Ergebnis 1 bis 3 von 3
Thema: ps2-tastatur am 644p....
    hallo, ich habe eine ps2-tastatur am 644p.
    funktioniert auch.
    wer kann mir das gedöns von den datazeilen mal erklären.
    ich kann es nicht enziffern, was das bedeuten kann.
    gruss
    $regfile = "m644pdef.dat"
    $crystal = 16000000
    $baud = 19200
    $hwstack = 32
    $swstack = 10
    $framesize = 40
    Config Keyboard = Pind.2 , Data = Pind.4 , Keydata = Keydata
    Dim S As String * 12
    Dim B As Byte
    $serialinput = Kbdinput
    Print "hello"
    B = Getatkbd()
    If B > 0 Then
       Print B ; Chr(b)
    End If
    End
    Kbdinput:
    $asm
    push r16           ; save used register
    push r25
    push r26
    push r27
    Kbdinput1:
    rCall _getatkbd   ; call the function
    tst r24           ; check for zero
    breq Kbdinput1     ; yes so try again
    pop r27           ; we got a valid key so restore registers
    pop r26
    pop r25
    pop r16
    $end Asm
    Return
    B = Getatkbd()
    Keydata:
    'normal keys lower case
    Data 0 , 0 , 0 , 0 , 0 , 200 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , &H5E , 0
    Data 0 , 0 , 0 , 0 , 0 , 113 , 49 , 0 , 0 , 0 , 122 , 115 , 97 , 119 , 50 , 0
    Data 0 , 99 , 120 , 100 , 101 , 52 , 51 , 0 , 0 , 32 , 118 , 102 , 116 , 114 , 53 , 0
    Data 0 , 110 , 98 , 104 , 103 , 121 , 54 , 7 , 8 , 44 , 109 , 106 , 117 , 55 , 56 , 0
    Data 0 , 44 , 107 , 105 , 111 , 48 , 57 , 0 , 0 , 46 , 45 , 108 , 48 , 112 , 43 , 0
    Data 0 , 0 , 0 , 0 , 0 , 92 , 0 , 0 , 0 , 0 , 13 , 0 , 0 , 92 , 0 , 0
    Data 0 , 60 , 0 , 0 , 0 , 0 , 8 , 0 , 0 , 49 , 0 , 52 , 55 , 0 , 0 , 0
    Data 48 , 44 , 50 , 53 , 54 , 56 , 0 , 0 , 0 , 43 , 51 , 45 , 42 , 57 , 0 , 0
    'shifted keys UPPER case
    Data 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0
    Data 0 , 0 , 0 , 0 , 0 , 81 , 33 , 0 , 0 , 0 , 90 , 83 , 65 , 87 , 34 , 0
    Data 0 , 67 , 88 , 68 , 69 , 0 , 35 , 0 , 0 , 32 , 86 , 70 , 84 , 82 , 37 , 0
    Data 0 , 78 , 66 , 72 , 71 , 89 , 38 , 0 , 0 , 76 , 77 , 74 , 85 , 47 , 40 , 0
    Data 0 , 59 , 75 , 73 , 79 , 61 , 41 , 0 , 0 , 58 , 95 , 76 , 48 , 80 , 63 , 0
    Data 0 , 0 , 0 , 0 , 0 , 96 , 0 , 0 , 0 , 0 , 13 , 94 , 0 , 42 , 0 , 0
    Data 0 , 62 , 0 , 0 , 0 , 8 , 0 , 0 , 49 , 0 , 52 , 55 , 0 , 0 , 0 , 0
    noch ein programm von hier :
    http://www.rn-wissen.de/index.php/PS/2_-_Schnittstelle
    ich muss hier ja für den 644p das gimsk ersetzen mit eimsk ("push r0:in r0,eimskush r0:disable int1 ) und dieses ( pop r0:!out eimsk,r0op r0)
    es werden nicht die tastendrücke angegeben, die ich drücke sondern ganz andere, die vom zahlenwert her nicht annähernd hinkommen.
    woran liegt der fehler in diesem bascom-musterprogramm?
    gruss
    Kehnert
    Ich betreibe eine PS/2-Tastatatur an einem Atmega8 in Bascom und muss
    ehrlich gesagt erwähnen, dass ich die Routine dafür auch im wesentlichen
    abgeschrieben habe, obwohl sie anders etwas aussieht, als bei Dir.
    Du und ich können erstmal sagen, dass es funktioniert. Das Wichtigste!
    Genau erschliesst sich mir die Funktion auch nicht, jedoch kann ich nur
    soviel sagen, dass der Tastaturcode GANZ ANDERS ist, als der ASC-Code,
    so dass eine Codewandlung gemacht werden muss, die dann in den
    DATA-Zeilen abgelegt ist. Hoffentlich sind meine Ausführungen richtig,
    ich denke hier gibts bestimmt Jemanden, der das gut ergänzen könnte.
    VG Micha
