ich möchte, als kurzes Zwischenprojekt, einen ADC von ADCA (Pina.2) im Free-Running Mode betreiben und die Werte über den DMA (Ch0) in den Speicher schreiben. Irgendwie passiert da aber etwas anderes als das vorhergesehene...
Hier mal mein Programm:
$regfile = "xm64a3def.dat"
$crystal = 32000000
$framesize = 100
$swstack = 100
$hwstack = 100
$lib "xmega.lib"
$external _xmegafix_clear
$external _xmegafix_rol_r1014
Config Osc = Disabled , 32mhzosc = Enabled
Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1
Config Com2 = 38400 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "COM2:" For Binary As #1
Dim Adc_ar(500) As Byte
Dim Print_data As Bit
Dim I As Word
Dim Adc_res As Byte
Dim Durchschnitt As Dword
For I = 1 To 500
   Adc_ar(i) = 0
Next I
Print_data = 0
Config Adca = Free , Convmode = Unsigned , Resolution = 8bit , Prescaler = 16 , Sweep = Ch0 , _
   Reference = Arefa , Dma = Off , Ch0_gain = 1 , Ch0_inp = Single_ended , Mux0 = 16
Config Dma = Enabled , Doublebuf = Disabled , Cpm = Ch0123
Config Dmach0 = Enabled , Burstlen = 1 , Chanrpt = Enabled , Tci = Lo , Eil = Off , _
   Sar = None , Sam = Fixed , Dar = None , Dam = Inc , Trigger = &H10 , Btc = 500 , Repeat = 0 , _
   Sadr = Varptr(adca_ch0_res) , Dadr = Varptr(adc_ar(1))
On Dma_ch0 Transaction_complete
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled , Hi = Enabled
Enable Interrupts
   If Print_data = 1 Then
      Reset Print_data
      Durchschnitt = 0
      For I = 1 To 500
         Print #1 , Adc_ar(i) ; ":" ;
         Durchschnitt = Durchschnitt + Adc_ar(i)
         Adc_ar(i) = 0
      Next I
      Print #1 ,
      Durchschnitt = Durchschnitt / 500
      Print #1 , "Durchschnitt: " ; Durchschnitt
      Print #1 , "------------------"
      Waitms 500
      Set Adca_ctrlb.3                                      'enable adca free-run mode
   End If
End
Transaction_complete:
   Reset Adca_ctrlb.3                                       'disable adc free-run mode
   Set Dma_intflags.0                                       'clear dma-interrupt bit
   Set Print_data
Return
Eigentlich sollte doch der ADC-Fertig-Interrupt den DMA triggern und dieser müsste das aktuelle Byte übertragen?! Hier ist mal ein kleiner Auszug aus HTerm:
243:243:239:239:239:226:226:128:128:128:255:255:255:255:255:111:111:111:215:215:215:61:61:40:40:40:117:117:117:34:34:68:68:68:93:93:93:44:44:36:36:36:46:46:46:32:32:33:33:33:117:117:117:56:56:33:33:33:114:114:114:38:38:63:63:63:41:41:41:59:59:42:42:42:27:27:27:35:35:41:41:41:36:36:36:35:35:88:88:88:30:30:30:73:73:27:27:27:49:49:49:55:55:57:57:57:58:58:58:26:26:54:54:54:107:107:107:32:32:45:45:45:107:107:107:42:42:54:54:54:108:108:108:50:50:26:26:26:42:42:42:118:118:34:34:34:39:39:39:30:30:40:40:40:30:30:30:31:31:39:39:39:88:88:88:30:30:25:25:25:73:73:73:28:28:31:31:31:113:113:113:42:42:26:26:26:85:85:85:29:29:34:34:34:88:88:88:53:53:47:47:47:31:31:31:89:89:113:113:113:37:37:37:43:43:120:120:120:52:52:52:26:26:65:65:65:84:84:84:40:40:64:64:64:46:46:46:34:34:30:30:30:24:24:24:25:25:46:46:46:38:38:38:31:31:44:44:44:39:39:39:51:51:110:110:110:36:36:36:26:26:38:38:38:36:36:36:36:36:29:29:29:22:22:22:19:19:20:20:20:20:20:20:20:20:20:20:20:19:19:19:20:20:19:19:19:37:37:37:36:36:36:36:36:37:37:37:36:36:36:36:36:36:36:36:37:37:36:36:36:36:36:36:38:38:34:34:34:99:99:99:85:85:42:42:42:118:118:118:45:45:86:86:86:32:32:32:63:63:26:26:26:110:110:110:112:112:45:45:45:118:118:118:38:38:28:28:28:103:103:103:32:32:62:62:62:86:86:86:52:52:35:35:35:43:43:43:31:31:38:38:38:117:117:117:64:64:33:33:33:115:115:115:37:37:73:73:73:40:40:40:71:71:42:42:42:26:26:26:34:34:40:40:40:35:35:35:34:34:85:85:85:29:29:29:70:70:26:26:26:47:47:47:54:54:54:54:54:59:59:59:26:26:56:56:56:103:103:103:32:32:44:44:44:105:105:105:47:47:54:54:54:106:106:106:46:46:30:30:30:46:46:46:115:115:33:33:33:39:39:
Durchschnitt: 58
0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:
Durchschnitt: 0
Durchschnitt: 0
Durchschnitt: 0
36:36:80:80:80:30:30:31:31:31:30:30:30:33:33:26:26:26:110:110:110:47:47:82:82:82:59:59:59:46:46:105:105:105:33:33:33:47:47:34:34:34:53:53:53:116:116:51:51:51:38:38:38:28:28:75:75:75:28:28:28:42:42:80:80:80:29:29:29:37:37:23:23:23:61:61:61:35:35:38:38:38:50:50:50:72:72:28:28:28:92:92:92:39:39:27:27:27:103:103:103:42:42:89:89:89:41:41:41:30:30:38:38:38:51:51:51:34:34:111:111:111:57:57:57:36:36:26:26:26:121:121:121:40:40:91:91:91:73:73:73:27:27:43:43:43:24:24:24:25:25:87:87:87:59:59:59:26:26:82:82:82:64:64:64:47:47:71:71:71:50:50:50:35:35:27:27:27:37:37:37:36:36:34:34:34:22:22:22:21:21:20:20:20:19:19:19:20:20:20:20:20:20:20:20:19:19:20:20:20:38:38:38:36:36:36:36:36:37:37:37:36:36:36:36:36:36:36:36:36:36:36:36:36:37:37:37:36:36:36:36:36:26:26:26:114:114:69:69:69:51:51:51:71:71:28:28:28:41:41:41:36:36:32:32:32:94:94:94:99:99:71:71:71:50:50:50:56:56:35:35:35:113:113:113:42:42:56:56:56:33:33:33:39:39:51:51:51:72:72:72:38:38:42:42:42:115:115:115:48:48:35:35:35:99:99:99:54:54:25:25:25:58:58:58:26:26:61:61:61:34:34:34:50:50:60:60:60:49:49:49:48:48:109:109:109:37:37:37:114:114:33:33:33:78:78:78:31:31:44:44:44:29:29:29:30:30:26:26:26:117:117:117:41:41:66:66:66:71:71:71:40:40:88:88:88:38:38:38:41:41:28:28:28:46:46:46:120:120:44:44:44:56:56:56:29:29:57:57:57:29:29:29:40:40:60:60:60:28:28:28:32:32:25:25:25:95:95:95:33:33:39:39:39:85:85:85:58:58:26:26:26:107:107:107:36:36:32:32:32:116:116:116:37:37:72:72:72:35:35:35:71:71:52:52:52:43:43:43:33:33:105:105:105:48:48:48:29:29:33:33:33:121:121:121:35:35:90:90:90:62:62:62:26:26:35:35:35:25:25:
Durchschnitt: 51
Durchschnitt: 0
Durchschnitt: 0
Durchschnitt: 0
