Ergebnis 11 bis 19 von 19
Thema: Brauche bitte dringend ein Demo Programm
    ähh... sprache is egal right? ;P
    procedure TForm1.Timer1Timer(Sender: TObject);
    var
    sred:string;
    sgreen:string;
    sblue:string;
    begin
    if change then
    begin
      inc(count);
      if red.Position < 10 then sred := '00'+IntToStr(red.position);
      if (red.Position > 9) and (red.Position < 99) then sred := '0'+IntToStr(red.position);
      if red.Position > 99 then sred := IntToStr(red.position);
      if green.Position < 10 then sgreen := '00'+IntToStr(green.position);
      if (green.Position > 9) and (green.Position < 99) then sgreen := '0'+IntToStr(green.position);
      if green.Position > 99 then sgreen := IntToStr(green.position);
      if blue.Position < 10 then sblue := '00'+IntToStr(blue.position);
      if (blue.Position > 9) and (blue.Position < 99) then sblue := '0'+IntToStr(blue.position);
      if blue.Position > 99 then sblue := IntToStr(blue.position);
      port.WriteStr(sred+sgreen+sblue+#13#10);
      change := false;
    end;
    dann poste ich auch mal einen für den NIBObee^^
    #include <nibobee/iodefs.h>
    #include <nibobee/motpwm.h>
    #include <nibobee/delay.h>
    #include <nibobee/sens.h>
    enum {
    MODE_STOP,
    MODE_DRIVE,
    MODE_BACK,
    MODE_STEER_R,
    MODE_STEER_L,
    MODE_AVOID_R,
    MODE_AVOID_L
    int16_t speed_l;
    int16_t speed_r;
    uint16_t counter_ms;
    uint8_t perform_check(uint8_t mode);
    uint8_t do_stop();
    uint8_t do_drive();
    uint8_t do_back();
    uint8_t do_steer_r();
    uint8_t do_steer_l();
    uint8_t do_avoid_r();
    uint8_t do_avoid_l();
    int main() {
    motpwm_init();
    sens_init();
    uint8_t mode;
    while(1==1) {
    enable_interrupts();
    delay(1);
    mode = perform_check(mode);
    switch (mode) {
    case MODE_STOP: mode = do_stop(); break;
    case MODE_DRIVE: mode = do_drive(); break;
    case MODE_BACK: mode = do_back(); break;
    case MODE_STEER_R: mode = do_steer_r(); break;
    case MODE_STEER_L: mode = do_steer_l(); break;
    case MODE_AVOID_R: mode = do_avoid_r(); break;
    case MODE_AVOID_L: mode = do_avoid_l(); break;
    switch (mode) {
    case MODE_STOP: speed_l = 0; speed_r = 0;
    break;
    case MODE_DRIVE: speed_l = 500; speed_r = 500;
    break;
    case MODE_BACK: speed_l = -500; speed_r = -500;
    break;
    case MODE_STEER_R: speed_l = 600; speed_r = 400;
    break;
    case MODE_STEER_L: speed_l = 400; speed_r = 600;
    break;
    case MODE_AVOID_R: speed_l = -400; speed_r = -600;
    break;
    case MODE_AVOID_L: speed_l = -600; speed_r = -400;
    break;
    motpwm_setLeft(speed_l);
    motpwm_setRight(speed_r);
    return 0;
    uint8_t perform_check(uint8_t mode) {
    if (sens_getLeft() && sens_getRight()) {
    if ((sens_getLeft()==-1) && (sens_getRight()==-1)) {
    mode = MODE_BACK;
    } else {
    mode = MODE_STOP;
    return mode;
    uint8_t do_stop() {
    if ((sens_getLeft()==0) && (sens_getRight()==0)) {
    return MODE_DRIVE;
    return MODE_STOP;
    uint8_t do_back() {
    if (sens_getLeft()==0) {
    return MODE_AVOID_L;
    if (sens_getRight()==0) {
    return MODE_AVOID_R;
    return MODE_BACK;
    uint8_t do_drive() {
    if (sens_getRight()==1) {
    return MODE_STEER_L;
    if (sens_getLeft()==1) {
    return MODE_STEER_R;
    if (sens_getRight()==-1) {
    if (sens_getLeft()==-1) {
    return MODE_DRIVE;
    uint8_t do_steer_r() {
    return MODE_DRIVE;
    uint8_t do_steer_l() {
    return MODE_DRIVE;
    uint8_t do_avoid_r() {
    if (counter_ms==0) {
    counter_ms=1000;
    } else {
    counter_ms--;
    if (counter_ms) {
    } else {
    return MODE_DRIVE;
    uint8_t do_avoid_l() {
    counter_ms=1000;
    } else {
    counter_ms--;
    if (counter_ms) {
    } else {
    return MODE_DRIVE;
    Wenn ich das jetzt richtig gesehen habe, ist das K8055 keine wirkliche SPS, sondern eher eine Platine mit nem µC drauf. Kann man auch über USB anschließen. Wenn du die Platine mit einem Rechner steuern willst, brauchst du wohl eine Software für den µC und eine für den PC. Ansonsten halt nur die für den µC. Aber anscheinend sollte der ganze Thread wohl nur ein Scherz sein.
    Kevin
    So etwas dreistes gabs hier wirklich noch nicht... man man man.
    Ich habe eher so den Eindruck das er keine Ahnung davon hat was er sich da gekauft hat. Vielleicht wurde er auch nur gut Beraten.
    Grüsse Hubert
    ____________
    Ja, das sieht man schon an seinem anderen Thread, bei dem ihm auch nicht geholfen werden konnte weil es einfach nicht das richtige für sein Vorhaben ist!
    ich würd ihm ja empfehln das viech zurückzuschicken und sich ein arduino board zu kaufen
    dann wär er an einen nachmittag fertig
    Über google findet sich auch die Velleman Seite dazu: http://www.velleman.eu/distributor/p...g=en&id=351346
    Da gibts sogar ne Software fürs eiPhone.
    LabView Beispiele finden sich über Google z.B. auch, auf der CD sollen wohl auch Beispiele sein.
    Ja, der junge mann ist echt cccoooooool. Wahrscheinlich ist er noch nicht entwöhnt und Mama wischt noch den Popo ab.
    Gruß Richard
  1. !Vergeben! Kleines Demo-Programm in C
    Von squelver im Forum Jobs/Hilfen/Stellen - Gesuche und Angebote
    Antworten: 23
    Letzter Beitrag: 13.01.2010, 17:05
  2. Frage zu Demo-Programm
    Von Testman3000 im Forum Schaltungen und Boards der Projektseite Mikrocontroller-Elektronik.de
    Letzter Beitrag: 28.07.2007, 18:16
  3. Problem mit Demo Programm Asuro
    Von Petje im Forum Asuro
    Letzter Beitrag: 26.06.2007, 14:52
  4. Dringend/Notfall Teile!!! *Bitte!!...)
    Von PsiQ im Forum Elektronik
    Letzter Beitrag: 22.06.2006, 15:37
  5. Brauche dringend Hilfe zu Programm
    Von malius im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 01.06.2005, 22:47
