hier ist die compilerausgabe, beim übersetzen des selftest_M32 programms (ich hoffe du meinst das hier):
aber ich glaube du hast mich falsch verstanden. das kompilieren sämtlicher programme funktioniert fehlerfrei, zumindest spuckt der compiler keine fehlermeldung aus.Code:> "make.exe" all -------- begin -------- avr-gcc (WinAVR 20080610) 4.3.0 Copyright (C) 2008 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Compiling: RP6Control_SELFTEST.c avr-gcc -c -mmcu=atmega32 -I. -gdwarf-2 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=RP6Control_SELFTEST.lst -I../../RP6Lib -I../../RP6Lib/RP6control -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6Control_SELFTEST.o.d RP6Control_SELFTEST.c -o RP6Control_SELFTEST.o Linking: RP6Control_SELFTEST.elf avr-gcc -mmcu=atmega32 -I. -gdwarf-2 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=RP6Control_SELFTEST.o -I../../RP6Lib -I../../RP6Lib/RP6control -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6Control_SELFTEST.elf.d RP6Control_SELFTEST.o ../../RP6Lib/RP6control/RP6ControlLib.o ../../RP6Lib/RP6common/RP6uart.o ../../RP6Lib/RP6common/RP6I2CmasterTWI.o --output RP6Control_SELFTEST.elf -Wl,-Map=RP6Control_SELFTEST.map,--cref -lm Creating load file for Flash: RP6Control_SELFTEST.hex avr-objcopy -O ihex -R .eeprom RP6Control_SELFTEST.elf RP6Control_SELFTEST.hex Creating Extended Listing: RP6Control_SELFTEST.lss avr-objdump -h -S RP6Control_SELFTEST.elf > RP6Control_SELFTEST.lss Creating Symbol Table: RP6Control_SELFTEST.sym avr-nm -n RP6Control_SELFTEST.elf > RP6Control_SELFTEST.sym Size after: AVR Memory Usage ---------------- Device: atmega32 Program: 7368 bytes (22.5% Full) (.text + .data + .bootloader) Data: 203 bytes (9.9% Full) (.data + .bss + .noinit) -------- end -------- > Process Exit Code: 0
ich programmiere ja auch schon länger mit dem RP6 und da hab ich bisher auch noch nie probleme mit dem compilieren gehabt.
das komplette hexfile schick ich dir per PM.
mfg andi
Zitieren
Lesezeichen