64:64:30:30:30:110:110:33:33:33:110:110:110:36:36:103:103:103:52:52:52:32:32:30:30:30:35:35:35:46:46:30:30:30:61:61:61:26:26:53:53:53:25:25:25:38:38:43:43:43:43:43:43:51:51:24:24:24:44:44:44:80:80:29:29:29:33:33:33:84:84:87:87:87:42:42:42:80:80:33:33:33:92:92:92:90:90:85:85:85:30:30:30:34:34:87:87:87:34:34:34:28:28:36:36:36:36:36:36:56:56:25:25:25:25:25:25:52:52:41:41:41:28:28:28:91:91:32:32:32:27:27:27:58:58:26:26:26:30:30:30:59:59:102:102:102:39:39:39:26:26:60:60:60:89:89:89:45:45:47:47:47:100:100:100:37:37:23:23:23:94:94:94:59:59:58:58:58:43:43:43:37:37:74:74:74:27:27:27:26:26:45:45:45:51:51:51:29:29:90:90:90:37:37:37:32:32:39:39:39:80:80:80:29:29:35:35:35:36:36:36:36:36:36:36:36:25:25:25:21:21:20:20:20:20:20:20:20:20:20:20:20:20:20:20:19:19:19:19:19:26:26:26:38:38:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:37:37:37:37:37:35:35:35:31:31:31:117:117:85:85:85:33:33:33:119:119:35:35:35:63:63:63:50:50:41:41:41:62:62:62:106:106:115:115:115:72:72:72:97:97:32:32:32:53:53:53:64:64:27:27:27:42:42:42:56:56:90:90:90:75:75:75:33:33:48:48:48:102:102:102:76:76:48:48:48:31:31:31:88:88:30:30:30:99:99:99:31:31:93:93:93:44:44:44:77:77:30:30:30:48:48:48:78:78:29:29:29:49:49:49:48:48:44:44:44:25:25:25:33:33:38:38:38:36:36:36:42:42:24:24:24:72:72:72:61:61:32:32:32:31:31:31:67:67:109:109:109:37:37:37:63:63:33:33:33:78:78:78:112:112:66:66:66:27:27:27:30:30:102:102:102:31:31:31:26:26:81:81:81:34:34:34:45:45:24:24:24:25:25:25:41:41:48:48:48:25:25:25:85:85:29:29:29:34:34:34:47:47:27:27:27:32:32:32:46:46:118:118:118:39:39:
Durchschnitt: 49
Durchschnitt: 0
Durchschnitt: 0
Durchschnitt: 0
100:100:48:48:113:113:113:50:50:50:48:48:32:32:32:52:52:52:25:25:101:101:101:112:112:112:50:50:109:109:109:42:42:42:30:30:118:118:118:33:33:33:72:72:93:93:93:37:37:37:37:37:49:49:49:33:33:33:34:34:115:115:115:46:46:46:35:35:113:113:113:40:40:40:47:47:41:41:41:47:47:47:44:44:27:27:27:37:37:37:42:42:36:36:36:36:36:36:91:91:30:30:30:78:78:78:29:29:50:50:50:58:58:58:59:59:53:53:53:26:26:26:57:57:111:111:111:34:34:34:47:47:109:109:109:38:38:38:57:57:106:106:106:54:54:54:26:26:39:39:39:121:121:121:35:35:40:40:40:26:26:26:41:41:31:31:31:32:32:32:40:40:94:94:94:31:31:31:25:25:76:76:76:29:29:29:31:31:116:116:116:42:42:42:27:27:86:86:86:30:30:30:34:34:93:93:93:82:82:82:49:49:32:32:32:89:89:89:112:112:37:37:37:59:59:59:119:119:50:50:50:25:25:25:66:66:84:84:84:41:41:41:62:62:45:45:45:36:36:36:29:29:26:26:26:25:25:25:45:45:37:37:37:34:34:34:45:45:39:39:39:49:49:49:105:105:33:33:33:27:27:27:38:38:36:36:36:36:36:36:29:29:22:22:22:19:19:19:20:20:20:20:20:20:20:20:20:20:19:19:19:20:20:20:20:20:38:38:38:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:37:37:37:32:32:106:106:106:82:82:82:40:40:119:119:119:42:42:42:89:89:32:32:32:60:60:60:26:26:112:112:112:114:114:114:43:43:119:119:119:37:37:37:27:27:94:94:94:31:31:31:57:57:85:85:85:69:69:69:34:34:41:41:41:29:29:29:50:50:110:110:110:66:66:66:33:33:118:118:118:35:35:35:100:100:38:38:38:100:100:100:48:48:26:26:26:32:32:32:37:37:33:33:33:32:32:32:73:73:28:28:28:60:60:60:26:26:41:41:41:47:47:47:49:49:55:55:55:25:25:25:58:58:89:89:89:31:31:31:39:39:91:91:91:76:76:76:47:47:99:99:99:53:53:53:40:40:
Durchschnitt: 53
Durchschnitt: 0
Durchschnitt: 0
Durchschnitt: 0
