Thema: Problem bei Zeit+Tempsteuerung
    hallo,
    folgendes problem:
    nach start des programmes funktioniert alles ca 24 stunden, dann zeigt der display nix mehr an.
    hardware: c-control-station+I/O terminal
    code:
    'INTERFACE ZUM I/O TERMINAL
    define sdio         port[5]'1
    define sclio        port[6]'2
    define strobe       port[4]'3
    define light        port[3]
    '---- FUNCTION KEYS -------
    define FUNCTION1    port[9]
    define FUNCTION2    port[10]
    define FUNCTION3    port[11]
    define FUNCTION4    port[12]
    '------- LEDs -------------
    define LED1         port[13]
    define LED2         port[14]
    define LED3         port[15]
    define LED4         port[16]
    '--- BIN-DEZIMAL-CONVERTER ---
    define tausender           byte[1]
    define hunderter           byte[2]
    define zehner              byte[3]
    define einer               byte[4]
    '---- MINI LCD 2x8 --------
    define lcd_char      byte[13]
    define lcd_data      byte[14]
    define  CHAR         byte[15]
    '---- PORT TREIBER --------
    define LED_PORT      byte[16]
    define EXT_PORT      byte[17]
    define MASK          byte[18]
    '----- PROGRAMM ------------
    define value         byte[19]
    define temp1          byte[20]
    define temp2          byte[21]
    define key            byte[22]
    define digit     byte[23]
    define T_Boden        word[1]
    define value17       word[2]
    define gp           word[3]
    define value16       word[4]
    define zeit           word[5]
    define VORON         word[6]
    define VOROFF        word[7]
    define NACHON        word[8]
    define NACHOFF       word[9]
    define T_Wasser      word[10]
    define counter       word[11]
    define DUENG         word[12]
    'VormittagLicht
    '------ TEMP FÜHLER --------
    define T1           AD[5]
    define T2           AD[6]
    define KEY_VAL      AD[4]
    define YES ON
    define NO OFF
    '------ ABCD  ----------
    define A_ &HC1
    define B_ &HC2
    define C_ &HC3
    define D_ &HC4
    define E_ &HC5
    define F_ &HC6
    define G_ &HC7
    define H_ &HC8
    define I_ &HC9
    define J_ &HCA
    define K_ &HCB
    define L_ &HCC
    define M_ &HCD
    define N_ &HCE
    define O_ &HCF
    define P_ &HD0
    define Q_ &HD1
    define R_ &HD2
    define S_ &HD3
    define T_ &HD4
    define U_ &HD5
    define V_ &HD6
    define W_ &HD7
    define X_ &HD8
    define Y_ &HD9
    define Z_ &HDA
    define LEERZ &HA0
    define MINUS &HAD
    define NULL &HB0
    define EINS &HB1
    define ZWEI &HB2
    define DREI &HB3
    define VIER &HB4
    define FUENF &HB5
    define SECHS &HB6
    define SIEBEN &HB7
    define ACHT &HB8
    define NEUN &HB9
    define GLEICH &HBD
    define DOPPELPUNKT &HBA
    define PUNKT &HAE
    define GRAD &HDF
    define FRAGEZ &HAF
    define STERN &HAA
    T_Boden = 200
    T_Wasser = 290
    'IIIIIIIIIIIII INITIALISIERUNG IIIIIIIIIIIIIIIIIIIII
    strobe=off:light=on:LED_PORT=255:EXT_PORT=0:gosub write_ports:gosub clear_display
    gosub lcd2x8_init:light=on
    gosub begruessung:pause 50
    gosub clear_display
    'IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
    'IIIIIIIIIIIIIII PROGRAMM START IIIIIIIIIIIIIIIIIIII
    #MAINLOOP
    gosub show_time:pause 100
    gosub schalt
    gosub tempsteuerung1:gosub tempsteuerung2:gosub tempanzeige1:gosub tempanzeige2
    pause 5
    goto MAINLOOP
    'IIIIIIIIIIIIIII PROGRAMM ENDE  IIIIIIIIIIIIIIIIIIII
    'ZEITABFRAGE
    #schalt
      if TAGAN then gosub 1on
      if NACHMITTAGAN then gosub 1on
      if NACHTAN then gosub 4on
      if DUENGERAN then gosub Duenger
    return
    #TAGAN
    if ( HOUR > 8) and ( HOUR<  12) then return YES else return NO
    #NACHMITTAGAN
    if ( HOUR > 13 ) and ( HOUR< 21 )then return YES else return NO
    #NACHTAN
    if (HOUR > 21) or ( HOUR < 8 ) then return YES else return NO
    #DUENGERAN
    if ( HOUR = 12 )and ( SECOND = 0)  then return YES else return NO
