Ergebnis 1 bis 10 von 25
Thema: Testprogramm läuft nicht
    habe jetzt einen RP6 und habe gleich mal ein kleines Testprogramm geschrieben, das aber nicht läuft.
    Hier mein Source-Code:
    #include "RP6RobotBaseLib.h"
    int main(void)
    	initRobotBase();
    	powerON();
    	char receiveBuffer[5];
    	receiveBytes(5);
    	waitUntilReceptionComplete();
    	copyReceivedBytesToBuffer(&receiveBuffer[0]);
    	if(receiveBuffer == "Hello")
    		writeString_P("Hi!\n");
    Und hier der Compiler-Output:
    > "C:\RP6Examples\RP6BASE_EXAMPLES\Test\\make_all.bat"
    C:\RP6Examples\RP6BASE_EXAMPLES\Test>set LANG=C
    C:\RP6Examples\RP6BASE_EXAMPLES\Test>make all
    -------- begin --------
    avr-gcc (GCC) 4.1.2 (WinAVR 20070525)
    Copyright (C) 2006 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    Compiling: Test.c
    avr-gcc -c -mmcu=atmega32 -I. -gdwarf-2 -DDEBUG_MEASURE_DUTY_CYCLE   -O -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=Test.lst -I../../RP6lib -I../../RP6lib/RP6base -I../../RP6lib/RP6common -std=gnu99 -MD -MP -MF .dep/Test.o.d Test.c -o Test.o
    Linking: Test.elf
    avr-gcc -mmcu=atmega32 -I. -gdwarf-2 -DDEBUG_MEASURE_DUTY_CYCLE   -O -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=Test.o -I../../RP6lib -I../../RP6lib/RP6base -I../../RP6lib/RP6common -std=gnu99 -MD -MP -MF .dep/Test.elf.d Test.o --output Test.elf -Wl,-Map=Test.map,--cref    -lm
    Test.o: In function `main':
    C:\RP6Examples\RP6BASE_EXAMPLES\Test/Test.c:5: undefined reference to `initRobotBase'
    C:\RP6Examples\RP6BASE_EXAMPLES\Test/Test.c:8: undefined reference to `receiveBytes'
    C:\RP6Examples\RP6BASE_EXAMPLES\Test/Test.c:9: undefined reference to `waitUntilReceptionComplete'
    C:\RP6Examples\RP6BASE_EXAMPLES\Test/Test.c:10: undefined reference to `copyReceivedBytesToBuffer'
    C:\RP6Examples\RP6BASE_EXAMPLES\Test/Test.c:13: undefined reference to `writeNStringP'
    make: *** [Test.elf] Error 1
    > Process Exit Code: 2
    > Time Taken: 00:03
    Zitat Zitat von Luki.B.
    Du hast aus versehen den Source Code statt dem Compilerout hingeschrieben.
    Ist editiert, danke für den Hinweis.
    Paderborn
    Ist in diesem Fall aber auch egal
    Das oben kann schon deswegen nicht so wie gedacht funktionieren, weil da überhaupt keine Endlosschleife im Code drin ist (s. Anleitung und Beispiele ).
    Weiterhin kannst Du keine Zeichenkette mit einer einfachen Bedingung wie "if(receiveBuffer == "Hello") " vergleichen.
    Das geht nur mit einzelnen Zeichen direkt.
    Eine Zeichenkette ist ein ARRAY mit Bytes (also quasi ein ganzer Haufen von Variablen) - Du kannst kein Array mit einem Array über "==" vergleichen - jedes Element muss einzeln mit dem entsprechenden anderen Element verglichen werden.
    Musst schon Funktionen wie strcmp verwenden (oder selbst duch das Array laufen... ).
    So in etwa:
    if(strcmp(receiveBuffer,"Hello")==0)
    // mach was...
    Hoffe das hilft Dir weiter, frag ruhig wenn noch was unklar ist.
    MfG,
    SlyD
    Der Source-Code sieht jetzt so aus:
    int main(void)
    	initRobotBase();
    	powerON();
    	while(true)
    		receiveBytes(5);
    Der Compiler-Output ist immernoch derselbe.
    btw: Wofür genau ist eigentlich die Endlosschleife gut? Ohne müsste das Programm doch normalerweisse auch laufen(Würde zwar nach einem Durchlauf abbrechen, aber laufen müsste es doch, oder?)
    Paderborn
    Ja eigentlich sollte es auch ohne laufen - aber der Programmzähler des Mikrocontrollers könnte dann einfach über den Reset des Programmspeichers laufen... wenn da noch überreste von alten Programmen vorhanden sind, kann sonstwas passieren.
