Ergebnis 1 bis 10 von 33
Thema: FM-Radio mit Arduino Pro Mini und Si4703 - Programm hängt sich auf!
Baum-Darstellung
    Erfahrener Benutzer Fleißiges Mitglied Avatar von basteluwe
    Hallo Leute,
    ich betreibe ein SI4703 breakout an einem Pro-Mini. Gesteuert wird mit 5 Tastern.
    2x Volume +/-
    1x Wechsel zu nächster Station (10 Stationen voreingestellt)
    2x +/- Scan zu nächster auffindbarer Station
    KEINE RDS-Auswertung.
    Die Anzeige der Daten erfolgt auf OLED 128x64.
     * This code is a modification/extract of several example-codes that come *
     * with different si4703-libraries. Libraries used are fetched from:      *
     *         http://www.mathertel.de/Arduino/RadioLibrary.aspx              *
     * Not sure if other libraries work with same code.                       *
     * 5 push-buttons control the radio (see comments in code)                *
     * OLED-display shows 3 lines:                                            *
     *  1- "frequency"                                                        *
     *  2- "station name" or "scan mode"                                      *
     *  3- "volume level" + "battery voltage" or "CHARGE BATTERY"             *
     * Code for voltage monitoring is fetched from:                           *
     * https://code.google.com/archive/p/tinkerit/wikis/SecretVoltmeter.wiki  *
     * U.Galepp Jan./2018                                                     *
    #include <Arduino.h>
    #include <Wire.h>
    #include <radio.h>
    #include <si4703.h>
    #include "U8glib.h"
    U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);  // define type of display (OLED 0.96" 128x64 pix)
    #define FIX_BAND     RADIO_BAND_FM            // the band that will be tuned by this sketch is FM
    #define FIX_STATION  8760                     // station at start-up is 87.60 MHz
    #define FIX_VOLUME   1                        // volume level at start-up
    SI4703 radio;                                 // Create an instance of Class for Si4703 Chip
    int volume = FIX_VOLUME;
    int button_1 = 3;                             // button volume up at Pin 3
    int button_2 = 4;                             // button volume down at Pin 4
    int button_3 = 5;                             // button station swap at Pin 5
    int button_4 = 6;                             // button scan up at Pin 6
    int button_5 = 7;                             // button scan down at Pin 7
    int buttonState_1 = 0;
    int buttonState_2 = 0;
    int buttonState_3 = 0;
    int buttonState_4 = 0;
    int buttonState_5 = 0;
    int flag = 0;                                 // used for decission to show "Station Name" or "scan mode"
    int stationNr = 0;
    int fmFreq[10] = {8760, 8820, 9100, 9350, 9500, 10030, 10080, 10280, 10330, 10480};
    char* fmName[10] = {"   NDR 1 MV", "   NDR Kultur", "   NDR 1 MV", "   NDR 2 MV",
                       "     N-JOY", "Deutschlandfunk", "  Antenne MV", "   NDR Info",
                        "Radio Paradiso", "  Ostseewelle"};
    char vol[2];
    float volts;
    char akku[4];
    long readVcc() {
      long result;
                                                 // Read 1.1V reference against AVcc
      ADMUX = _BV(REFS0) | _BV(MUX3)
                  | _BV(MUX2) | _BV(MUX1);
      delay(2);                                  // Wait for Vref to settle
      ADCSRA |= _BV(ADSC);                       // Convert
      while (bit_is_set(ADCSRA,ADSC));
      result = ADCL;
      result |= ADCH<<8;
      result = 1126400L / result;                // Back-calculate AVcc in mV
      return result;
     *           Setup            *
    void setup() {
      radio.init();                               // initialize radio
      radio.setBandFrequency(FIX_BAND, FIX_STATION);
      radio.setVolume(volume);
