Ergebnis 11 bis 13 von 13
Thema: Verständniss Frage zu einer Modulation
    Benutzer Stammmitglied Avatar von Janiiix3
    Hannover
    Sooo nun bin ich wieder erwacht :-P
    Hier mal mein aktueller Quellcode. Ich mache mit großer Sicherheit irgendwas ganz gravierendes falsch...
    #define F_CPU 16000000
    #define RC5_HALF_BIT_TIME 8 // 8 * 111µs = 888µs
    #define RC5_SEND_ON        PORTD |=  (1<<PD1)
    #define RC5_SEND_OFF    PORTD &= ~(1<<PD1)
    #include <avr/io.h>
    #include <avr/interrupt.h>
    #include <util/delay.h>
    #include <stdbool.h>
    void rc5_send_command(uint16_t command);
    void rc5_send_one(void);
    void rc5_send_zero(void);
    void delay_880(void);
    volatile static uint8_t modulation, rc5_half_bit_cnt, rc5_state;
    uint16_t rc5_byte = 0x00;
    int main(void)
        DDRB |= (1<<PB7);
        DDRD |= (1<<PD1);
        TCCR0A  = (1<<WGM01);  // CTC
        TCCR0B  = (1<<CS01);   // 8 ( ca. 111µs @ 8 MHz )
        TCCR1B  = (1<<CS10);   // 1 ( ca. 36 kHz @ 8 MHz )
        TCCR1B |= (1<<WGM12);  // CTC
        TIMSK0  = (1<<OCIE0A); // OutputCompare0A
        TIMSK1  = (1<<OCIE1A); // OutputCompare1A
        OCR0A  = (0x6E);
        OCR1A  = (0x00DD);
        sei();
        while(1)
            rc5_send_command(0b11000000001100);
    /* send a 14 bit command to the IR - Receiver */
        uint16_t send_byte = command;
        for (uint16_t x = 0 ; x < 14 ; x++)
            if (send_byte & 0x8000)
                rc5_send_one();
            else
                rc5_send_zero();
            send_byte <<= 0x0001;
    /* send a logical one to the Receiver ( 1 --> 0 ) */
        rc5_state &= ~(0x40);
        delay_880();
        rc5_state |=  (0x40);
        delay_880();
    /* send a logical zero to the  Receiver ( 0 --> 1 ) */
        rc5_state |= (0x40); // led on
        delay_880();
        rc5_state &= ~(0x40); // led off
        delay_880();
        while(1)
            if ((rc5_state & 0x01) == 0x01)
                rc5_half_bit_cnt = 0x00;
                rc5_state = 0x00;
                break;
    /* called every 111 µs */
    ISR(TIMER0_COMPA_vect)
        rc5_half_bit_cnt++;
        if (rc5_half_bit_cnt >= RC5_HALF_BIT_TIME)
            rc5_state |= 0x01;
    /* called every 0,0278 ms */
    ISR(TIMER1_COMPA_vect)
        if ((rc5_state & 0x40) == 0x40)
            RC5_SEND_ON;
        else
            RC5_SEND_OFF;
    __________________________________________________ _________________
    /*Ich möchte gerne die Welt verändern, doch Gott gibt den Quelltext nicht frei.*/
    ( <-- Das ist Glubschie, er ist nett )
    Erfahrener Benutzer Roboter Experte Avatar von sternst
    Deine ISR gibt doch gar kein 36kHz-Signal aus, statt dessen ist der Pin jeweils 880µs lang 0 oder 1. Die ISR müsste eher so aussehen:
            RC5_SEND_TOGGLE;
        else
            RC5_SEND_OFF;
    Außerdem müsstest du das Intervall für die ISR halbieren, denn für ein 36kHz-Signal musst du den Pin ja mit 72kHz toggeln.
    ABER: Wie andere schon sagten, es wäre viel sinnvoller das 36kHz-Signal direkt vom Timer erzeugen zu lassen, und dann entsprechend einfach ein- und auszuschalten.
    Stefan
    .. kein 36kHz-Signal .. statt dessen .. 880µs lang 0 oder 1 .. Wie andere schon sagten .. für .. 36kHz .. mit 72kHz toggeln ..
    Stefan, wieder schön; wirklich gut und knapp erklärt. Aber derJaniiix3 sollte das ja schon wissen, zumindest wenn er die ausführlichen, anschaulichen Erläuterungen von Seb durchgearbeitet hätte. Mit solchen Erklärungen zur Modulation (wo man sogar die 36 kHz erkennt *ggg*)
    ......Bild hier
    zum Aufbau der beiden Datenbits (>>klick) oder zum Aufbau des RC-5-Protokolls
    ......Bild hier
    sollte der Sachvorgang doch klar werden (dachte ich). Aber ich habe selbst auch (?noch?) immer wieder diesen Hang zur experimentellen Softwarentwicklung.
  1. PWM Modulation
    Von frank65 im Forum PIC Controller
    Letzter Beitrag: 15.06.2010, 01:10
  2. [GELÖST] Was ist das für eine Modulation?
    Von Maverick89 im Forum Elektronik
    Antworten: 7
    Letzter Beitrag: 25.02.2010, 23:43
  3. Modulation / Demudaltion...
    Von Manu_91 im Forum Elektronik
    Letzter Beitrag: 14.12.2008, 17:18
  4. IR Modulation
    Von scales im Forum Sensoren / Sensorik
    Letzter Beitrag: 27.11.2006, 18:56
  5. Allgemeines Verständniss der Grundschaltungen
    Von Crash32 im Forum Elektronik
    Letzter Beitrag: 16.12.2005, 20:04