72:72:27:27:32:32:32:25:25:25:101:101:32:32:32:41:41:41:87:87:56:56:56:26:26:26:106:106:35:35:35:33:33:33:115:115:37:37:37:72:72:72:34:34:72:72:72:51:51:51:43:43:33:33:33:106:106:106:48:48:27:27:27:32:32:32:121:121:35:35:35:74:74:74:64:64:26:26:26:35:35:35:24:24:25:25:25:69:69:69:48:48:25:25:25:63:63:63:52:52:72:72:72:83:83:83:43:43:29:29:29:36:36:36:36:36:37:37:37:30:30:30:22:22:19:19:19:20:20:20:20:20:20:20:20:19:19:19:20:20:20:20:20:20:20:20:37:37:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:37:37:37:36:36:36:36:36:37:37:37:37:37:37:50:50:115:115:115:56:56:56:100:100:56:56:56:28:28:28:34:34:33:33:33:26:26:26:86:86:108:108:108:56:56:56:93:93:47:47:47:30:30:30:119:119:36:36:36:85:85:85:63:63:33:33:33:42:42:42:57:57:36:36:36:36:36:36:113:113:41:41:41:32:32:32:103:103:44:44:44:26:26:26:45:45:27:27:27:46:46:46:30:30:40:40:40:46:46:46:41:41:39:39:39:109:109:109:33:33:88:88:88:30:30:30:58:58:63:63:63:66:66:66:33:33:27:27:27:40:40:40:122:122:36:36:36:52:52:52:104:104:36:36:36:63:63:63:87:87:43:43:43:25:25:25:38:38:121:121:121:37:37:37:44:44:25:25:25:44:44:44:35:35:32:32:32:48:48:48:76:76:31:31:31:25:25:25:86:86:29:29:29:32:32:32:114:114:46:46:46:26:26:26:97:97:32:32:32:34:34:34:100:100:41:41:41:54:54:54:33:33:101:101:101:99:99:99:38:38:40:40:40:117:117:117:42:42:25:25:25:62:62:62:94:94:33:33:33:66:66:66:48:48:25:25:25:31:31:31:25:25:25:25:25:51:51:51:39:39:24:24:24:47:47:47:43:43:55:55:55:100:100:100:36:36:26:26:26:39:39:39:36:36:36:36:36:29:29:29:22:22:19:19:19:20:20:20:19:19:20:20:20:20:20:20:20:20:20:20:20:19:19:19:37:37:
Durchschnitt: 47
Durchschnitt: 0
Durchschnitt: 0
Durchschnitt: 0
53:53:95:95:95:36:36:114:114:114:34:34:34:81:81:30:30:30:42:42:42:28:28:30:30:30:25:25:25:119:119:42:42:42:60:60:60:49:49:41:41:41:80:80:80:38:38:39:39:39:25:25:25:46:46:110:110:110:43:43:43:58:58:28:28:28:53:53:53:35:35:38:38:38:62:62:62:29:29:30:30:30:25:25:25:101:101:33:33:33:28:28:28:92:92:51:51:51:24:24:24:105:105:34:34:34:31:31:31:106:106:34:34:34:67:67:67:33:33:83:83:83:56:56:56:41:41:33:33:33:106:106:106:46:46:26:26:26:31:31:31:117:117:34:34:34:63:63:63:59:59:25:25:25:34:34:34:25:25:26:26:26:64:64:64:46:46:24:24:24:55:55:55:49:49:67:67:67:64:64:64:39:39:33:33:33:38:38:38:36:36:37:37:37:30:30:30:22:22:20:20:20:19:19:19:20:20:20:20:20:20:20:20:19:19:20:20:20:19:19:19:37:37:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:37:37:37:36:36:36:36:36:36:36:36:36:36:36:64:64:108:108:108:52:52:52:109:109:53:53:53:34:34:34:33:33:40:40:40:26:26:26:92:92:109:109:109:51:51:51:92:92:44:44:44:30:30:30:119:119:35:35:35:79:79:79:78:78:32:32:32:39:39:39:47:47:33:33:33:34:34:34:108:108:43:43:43:35:35:35:103:103:40:40:40:41:41:41:41:41:38:38:38:41:41:41:27:27:37:37:37:43:43:43:34:34:36:36:36:84:84:84:29:29:80:80:80:29:29:29:54:54:60:60:60:59:59:59:45:45:26:26:26:36:36:36:116:116:33:33:33:44:44:44:95:95:37:37:37:54:54:54:102:102:42:42:42:25:25:25:38:38:118:118:118:35:35:35:41:41:26:26:26:40:40:40:35:35:28:28:28:45:45:45:79:79:28:28:28:25:25:25:76:76:29:29:29:26:26:26:110:110:40:40:40:26:26:26:81:81:29:29:29:30:30:30:85:85:33:33:33:47:47:47:30:30:89:89:89:108:108:108:36:36:29:29:29:117:117:117:44:44:24:24:24:54:54:54:83:83:40:40:40:54:54:
