Thema: Problem mit Pollin Grafik LCD TG12864B
    hessen
    habe ein Problem mit dem Pollin Grafik LCD TG12864B und zwar zeigt das Display mir fast alle Pixel an( Contrast gedimmt). Zwischen den Pixel sieht man wie eine Linie wandert, Schrift wird allerdings gar nicht an gezeigt.
    Mit Hello World
    'some routines to control the display are in the glcdKS108.lib file
    $lib "glcdKS108.lib"
    $regfile = "m8def.dat"
    '$crystal = 7372800
    $baud = 9600
    $lib "glcdKS108.lbx"
    'First we define that we use a graphic LCD
    Config Graphlcd = 128 * 64sed , Dataport = Portd , Controlport = Portc , Ce = 2, Ce2 = 1 , Cd = 5 , Rd = 4 , Reset = 0 , Enable = 3
    Cls
    Lcdat 1 , 1 , "Hello World"
    Nop 'mache nichts
    Beispiel von MCS
    '                         KS108.BAS
    ' demonstrates the KS108 based graphical display support
    $crystal = 7372800
    $baud = 19200
    Print "Config"                                              ' printing will still work as only the receiver pin is disabled
    Config Graphlcd = 128 * 64sed , Dataport = Portd , Controlport = Portc , Ce = 1 , Ce2 = 2 , Cd = 5 , Rd = 4 , Reset = 0 , Enable = 3
    'Dim variables (y not used)
    Dim X As Byte , Y As Byte
    Print "Cls"
    Cls
    Wait 1
    'specify the font we want to use
    Setfont Font8x8
    'You can use locate but the columns have a range from 1-128
    'When you want to show somthing on the LCD, use the LDAT command
    'LCDAT Y , COL, value
    Lcdat 1 , 1 , "123"
    'lcdat accepts an additional param for inversing the text
    Lcdat 2 , 1 , "123" , 1                                     ' will inverse the text
    'Now use a different font
    'Setfont Font8x8
    'since the 16*16 font uses 2 rows, show on row 3
    'Lcdat 1 , 1 , "2345"
    'Lcdat 2 , 56 , "2345656"
    Wait 1
    Line(0 , 0) -(128 , 64) , 1                                 'make line
    Wait 2
    Line(0 , 0) -(128 , 64) , 0                                 'remove line
    For Y = 1 To 20
       Circle(30 , 30) , Y , 1
       Waitms 100
    Next
    Wait 1
    Glcdcmd &H3E , 1 : Glcdcmd &H3E , 2                         ' both displays off
    Wait 1
    Glcdcmd &H3F , 1 : Glcdcmd &H3F , 2                         'both on
    'GLCDCMD accepts an additional param to select the chip
    'With multiple, GLCDCMD statements, it is best to specify the chip only the first time
    Showpic 0 , 0 , Plaatje                                     'show a comnpressed picture
    End                                                         'end program
    'we need to include the font files
    'Notice that this is a testfont with only numbers defined !
    '$include "smallfont8x8.font"
    $include "font8x8.font"
    '$include "font16x16.font"
    Plaatje:
    'include the picture data
    $bgf "ks108.bgf"
    Habe auch schon bei Google geschaut, aber leider nichts gefunden!
    Hoffe ihr habt ein paar Ideen!
    Plaatje:
    $bgf "ks108.bgf"
    Wahrscheinlich fehlen ingerdwelche davon ?
    hessen
    hmmm.... nein
    habe gerade waits eingefügt und schon klappts :-D .... Trotzdem vielen Dank :-D
  1. LCD-Modul TG12864B-13 von Pollin
    Von bd239 im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 08.11.2010, 19:41
  2. Grafik-LCD von Pollin
    Von dolivo im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 12.02.2010, 12:54
  3. TG12864B GLCD Pollin Anschluss
    Von zebrafalke im Forum Basic-Programmierung (Bascom-Compiler)
    Antworten: 16
    Letzter Beitrag: 23.02.2009, 14:20
  4. GLCD TG12864B-03 mit KS108 von Pollin wie anschließen?
    Von Inkoknito im Forum Basic-Programmierung (Bascom-Compiler)
    Antworten: 7
    Letzter Beitrag: 29.10.2008, 20:09
  5. Pollin Grafikdisplay TG12864B-05 und bascom wie anschließen?
    Von Accenter im Forum Basic-Programmierung (Bascom-Compiler)
    Antworten: 11
    Letzter Beitrag: 08.08.2007, 10:56
