Ergebnis 1 bis 10 von 12
Thema: 3PI goes BASCOM
    Erfahrener Benutzer Roboter Genie Avatar von pinsel120866
    Hohenems
    Beitrag 3PI goes BASCOM
    ich habe mir einen Bascom Code zurechtgelegt, der die LEDs, das Display und die Motoren bedient:
        '==== 3PI goes Bascom
        '==== December 2012, pinsel120866
        $regfile = "m328pdef.dat"       ' Set the chip as a Mega 328p
        $crystal = 20000000       ' Clock speed 20 MHZ
        '=== Generic Port Setup ===
        Config Portb = Output
        Config Portc = Output
        Config Portd = Output
        re_led Alias Portd.7       ' Green User LED
        li_led Alias Portd.1       ' Red User LED
        '=== LCD SETUP ===
        Config Lcdpin = Pin , Db4 = Portb.1 , Db5 = Portb.4 , Db6 = Portb.5 , Db7 = Portd.7 , E = Portd.4 , Rs = Portd.2
        Config Lcd = 16 * 2       ' Actually 8x2 but that is not recognized by BASCOM.
        Rw Alias Portb.0 : Rw = 0       ' Set to Zero to write to the LCD
        Cursor = Off
        '=== PWM SETUP ===
        Config Timer0 = Pwm , Prescale = 1 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down
        Config Timer2 = Pwm , Prescale = 1 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down
        ' Pin Configurations
        ' Portb.0 - LCD Function R/W
        ' Portb.1 - LCD Data DB4                    ( Switch A )
        ' Portb.2 - Buzzer
        ' Portb.3 - Motor 2 Control Line
        ' Portb.4 - LCD Data DB5                    ( Switch B )
        ' Portb.5 - LCD Data DB6                    ( Switch C )
        ' Portb.6 -
        ' Portb.7 -
        ' Portc.0 - IR Sensor #1 ( Left )
        ' Portc.1 - IR Sensor #2
        ' Portc.2 - IR Sensor #3 ( Center )
        ' Portc.3 - IR Sensor #4
        ' Portc.4 - IR Sensor #5 ( Right )
        ' Portc.5 - ADC5
        ' Portc.6 - Motor Controller Not Standby
        ' Portc.7 -
        ' Portd.0 - RXD
        ' Portd.1 - TXD                                      (RED LED)
        ' Portd.2 - LCD Function RS
        ' Portd.3 - Motor 2 Control Line
        ' Portd.4 - LCD Function E
        ' Portd.5 - Motor 1 Control Line
        ' Portd.6 - Motor 1 Control Line
        ' Portd.7 - LCD Data DB7                      (GRN LED)
        ' ADC6   -  Battery Power Indicator
        ' ADC7   -  User Trim Pot on underside
        ' Program Start Here
        Dim X As Word       ' Set up a simple variable
        Cls
        Lcd "START"
        Locate 2 , 1
        For X = 1 To 5
        Lcd "*"
        Wait 1
        re_led = 1
        li_led = 1
        Next X
        Cls
        Lcd "Gerade"
        X=60
        re_led = 0
        li_led = 0
        Gosub Robot_forward
        Waitms 1000
        Cls
        Lcd "Rechts"
        X=100
        re_led = 1
        li_led = 0
        Gosub Robot_right
        Waitms 1000
        cls
        lcd "Zurück"
        x=60
        re_led = 0
        li_led = 0
        gosub  ROBOT_REVERSE
        waitms 1000
        cls
        lcd"Links"
        x=100
        re_led = 0
        li_led = 1
        gosub ROBOT_LEFT
        waitms 1000
        re_led = 0
        li_led = 0
        Cls
        Lcd "Fertig"
        Gosub Robot_stop
        waitms 1000
        Do       ' Just waste time at the end
        End       'end program
        ' Subroutines Here
        Robot_forward:
        Pwm0a = X : Pwm0b = 0 : Pwm2a = X : Pwm2b = 0
        Return
        Robot_stop:
        Pwm0a = 0 : Pwm0b = 0 : Pwm2a = 0 : Pwm2b = 0
        Return
        Robot_reverse:
        Pwm0a = 0 : Pwm0b = X : Pwm2a = 0 : Pwm2b = X
        Return
        Robot_right:
        Pwm0a = 0 : Pwm0b = X : Pwm2a = X : Pwm2b = 0
        Return
        Robot_left:
        Pwm0a = X : Pwm0b = 0 : Pwm2a = 0 : Pwm2b = X
        Return
    Läuft soweit ganz gut, bei den Liniensensoren komme ich nicht weiter.
    Kann mich bitte jemand dabei unterstützen?
    Wäre nett...
    Karlstadt
    Hallo Pinsel,
    meiner Erinnerung nach mußt du das Licht für die Liniensensoren einschalten. PortC.5, hab grad nachgeschaut.
