Ergebnis 11 bis 20 von 49
Thema: Arduino Mega am Raspi Pi 3
    Saarbrücken
    Ja ich habe mich streng daran gehalten.
    Lokal kann ich schlecht mit dem Raspi arbeiten, habe momentan nichts dran.
    pi@raspi:~/Entwicklung/Serial $ gpio -v
    gpio version: 2.32
    Copyright (c) 2012-2015 Gordon Henderson
    This is free software with ABSOLUTELY NO WARRANTY.
    For details type: gpio -warranty
    Raspberry Pi Details:
      Type: Pi 3, Revision: 02, Memory: 1024MB, Maker: Sony
      * Device tree is enabled.
      * This Raspberry Pi supports user-level GPIO access.
        -> See the man-page for more details
        -> ie. export WIRINGPI_GPIOMEM=1
    pi@raspi:~/Entwicklung/Serial $ gpio readall
     +-----+-----+---------+------+---+---Pi 3---+---+------+---------+-----+-----+
     | BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
     |     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
     |   2 |   8 |   SDA.1 |   IN | 1 |  3 || 4  |   |      | 5V      |     |     |
     |   3 |   9 |   SCL.1 |   IN | 1 |  5 || 6  |   |      | 0v      |     |     |
     |   4 |   7 | GPIO. 7 |   IN | 1 |  7 || 8  | 1 | ALT5 | TxD     | 15  | 14  |
     |     |     |      0v |      |   |  9 || 10 | 1 | ALT5 | RxD     | 16  | 15  |
     |  17 |   0 | GPIO. 0 |   IN | 0 | 11 || 12 | 0 | IN   | GPIO. 1 | 1   | 18  |
     |  27 |   2 | GPIO. 2 |   IN | 0 | 13 || 14 |   |      | 0v      |     |     |
     |  22 |   3 | GPIO. 3 |   IN | 0 | 15 || 16 | 0 | IN   | GPIO. 4 | 4   | 23  |
     |     |     |    3.3v |      |   | 17 || 18 | 0 | IN   | GPIO. 5 | 5   | 24  |
     |  10 |  12 |    MOSI |   IN | 0 | 19 || 20 |   |      | 0v      |     |     |
     |   9 |  13 |    MISO |   IN | 0 | 21 || 22 | 0 | IN   | GPIO. 6 | 6   | 25  |
     |  11 |  14 |    SCLK |   IN | 0 | 23 || 24 | 1 | IN   | CE0     | 10  | 8   |
     |     |     |      0v |      |   | 25 || 26 | 1 | IN   | CE1     | 11  | 7   |
     |   0 |  30 |   SDA.0 |   IN | 1 | 27 || 28 | 1 | IN   | SCL.0   | 31  | 1   |
     |   5 |  21 | GPIO.21 |   IN | 1 | 29 || 30 |   |      | 0v      |     |     |
     |   6 |  22 | GPIO.22 |   IN | 1 | 31 || 32 | 0 | IN   | GPIO.26 | 26  | 12  |
     |  13 |  23 | GPIO.23 |   IN | 0 | 33 || 34 |   |      | 0v      |     |     |
     |  19 |  24 | GPIO.24 |   IN | 0 | 35 || 36 | 0 | IN   | GPIO.27 | 27  | 16  |
     |  26 |  25 | GPIO.25 |   IN | 0 | 37 || 38 | 0 | IN   | GPIO.28 | 28  | 20  |
     |     |     |      0v |      |   | 39 || 40 | 0 | IN   | GPIO.29 | 29  | 21  |
    Also soweit scheint das zu passen. Nach dem Essen stöpsel ich den Raspi mal im Schlafzimmer dran, mal schauen ob das dann geht. Würde mich aber stark wundern wenn das ein Unterschied machen würde. Arbeite ja nicht zum ersten Mal mit ssh auf anderen Rechnern.
    HaWe
    dann weiß ich nicht weiter bei dir - vlt ein Pi 3 Bug?
