habe ein Problem mit dem Pollin Grafik LCD TG12864B und zwar zeigt das Display mir fast alle Pixel an( Contrast gedimmt). Zwischen den Pixel sieht man wie eine Linie wandert, Schrift wird allerdings gar nicht an gezeigt.
Mit Hello World
Code:'some routines to control the display are in the glcdKS108.lib file $lib "glcdKS108.lib" $regfile = "m8def.dat" '$crystal = 7372800 $baud = 9600 $lib "glcdKS108.lbx" 'First we define that we use a graphic LCD Config Graphlcd = 128 * 64sed , Dataport = Portd , Controlport = Portc , Ce = 2, Ce2 = 1 , Cd = 5 , Rd = 4 , Reset = 0 , Enable = 3 Cls Lcdat 1 , 1 , "Hello World" Do Nop 'mache nichts Loop
Beispiel von MCS
Habe auch schon bei Google geschaut, aber leider nichts gefunden!Code:'-------------------------------------------------------------------- ' KS108.BAS ' demonstrates the KS108 based graphical display support '-------------------------------------------------------------------- 'some routines to control the display are in the glcdKS108.lib file $lib "glcdKS108.lib" $regfile = "m8def.dat" $crystal = 7372800 $baud = 19200 Print "Config" ' printing will still work as only the receiver pin is disabled 'First we define that we use a graphic LCD Config Graphlcd = 128 * 64sed , Dataport = Portd , Controlport = Portc , Ce = 1 , Ce2 = 2 , Cd = 5 , Rd = 4 , Reset = 0 , Enable = 3 'Dim variables (y not used) Dim X As Byte , Y As Byte Print "Cls" Cls Wait 1 'specify the font we want to use Setfont Font8x8 'You can use locate but the columns have a range from 1-128 'When you want to show somthing on the LCD, use the LDAT command 'LCDAT Y , COL, value Lcdat 1 , 1 , "123" 'lcdat accepts an additional param for inversing the text Lcdat 2 , 1 , "123" , 1 ' will inverse the text 'Now use a different font 'Setfont Font8x8 'since the 16*16 font uses 2 rows, show on row 3 'Lcdat 1 , 1 , "2345" 'Lcdat 2 , 56 , "2345656" Wait 1 Line(0 , 0) -(128 , 64) , 1 'make line Wait 2 Line(0 , 0) -(128 , 64) , 0 'remove line For Y = 1 To 20 Circle(30 , 30) , Y , 1 Waitms 100 Next Wait 1 Glcdcmd &H3E , 1 : Glcdcmd &H3E , 2 ' both displays off Wait 1 Glcdcmd &H3F , 1 : Glcdcmd &H3F , 2 'both on 'GLCDCMD accepts an additional param to select the chip 'With multiple, GLCDCMD statements, it is best to specify the chip only the first time Showpic 0 , 0 , Plaatje 'show a comnpressed picture End 'end program 'we need to include the font files 'Notice that this is a testfont with only numbers defined ! '$include "smallfont8x8.font" $include "font8x8.font" '$include "font16x16.font" Plaatje: 'include the picture data $bgf "ks108.bgf"
Hoffe ihr habt ein paar Ideen!
Zitieren
Lesezeichen