    Die 5 Sensoren werden dann über AD-Wandler eingelesen.
    Ich meine, es wäre eine externe Referenz dran, deshalb bei der Config ADC Reference = Off
    Gruß, Michael
    Hohenems
    Hallo Michael,
    danke für die Antwort.
    Ich habe nun folgendes:
    Declare Sub Linedata()
    Dim Linesens1 As Integer
    Dim Linesens2 As Integer
    Dim Linesens3 As Integer
    Dim Linesens4 As Integer
    Dim Linesens5 As Integer
    Config Adc = Single , Prescaler = Auto , Reference = Off
    Start Adc
    Sub Linedata()
    Config Portc.5 = Output
    Portc.5 = 1
    Linesens1 = Getadc(0)
    Linesens2 = Getadc(1)
    Linesens3 = Getadc(2)
    Linesens4 = Getadc(3)
    Linesens5 = Getadc(4)
    Portc.5 = 0
    End Sub
    Aufruf mit
    call Linedata
    Was meinst du?
    Geändert von pinsel120866 (02.12.2012 um 18:26 Uhr)
    Karlstadt
    Hallo Pinsel,
    ja, so hab ich es auch gemacht.
    PortC.0 bis PortC.4 muß Input sein. Linienlicht ist PortC.5, Output
    Linienlicht = 1
    Portc = Portc Or &B00011111
    For I = 0 To 4
         S = I + 1
         Pc_(s) = Getadc(i)
    Next
    Gruß, Michael
    Also laut der Anleitung auf der Webseite von Pololu werden die Licht bzw. Liniensensoren nicht über den ADC ausgelesen, sondern Man muss den entsprechenden Port als Output deklarieren, auf HIGH setzen, etwas warten (vielleicht ~ 10 us, um den Konsensator aufzuladen) und dann den Port auf einen Input umstellen, und pullup ausschalten. Nun misst man die Zeit, bis der Input wieder auf LOW geht (der Konsensator wird durch den Fototransistor entladen). Und je nach dem wieviel Licht in den Sensor trifft, ändert sich die Zeit.
    Link : http://www.pololu.com/docs/0J21/5.d
    Gesammter Artikel : http://www.pololu.com/docs/0J21/all
    Karlstadt
    so kann man es natürlich auch machen. Mit dem AD-Wandler hast du halt nicht den Stress mit der Umschalterei und dem Impulse-messen. Dann hätte sich der Hersteller aber auch die genaue Verteilung auf die AD-Ports sparen können
    Gruß, Michael
    ... Mit dem AD-Wandler hast du halt nicht den Stress mit der Umschalterei ...
    Meinst Du? Na ja, der ADWandler stellt sich nicht von alleine um (Stichwort: Multiplex). Und MÖGLICHERWEISE ist die Kennlinie dieses Kondensator-Entlade-Tricks für die gestellte Aufgabe zweckmässiger als die des ADC. Ist jetzt nur geraten/vermutet/alsmöglichgedacht, ich habs noch nicht verglichen.
    Karlstadt
    schau einfach mein letztes Programmbeispiel an. Ich glaube nicht, dass das mit DDR-Umschalten und Timerlesen einfacher geht.
    Die Linienberechnung danach wichtet die Werte um die Position herauszukriegen. Selbst wenn die AD-Wandler eine andere Kennlinie haben, die Linienposition bekommst du trotzdem genau raus.
    Gruß, Michael
    Gruß, Michael
    Wenn der Schaltplan aus dem Datenblatt stimmt:
Hits:	7
Größe:	4,3 KB
    geht das mit dem ADC garnicht. Und selbst wenn man statt des Kondensators einen Widerstand nach Vcc einbaut, ist der Ausgangswiderstand des Phototransistors tendenziell eine Größenordnung (oder mehr) zu groß für einen typischen µC-ADC. Die Ergebnisse werden kaum besser sein, als wenn man den Port einfach digital einliest, und den Widerstand nach Vcc durch ausprobieren ermittelt.
    MfG Klebwax
  1. 3Pi Liniensensoren
    Von pinsel120866 im Forum 3pi Robot
    Letzter Beitrag: 01.12.2018, 16:39
  2. Verkaufe Pololu 3Pi
    Von Zwerwelfliescher im Forum Kaufen, Verkaufen, Tauschen, Suchen
    Antworten: 9
    Letzter Beitrag: 29.03.2013, 16:52
  3. 3pi Wireless
    Von Zwerwelfliescher im Forum Vorstellungen+Bilder von fertigen Projekten/Bots
    Letzter Beitrag: 25.12.2011, 11:35
  4. 3Pi - Stromversorgung
    Von Hyla im Forum 3pi Robot
    Letzter Beitrag: 19.09.2009, 19:21
  5. 3Pi Einsteigerfragen
    Von Fritz.Xob im Forum 3pi Robot
    Letzter Beitrag: 15.07.2009, 20:50