    Ich habe 2 Pi 2, bei beiden funzt es wunderbar... :-/
    ... bzw...:
    wie compiliert und läuft dieses Beispiel?
     * blink.c:
     *      blinks the first LED
     *      Gordon Henderson, projects@drogon.net
    #include <stdio.h>
    #include <wiringPi.h>
    int main (void)
      printf ("Raspberry Pi blink\n") ;
      if (wiringPiSetup () == -1)
        return 1 ;
      pinMode (0, OUTPUT) ;         // aka BCM_GPIO pin 17
      for (;;)
        digitalWrite (0, 1) ;       // On
        delay (500) ;               // mS
        digitalWrite (0, 0) ;       // Off
        delay (500) ;
      return 0 ;
      GCC -o blink blink.c -lwiringPi
    //and run with:
    sudo ./blink
    Saarbrücken
    Funktioniert einwandfrei. Liegt vielleicht am g++
    HaWe
    ich arbeite durchweg NUR mit g++ wegen iostream und ein oder zwei C++ libs.
    der code compiliert aber bei mir auch mit g++
    Versuch mal, ob sich dieser Code compilieren lässt:
    http://www.mindstormsforum.de/viewto...p=67907#p67815
    Saarbrücken
    Okay, habs gefunden. Offensichtlich hatte sich der Pfad nicht in dem Terminal aktualisiert. hab mich mit ssh ausgeloggt dann wieder eingeloggt jetzt gehts prima!
    Saarbrücken
    Mal eine kurze Frage, sind die GPIOs bei allen Raspis gleich?
    NRW
    bitteschön
    https://www.raspberrypi.org/documentation/usage/gpio/
    B+ , Pi2 und P3 haben ein paar mehr, wenn du nach Bildern zu GPIO im Internet suchst findest du eine Menge Hinweise, incl. einer Tabelle GPIO -> Wiring PI
    cYa
    Saarbrücken
    Japp habe ich schon gefunden. War auf der Seite von raspberrypi.org etwas verwirrt, hatte es dann aber doch gefunden.
    Danke!
    Saarbrücken
    Ich bin gerade ein wenig verwirrt.
    Ich habe es jetzt sowohl über UART (mit dem Spannungsteiler laut HaWe) wie auch über USB versucht. Dabei bin ich wie hier beschrieben vor gegangen. Das Öffnen der Schnittstelle scheint offensichtlich problemlos zu funktionieren, senden und empfangen hingegen will nicht klappen. Dabei setze ich einen Arduino Mega ein, der Serial1 benutzt, es wird also keine SoftwareSerial, oder ähnliches verwendet. Dabei initialisiere ich Serial1 mit 115200 Baud.
    HaWe
    Hast du meinen Code einmal probeweise verwendet? Der funktioniert ja nachweislich.
    Wenn er bei dir aber auch nicht funktioniert, kann es nur an deinem Raspi oder Arduino Setup oder der Verkabelung etc. liegen.
    Wenn mein Code bei dir aber doch funktioniert, kann es nur an deinem eigenen Kommunikationsprogramm liegen.
  1. I2C-Farb-Sensoren (RGB) für Raspi u/o Arduino
    Von HaWe im Forum Sensoren / Sensorik
    Antworten: 19
    Letzter Beitrag: 05.04.2016, 16:42
  2. Antworten: 63
    Letzter Beitrag: 18.02.2016, 08:43
  3. Arduino Mega mit LCD I2C
    Von Ezekiel im Forum Arduino -Plattform
    Antworten: 11
    Letzter Beitrag: 12.01.2016, 10:50
  4. Raspi mit Arduino per USB verbinden
    Von HaWe im Forum Raspberry Pi
    Antworten: 4
    Letzter Beitrag: 11.11.2015, 17:26
  5. Phoenix_PS2_SSC32 Arduino Mega
    Von Ownnemesis im Forum Arduino -Plattform
    Antworten: 6
    Letzter Beitrag: 15.10.2015, 18:54