    #tempsteuerung1
    looktab ttab1, T1, value16
    value16=value16-80
    if value16 < T_Boden then gosub 2on else gosub 2off
    return
    #tempsteuerung2
    looktab ttab1, T2, value17
    value17=value17-80
    if value17 < T_Wasser then gosub 3on else gosub 3off
    return
    #tempanzeige1
    gosub setline1
    lcd_char=T_:gosub write_char
    lcd_char=EINS:gosub write_char
    lcd_char=&HA0:gosub write_char
    hunderter=value16/100:lcd_char=hunderter+&HB0:gosub write_char
    gp=hunderter*100
    zehner=(value16-gp)/10:lcd_char=zehner+&HB0:gosub write_char
    lcd_char=&HAC:gosub write_char:
    einer=value16-gp-(zehner*10):lcd_char=einer+&HB0:gosub write_char
    lcd_char=&HA0:gosub write_char:lcd_char=&HC3:gosub write_char:lcd_char=&HA0:gosub write_char
    return
    #tempanzeige2
    gosub setline2
    lcd_char=ZWEI:gosub write_char
    hunderter=value17/100:lcd_char=hunderter+&HB0:gosub write_char
    gp=hunderter*100
    zehner=(value17-gp)/10:lcd_char=zehner+&HB0:gosub write_char
    einer=value17-gp-(zehner*10):lcd_char=einer+&HB0:gosub write_char
    return
    #show_time
    gosub clear_display
    gosub setline1
    value=hour:gosub show_2_digits
    lcd_char =&HBA : gosub write_char
    value=minute:gosub show_2_digits
    value=second:gosub show_2_digits
    pause 100
    return
    #Duenger
    gosub 5on
    pause 20
    gosub 5off
    return
    'IIIIIIIIIIIII UNTERPROGRAMME IIIIIIIIIIIIIIIIIIIIIII
    #1off
    EXT_PORT=EXT_PORT and &HFE:goto write_ports
    #1on
    EXT_PORT=EXT_PORT or &H01:goto write_ports
    #2off
    EXT_PORT=EXT_PORT and &HFD:goto write_ports
    #2on
    EXT_PORT=EXT_PORT or &H02:goto write_ports
    #3off
    EXT_PORT=EXT_PORT and &HFB:goto write_ports
    #3on
    EXT_PORT=EXT_PORT or &H04:goto write_ports
    #4off
    EXT_PORT=EXT_PORT and &HF7:goto write_ports
    #4on
    EXT_PORT=EXT_PORT or &H08:goto write_ports
    #5off
    EXT_PORT=EXT_PORT and &HEF:goto write_ports
    #5on
    EXT_PORT=EXT_PORT or &H10:goto write_ports
    #6off
    EXT_PORT=EXT_PORT and &HDF:goto write_ports
    #6on
    EXT_PORT=EXT_PORT or &H20:goto write_ports
    #7off
    EXT_PORT=EXT_PORT and &HBF:goto write_ports
    #7on
    EXT_PORT=EXT_PORT or &H40:goto write_ports
    #8off
    EXT_PORT=EXT_PORT and &H7F:goto write_ports
    #8on
    EXT_PORT=EXT_PORT or &H80:goto write_ports
    'IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
    #1rton
    LED_PORT=LED_PORT and &HFE:goto write_ports
    #1rtoff
    LED_PORT=LED_PORT or &H01:goto write_ports
    #1gnon
    LED_PORT=LED_PORT and &HFD:goto write_ports
    #1gnoff
    LED_PORT=LED_PORT or &H02:goto write_ports
    #2rton
    LED_PORT=LED_PORT and &HFB:goto write_ports
    #2rtoff
    LED_PORT=LED_PORT or &H04:goto write_ports
    #2gnon
    LED_PORT=LED_PORT and &HF7:goto write_ports
    #2gnoff
    LED_PORT=LED_PORT or &H08:goto write_ports
    #3rton
    LED_PORT=LED_PORT and &HEF:goto write_ports
    #3rtoff
    LED_PORT=LED_PORT or &H10:goto write_ports
    #3gnon
    LED_PORT=LED_PORT and &HDF:goto write_ports
    #3gnoff
    LED_PORT=LED_PORT or &H20:goto write_ports
    #4gnon
    LED_PORT=LED_PORT and &HBF:goto write_ports
    #4gnoff
    LED_PORT=LED_PORT or &H40:goto write_ports
    #5gnon
    LED_PORT=LED_PORT and &H7F:goto write_ports
    #5gnoff
    LED_PORT=LED_PORT or &H80:goto write_ports
    #display_binary
    gosub setline1
    lcd_char=((value and &H80) shr 7)+&HB0:gosub write_char
    lcd_char=((value and &H40) shr 6)+&HB0:gosub write_char
    lcd_char=((value and &H20) shr 5)+&HB0:gosub write_char
    lcd_char=((value and &H10) shr 4)+&HB0:gosub write_char
    lcd_char=((value and &H08) shr 3)+&HB0:gosub write_char
    lcd_char=((value and &H04) shr 2)+&HB0:gosub write_char
    lcd_char=((value and &H02) shr 1)+&HB0:gosub write_char
    lcd_char=(value and &H01)+&HB0:gosub write_char
    return
    #begruessung' Aquarium '
    gosub setline1
    lcd_char=A_:gosub write_character
