Ja, lt. Datenblatt Independent or Common Mode
Zitat Datenblatt
Mode
The mode command changes the way the speed/turn values are used. The options being:
0, (Default Setting) If a value of 0 is written then the speed registers is literal speeds in the range of 0 (Full Reverse) 128 (Stop) 255 (Full Forward).
1, Mode 1 is similar to Mode 0, except that the speed values are interpreted as signed values. The range being -128 (Full Reverse) 0 (Stop) 127 (Full Forward).
2, Writing a value of 2 to the mode will make speed1 control both motors speed, and speed2 becomes the turn value.
Data is in the range of 0 (Full Reverse) 128 (Stop) 255 (Full Forward).
3, Mode 3 is similar to Mode 2, except that the speed values are interpreted as signed values.
Data is in the range of -128 (Full Reverse) 0 (Stop) 127 (Full Forward)
Zitieren
Lesezeichen