    Die Fehlermeldungen vom Compiler deuten darauf hin das in Deinem Makefile was nicht richtig ist oder Du die Ordnerstruktur nicht so aufgebaut hast wie bei den Beispielprogrammen (die Relativposition der RP6Lib muss stimmen, sonst findet die der Compiler nicht (oder man passt das entsprechend im Makefile an) - zwei Verzeichnisebenen höher... )
    Hier mal ein Beispiel:
    http://www.arexx.com/rp6/downloads/R...t_template.zip
    (die Lib die hier dabei ist eine ALTE 2007er Version... die nicht mehr verwenden - muss ich mal updaten das Beispiel.)
    MfG,
    SlyD
    Also die Verzeichnisstruktur sieht bei mir so aus:
    C:\RP6Examples\
     -RP6BASE_EXAMPLES
      -Test
       -Test.c
       -makefile
       -make_all.bat
       -make_clean.bat
     -RP6CONTROL_EXAMPLES
     -RP6Lib
    Das Makefile sieht so aus:
    TARGET = Test
    RP6_LIB_PATH=../../RP6lib
    RP6_LIB_PATH_OTHERS= $(RP6_LIB_PATH)/RP6base $(RP6_LIB_PATH)/RP6common
    SRC = $(TARGET).c
    MCU = atmega32
    FORMAT = ihex
    ASRC=
    DEBUG =dwarf-2
    EXTRAINCDIRS = $(RP6_LIB_PATH) $(RP6_LIB_PATH_OTHERS)
    CSTANDARD = -std=gnu99
    CDEFS = -DDEBUG_MEASURE_DUTY_CYCLE
    CINCS =
    CFLAGS = -g$(DEBUG)
    CFLAGS += $(CDEFS) $(CINCS)
    CFLAGS += -O$(OPT)
    CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
    CFLAGS += -Wall -Wstrict-prototypes
    CFLAGS += -Wa,-adhlns=$(<:.c=.lst)
    CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
    CFLAGS += $(CSTANDARD)
    PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
    PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
    PRINTF_LIB =
    SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
    SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
    SCANF_LIB =
    MATH_LIB = -lm
    EXTMEMOPTS =
    LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
    LDFLAGS += $(EXTMEMOPTS)
    LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
    AVRDUDE_PROGRAMMER = stk500
    AVRDUDE_PORT = com1    # Programmer connected to serial device
    AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
    AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
    AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
    AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
    AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
    DEBUG_MFREQ = $(F_CPU)
    DEBUG_UI = insight
    DEBUG_BACKEND = avarice
    GDBINIT_FILE = __avr_gdbinit
    JTAG_DEV = /dev/com1
    DEBUG_PORT = 4242
    DEBUG_HOST = localhost
    SHELL = sh
    CC = avr-gcc
    OBJCOPY = avr-objcopy
    OBJDUMP = avr-objdump
    SIZE = avr-size
    NM = avr-nm
    AVRDUDE = avrdude
    REMOVE = rm -f
    REMOVEDIR = rmdir
    COPY = cp
    WINSHELL = cmd
    MSG_ERRORS_NONE = Errors: none
    MSG_BEGIN = -------- begin --------
    MSG_END = --------  end  --------
    MSG_SIZE_BEFORE = Size before:
    MSG_SIZE_AFTER = Size after:
    MSG_COFF = Converting to AVR COFF:
    MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
    MSG_FLASH = Creating load file for Flash:
    MSG_EEPROM = Creating load file for EEPROM:
    MSG_EXTENDED_LISTING = Creating Extended Listing:
    MSG_SYMBOL_TABLE = Creating Symbol Table:
    MSG_LINKING = Linking:
    MSG_COMPILING = Compiling:
    MSG_ASSEMBLING = Assembling:
    MSG_CLEANING = Cleaning project:
    OBJ = $(SRC:.c=.o) $(ASRC:.S=.o)
    LST = $(SRC:.c=.lst) $(ASRC:.S=.lst)
    GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d
    ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
    ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
    all: begin gccversion sizebefore build sizeafter end
    build: elf hex eep lss sym
    elf: $(TARGET).elf
    hex: $(TARGET).hex
    eep: $(TARGET).eep
    lss: $(TARGET).lss
    sym: $(TARGET).sym
    begin:
    	@echo
    	@echo $(MSG_BEGIN)
    end:
    	@echo $(MSG_END)
    	@echo
    HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
    ELFSIZE = $(SIZE) --format=avr --mcu=$(MCU) $(TARGET).elf
    sizebefore:
    	@if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
    	2>/dev/null; echo; fi
    sizeafter:
    	@if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
    gccversion :
    	@$(CC) --version
    program: $(TARGET).hex $(TARGET).eep
    	$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
    gdb-config:
    	@$(REMOVE) $(GDBINIT_FILE)
    	@echo define reset >> $(GDBINIT_FILE)
    	@echo SIGNAL SIGHUP >> $(GDBINIT_FILE)
    	@echo end >> $(GDBINIT_FILE)
    	@echo file $(TARGET).elf >> $(GDBINIT_FILE)
    	@echo target remote $(DEBUG_HOST):$(DEBUG_PORT)  >> $(GDBINIT_FILE)
    ifeq ($(DEBUG_BACKEND),simulavr)
    	@echo load  >> $(GDBINIT_FILE)
    endif
    	@echo break main >> $(GDBINIT_FILE)
    debug: gdb-config $(TARGET).elf
    ifeq ($(DEBUG_BACKEND), avarice)
    	@echo Starting AVaRICE - Press enter when "waiting to connect" message displays.