    lcd_char=Q_:gosub write_character
    lcd_char=U_:gosub write_character
    lcd_char=R_:gosub write_character
    lcd_char=I_:gosub write_character
    lcd_char=M_:gosub write_character
    return
    #time_msg ' Zeit '
    gosub setline1
    lcd_char=LEERZ:gosub write_char
    lcd_char=Z_:gosub write_char
    lcd_char=E_:gosub write_char
    return
    #grad ' GRAD'
    gosub setline1
    lcd_char=G_:gosub write_char
    lcd_char=D_:gosub write_char
    return
    '-------- I/O-TERMINAL PORT Treiber ---------
    #write_ports
    MASK=&H80
    #shift_mask1
    if MASK=0 then goto  write_ledport
    if (MASK and EXT_PORT)=0 then goto shift_lo1
    sdio=on:sclio=off:sclio=on:MASK=MASK shr 1:goto shift_mask1
    #shift_lo1
    sdio=off:sclio=off:sclio=on:MASK=MASK shr 1:goto shift_mask1
    #write_ledport
    MASK=&H80
    #shift_mask2
    if MASK=0 then goto exit_driver
    if (MASK and LED_PORT)=0 then goto shift_lo2
    sdio=on:sclio=off:sclio=on:MASK=MASK shr 1:goto shift_mask2
    #shift_lo2
    sdio=off:sclio=off:sclio=on:MASK=MASK shr 1:goto shift_mask2
    #exit_driver
    strobe=on:strobe=off:return
    '-------- I/O-TERMINAL LCD Treiber ----------
    #setline1
    lcd_char=&H84:goto mode_control
    #setline2
    lcd_char=&HC4:goto mode_control
    #clear_display
    lcd_char=&H01:goto mode_control
    #scroll_display_left
    lcd_char=&H18:goto mode_control
    #scroll_display_right
    lcd_char=&H1C:goto mode_control
    #write_character
    beep 368,1,0
    #write_char
    sclio=on:sdio=on:sdio=off:sclio=off
    lcd_data=&H74:gosub write_byte
    lcd_data=&H40:gosub write_byte
    lcd_data=lcd_char:gosub write_byte
    sdio=off:sclio=on:sdio=on:return
    '------ 2 DIGITS AM LCD ANZEIGEN -------
    #show_2_digits
     zehner=value/10
     gosub write_char
     'einer abfragen
     einer=value-(zehner*10)
     lcd_char=einer+&HB0
     gosub write_char
     return
    #mode_control
    lcd_data=&H00:gosub write_byte
    #write_byte
    sdio=(lcd_data and &H80)shr 7:sclio=on:sclio=off
    sdio=(lcd_data and &H40)shr 6:sclio=on:sclio=off
    sdio=(lcd_data and &H20)shr 5:sclio=on:sclio=off
    sdio=(lcd_data and &H10)shr 4:sclio=on:sclio=off
    sdio=(lcd_data and &H08)shr 3:sclio=on:sclio=off
    sdio=(lcd_data and &H04)shr 2:sclio=on:sclio=off
    sdio=(lcd_data and &H02)shr 1:sclio=on:sclio=off
    sdio=lcd_data and &H01:sclio=on:sclio=off
    deact sdio:sclio=on:sclio=off:sdio=off:return
    #lcd2x8_init
    lcd_data=&H25:gosub write_byte
    lcd_data=&H06:gosub write_byte
    lcd_data=&H24:gosub write_byte
    lcd_data=&H0C:gosub write_byte
    lcd_data=&H84:gosub write_byte
    '------ I/O-TERMINAL KEYBOARD DECODER   -----
    #key_decode
    key=255:if key_val<8 then return
    #get_stable
    key=key_val:if key<>key_val then goto get_stable
    if key_val>8   then key=10 'F1 KEY
    if key_val>25  then key=11 'F2 KEY
    if key_val>41  then key=12 'F3 KEY
    if key_val>57  then key=1  ' 1 KEY
    if key_val>74  then key=2  ' 2 KEY
    if key_val>90  then key=3  ' 3 KEY
    if key_val>106 then key=4  ' 4 KEY
    if key_val>124 then key=5  ' 5 KEY
    if key_val>140 then key=6  ' 6 KEY
    if key_val>156 then key=7  ' 7 KEY
    if key_val>170 then key=9  ' 9 KEY
    if key_val>187 then key=8  ' 8 KEY
    if key_val>203 then key=0  ' 0 KEY
    if key_val>221 then key=13  ' CLEAR
    if key_val>238 then key=14 ' RETURN
    return
    table ttab1 "temperaturen.tab"
    table ttab2 "temperaturen.tab"
    Hallo Croy,
    in der Bedienungsanleitung für die M-Unit steht auf Seite:
    "Definition von Variablen
    Der C-Control/Basic Steuercomputer stellt 24 Byte- Speicherzellen dem Anwender zur Verwendung "
    Du hast 12 Word Variablen a 2 Byte = 24 Bytes und 15 Byte Variable macht zusammen 39 Bytes.
    Da kommt es meiner Meinung nach zu Überschreiben der Variablen
    Bin kein Fachmann, hoffe aber Dir geholfen zu haben
    Johann ter Horst
    danke für die hilfe, stimmt, könnte daran liegen, ich werds mal testen.....
