version = RXTX-2.1-7
    Java lib Version   = RXTX-2.1-7
    TERMINAL: RP6Loader Terminal
    TERMINAL:  - type ".help" for command list!
    Global->loadFileList
    Global->Enabling log panel...
    RP6 Loader is ready to go.
    weit weg von nahe Bonn
    versuch mal was da steht
    jo das stimmt aber denke ich so
    bzw. wo kriege ich denn dieses file noch her?
    hm ... kenn mich mit RP6 nicht aus, liegt ne CD bei, such einfach dort mal oder installiers nochmal neu .. eventuell mangelt es auch an deiner java runtime
    Paderborn
    Du musst das *komplette* Archiv entpacken - nicht nur einzelne Dateien. Die Ordnerstruktur muss genau so bleiben wie im zip Archiv.
    Da ist diese Datei natürlich drin.
    Mfg;
    SlyD
    Frankfurt
    ich hatte bis eben gerade das selbe problem:
    Falls deins immernoch besteht, das hat bei mit geholfen:
    - Starte den Computer neu
    - Starte keine Programme die mit dem RP6 zutun haben
    - Stecke das USB Interface (nicht mit dem RP6 verbunden) in deinen Computer
    - Warte bis die Hardware installiert wurde (Merkt man an dieser Ballon Message unten rechts)
    - Starte den RP6 Loader
    Spanky