    	@$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
    	$(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
    	@$(WINSHELL) /c pause
    else
    	@$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
    	$(DEBUG_MFREQ) --port $(DEBUG_PORT)
    endif
    	@$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
    COFFCONVERT=$(OBJCOPY) --debugging \
    --change-section-address .data-0x800000 \
    --change-section-address .bss-0x800000 \
    --change-section-address .noinit-0x800000 \
    --change-section-address .eeprom-0x810000
    coff: $(TARGET).elf
    	@echo
    	@echo $(MSG_COFF) $(TARGET).cof
    	$(COFFCONVERT) -O coff-avr $< $(TARGET).cof
    extcoff: $(TARGET).elf
    	@echo
    	@echo $(MSG_EXTENDED_COFF) $(TARGET).cof
    	$(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
    %.hex: %.elf
    	@echo
    	@echo $(MSG_FLASH) $@
    	$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
    %.eep: %.elf
    	@echo
    	@echo $(MSG_EEPROM) $@
    	-$(OBJCOPY) -j .eeprom --set-section-flags .eeprom=alloc,load \
    	--change-section-lma .eeprom=0 --no-change-warnings -O $(FORMAT) $< $@ || exit 0
    %.lss: %.elf
    	@echo
    	@echo $(MSG_EXTENDED_LISTING) $@
    	$(OBJDUMP) -h -S $< > $@
    %.sym: %.elf
    	@echo
    	@echo $(MSG_SYMBOL_TABLE) $@
    	$(NM) -n $< > $@
    .SECONDARY : $(TARGET).elf
    .PRECIOUS : $(OBJ)
    %.elf: $(OBJ)
    	@echo
    	@echo $(MSG_LINKING) $@
    	$(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
    %.o : %.c
    	@echo
    	@echo $(MSG_COMPILING) $<
    	$(CC) -c $(ALL_CFLAGS) $< -o $@
    %.s : %.c
    	$(CC) -S $(ALL_CFLAGS) $< -o $@
    %.o : %.S
    	@echo
    	@echo $(MSG_ASSEMBLING) $<
    	$(CC) -c $(ALL_ASFLAGS) $< -o $@
    %.i : %.c
    	$(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@
    clean: begin clean_list end
    clean_list :
    	@echo
    	@echo $(MSG_CLEANING)
    include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
    .PHONY : all begin finish end sizebefore sizeafter gccversion \
    build elf hex eep lss sym coff extcoff \
    clean clean_list program debug gdb-config
    Paderborn
    Automatisch generiert?
    Nunja. In dem obigen Makefile hast Du bei src die C Dateien der RP6Lib nicht eingetragen. Den Rest hab ich mir nicht mehr angeschaut.
    Nimm am besten das aus dem oben verlinkten Zip Archiv und ändere da einfach den Namen von deinem Programm. Der Rest passt dann schon sofort.
    MfG,
    SlyD
    Hat funktioniert, Danke!
    Habe noch ein kleines Problem.
    Wenn ich folgendes Programm kompiliere, auf den Roboter lade und starte:
    int main(void)
    	initRobotBase();
    	powerON();
    	while(true)
    		writeString_P("Programm gestartet!\n");
    		receiveBytes(5);
    wird erstmal "Programm gestartet!" ausgegeben.
    Wenn ich allerdings "Hello" eingebe, gibt der Roboter nichts aus, er sollte aber "Hi!" ausgeben.
    Hallo 9999,
    die beste Art, eigene Programme für den RP6 zu schreiben ist, erst mal die Demos zu ändern mit eigenen Ideen.
    In der Demo "Example_02_UART_02" wird z.B. gezeigt, wie man eine Benutzereingabe machen kann und Text als Antwort ausgibt.
    Gruß Dirk
