habe ähnlich wie bei der M32 die Libs verändert aber da kommt nur misst bei raus.
habe es so abgeändert:
h. lib
c. libCode:void _showScreenLCD_P(const char *line1, const char *line2, const char *line3, const char *line4); #define showScreenLCD(__line1,__line2,__line3,__line4); ({_showScreenLCD_P((PSTR(__line1)),(PSTR(__line2)),(PSTR(__line3)),(PSTR(__line4)));})
undCode:void initLCD(void) { delayCycles(34000); //No need for Power ON delay as usually the // Bootloader should have been executed before... PORTG &= ~DISP_WR; PORTG &= ~DISP_RS_ALE; PORTG &= ~DISP_EN_RD; mSleep(5); writeLCDCommand(0b00101100); delayCycles(55500); mSleep(50); writeLCDCommand(0b00001001); delayCycles(55500); mSleep(5); writeLCDCommand(0b00101000); delayCycles(55500); mSleep(5); writeLCDCommand(0b00001000); delayCycles(55500); mSleep(1); writeLCDCommand(0b00000001); delayCycles(55500); mSleep(1); writeLCDCommand(0b00000010); delayCycles(55500); mSleep(1); writeLCDCommand(0b00001100); delayCycles(55500); mSleep(1); mSleep(5); clearLCD(); }
was ist daran nun falsch?Code:void _showScreenLCD_P(const char *line1, const char *line2, const char *line3, const char *line4) { clearLCD(); writeNStringLCD_P(line1); setCursorPosLCD(1, 0); writeNStringLCD_P(line2); setCursorPosLCD(2, 0); writeNStringLCD_P(line3); setCursorPosLCD(3, 0); writeNStringLCD_P(line4); } /** * Sets the cursor position on LCD. */ void setCursorPosLCD(uint8_t line, uint8_t pos) { pos |= 128; if(line==1) pos += 0x40; if(line==2) pos += 0x14; if(line==3) pos += 0x54; writeLCDCommand(pos); }
danke schonmal
Zitieren
Lesezeichen
