- Modernes Energiemessgeraet
Ergebnis 1 bis 7 von 7
Thema: Fehler im Code?
    Fehler im Code?
    Halli Hallo
    Habe gerade versucht mit der neuen Lib etwas umzugehen jedoch gleich einen Fehler bekommen.. habe folgenden Code:
    #include "asuro.h"
    int main(void)
    int i;
    i = 0;
    Init();
    EncoderInit();
    while(i != 1){
    MotorDir(FWD,FWD);
    Go(500,255);
    i = i + 1;
    return 0;
    Und die Ausgabe ist:
    D:\Asuro\ASURO_src\EigeneSrc>make MCU=atmega8 LIBFILE=asuro
    set -e; avr-gcc -MM -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -ID:/Asuro/ASURO_SRC/AsuroLib/lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \
    [ -s asuro.d ] || rm -f asuro.d
    C:\Users\Matze\AppData\Local\Temp\make45522.sh: /c/WinAVR/bin/avr-gcc: Invalid argument
    set -e; avr-gcc -MM -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -ID:/Asuro/ASURO_SRC/AsuroLib/lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test.d; \
    [ -s test.d ] || rm -f test.d
    C:\Users\Matze\AppData\Local\Temp\make45523.sh: /c/WinAVR/bin/avr-gcc: Invalid argument
    -------- begin --------
    avr-gcc --version
    avr-gcc (GCC) 3.3.1
    Copyright (C) 2003 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    avr-gcc -c -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -ID:/Asuro/ASURO_SRC/AsuroLib/lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o
    avr-gcc -c -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -ID:/Asuro/ASURO_SRC/AsuroLib/lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c -o asuro.o
    avr-gcc -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -ID:/Asuro/ASURO_SRC/AsuroLib/lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.o test.o asuro.o --output test.elf -Wl,-Map=test.map,--cref -LD:/Asuro/ASURO_SRC/AsuroLib/lib -lm -lasuro
    C:\WinAVR\bin\..\lib\gcc-lib\avr\3.3.1\..\..\..\..\avr\bin\ld.exe: BFD 2.14 20030612 + coff-avr-patch (20030831) internal error, aborting at ../../bfd/reloc.c line 444 in bfd_get_reloc_size
    C:\WinAVR\bin\..\lib\gcc-lib\avr\3.3.1\..\..\..\..\avr\bin\ld.exe: Please report this bug.
    make: *** [test.elf] Error 1
    D:\Asuro\ASURO_src\EigeneSrc>pause
    Drcken Sie eine beliebige Taste . . .
    Worin liegt mein Fehler??
    MfG. mtzE
    die installierte software hat einen fehler, ist veraltet oder nicht richtig installiert.
    Hmm Problem gelöst.. hab mal ne neue Version von WinAVR installiert..
    kommt zwar jetzt immer noch ein Fehler.. Mit dem Errorcode: 128 aber die Hex Datei wird erstellt und ist voll funktionsfähig..
    MfG. mtzE
    Niederlanden
    ... Errorcode: 128
    Ich habe dieses gefunden in das Arexx forum:
    http://www.arexx.com/forum/viewtopic.php?t=704
    Wunderbar
    hat mir geholfen.. dankeschön!
    Hätte nicht gedacht das es an einer dll lag :P
    MfG. mtzE
    Stuttgart
    Sherlock Valen ;)
    Niederlanden
    Es hat mich auch bewundert das ich es so schnell gefunden habe. Und das es so in die nähe war, bei unsere sehr ge-ehrte Asuro Hersteller.