Durchschnitt: 48
Durchschnitt: 0
Durchschnitt: 0
Durchschnitt: 0
27:27:21:21:20:20:20:20:20:20:20:20:19:19:19:20:20:20:20:20:20:20:20:20:20:20:19:19:20:20:20:19:19:19:20:20:19:19:19:20:20:20:19:19:20:20:20:19:19:19:20:20:20:20:20:20:20:20:19:19:20:20:20:19:19:19:20:20:19:19:19:19:19:19:19:19:20:20:20:19:19:19:19:19:19:19:19:20:20:20:19:19:20:20:20:20:20:20:20:20:20:20:20:20:20:20:19:19:20:20:20:19:19:19:20:20:19:19:19:20:20:20:20:20:20:20:20:19:19:19:20:20:19:19:19:20:20:20:37:37:36:36:36:37:37:37:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:36:23:23:21:21:21:20:20:20:19:19:20:20:20:20:20:20:20:20:19:19:19:20:20:20:20:20:19:19:19:20:20:20:20:20:20:20:20:19:19:19:20:20:19:19:19:20:20:20:20:20:20:20:20:19:19:19:20:20:20:20:20:19:19:19:19:19:20:20:20:19:19:19:19:19:19:19:19:19:19:19:19:19:20:20:20:20:20:20:19:19:19:19:19:20:20:20:20:20:19:19:19:19:19:19:20:20:19:19:19:20:20:20:19:19:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:20:19:19:20:20:20:20:20:20:37:37:37:37:37:36:36:36:37:37:36:36:36:36:36:36:36:36:36:36:36:36:36:36:22:22:20:20:20:19:19:19:20:20:19:19:19:20:20:20:19:19:20:20:20:20:20:20:20:20:20:20:20:20:20:20:19:19:20:20:20:20:20:20:20:20:19:19:19:20:20:20:20:20:20:20:20:19:19:19:19:19:19:19:19:19:19:19:20:20:20:20:20:19:19:19:20:20:20:20:20:19:19:19:19:19:20:20:20:20:20:20:19:19:19:19:19:20:20:20:19:19:20:20:20:19:19:19:20:20:19:19:19:20:20:20:19:19:20:20:20:19:19:19:19:19:20:20:20:20:20:20:19:19:19:19:19:20:20:20:20:20:19:19:19:20:20:20:19:19:20:20:20:25:25:25:37:37:36:36:36:37:37:37:36:36:
Durchschnitt: 21
Wie man deutlich erkennt, wird einmal das Ganze Array (500 Werte) eingelesen und gespeichert und dann dreimal nichts. Aber warum? Dass manche Werte mehrfach vorkommen, liegt daran, dass der Prescaler relativ klein ist und das Signal ein BAS-Signal einer 15€ Kamera ist, welches eine nicht allzugroße Auflösung hat.
Ist vielleicht meine Initialisierung des DMA falsch? Sollte ich Repeat = 500 und BTC = 1 machen?
Es muss eben immer, wenn der ADC einen neuen Wert eingelesen hat, dieser in die nächste Stelle vom Array geschrieben werden. Das via den ADC-Interrupt zu machen wäre zwar eine Möglichkeit, aber keine sehr schöne, da ich möglichst die volle Rechenleistung brauche und ich das nicht so schön finde wie mit dem DMA.
Zum Hintergrund:
In Zukunft soll der Sync mithilfe eines Analog-Comparators erkannt werden. Dieser triggert den Start von 500x Einlesen und diese Werte sollen dann verarbeitet werden (also z.b. in ein 2D Array schreiben und dann durch ein NN analysieren, um bestimme Muster (X,+,O,-, usw...) zu erkennen oder zb. per Funk an den PC übertragen und als Bild darstellen).
Ich hoffe ihr versteht mein Problem und könnt mir helfen bzw. Tipps geben
Gruß & Vielen Dank
Chris