      radio.setMono(false);
      radio.setMute(false);
      pinMode(button_1, INPUT);                   // define button Pins
      pinMode(button_2, INPUT);                   // -||-
      pinMode(button_3, INPUT);                   // -||-
      pinMode(button_4, INPUT);                   // -||-
      pinMode(button_5, INPUT);                   // -||-
      digitalWrite(button_1, HIGH);               // button-Pin Pull-up
      digitalWrite(button_2, HIGH);               // -||-
      digitalWrite(button_3, HIGH);               // -||-
      digitalWrite(button_4, HIGH);               // -||-
      digitalWrite(button_5, HIGH);               // -||-
     * Subroutine Display on OLED *
    void displayData()
      volts = (float)readVcc()/(float)1000;       // read Vcc and divide by 1000
      char s[12];
      radio.formatFrequency(s, sizeof(s));        // format frequency value to output like: "87,60 MHz"
        u8g.firstPage();
        do {
        u8g.drawFrame(0,0,128,64);                // display frame around screen
        u8g.setFont(u8g_font_timB14);
        u8g.drawStr(15, 22, s);
        u8g.setFont(u8g_font_unifont);
        if(flag==0)
          u8g.drawStr(4, 44, fmName[stationNr]);  // if fequency from array, take name from array too
        if(flag==1)
          u8g.drawStr(25, 44, "scan mode");       // if frequency from scan, show "scan mode"
        if(volts > 3.3)                           // if Vcc > 3.3V display "Volume" & "Volt"
            u8g.setFont(u8g_font_6x13);
            u8g.drawStr(6, 59,"Volume: ");
            sprintf (vol, "%d", volume);          // change int "volume" to char "vol"
            u8g.drawStr(50, 59, vol);
            u8g.drawStr(68, 59,"Bat:");
            dtostrf(volts, 2, 1, akku);           // change float "volts" to char "akku"
            u8g.drawStr(94, 59,akku);
            u8g.drawStr(115, 59,"V");
           else                                   // if VCC >= 3.3V display "CHARGE BATTERY"
            u8g.drawStr(6, 59,"CHARGE BATTERY");
         while( u8g.nextPage() );
     *         Main Loop          *
    void loop()
      buttonState_1 = digitalRead(button_1);
      buttonState_2 = digitalRead(button_2);
      buttonState_3 = digitalRead(button_3);
      buttonState_4 = digitalRead(button_4);
      buttonState_5 = digitalRead(button_5);
      if (buttonState_1 == LOW)
          volume ++;
          if (volume == 16) volume = 15;
          delay(100);
      else if (buttonState_2 == LOW)
          volume --;
          if (volume < 0) volume = 0;
          delay(100);
      else if (buttonState_3 == LOW)
          stationNr ++;
          if (stationNr == 10) stationNr = 0;
          radio.setFrequency(fmFreq[stationNr]);
          flag = 0;
          delay(500);
      else if (buttonState_4 == LOW)
          radio.seekUp();
          flag = 1;
          delay(500);
      else if (buttonState_5 == LOW)
          radio.seekDown();
          flag = 1;
          delay(500);
      else displayData();
    Prinzipiell funktioniert alles prima, nur leider friert das Ding immer mal wieder ein!
    Das kann schon Sekunden nach dem Start passieren, manchmal aber auch erst nach längerer Zeit.
    Ich bin nicht sicher, ob der Sketch auf dem Arduino einfriert oder ob es der SI4703 ist. Eigentlich glaube ich eher an ein Problem mit dem Sketch, weil dann auch die Anzeigewerte nicht mehr richtig reagieren, wenn ich auf Taster drücke. Andererseits habe ich manchmal den Eindruck, das das Einfrieren durch Bewegung in der Nähe der Antenne getriggert wird. Das würde für mich eher auf ein Problem mit dem SI4703 deuten. Ich habe versuchsweise die Anzeigeroutine auskommentiert. Das hat nichts gebracht.
    Hier noch die Schaltung, falls das wichtig ist:
Hits:	19
Größe:	37,6 KB
    Irgendwelche Ideen warum das Ding einfriert?
    Gruß Uwe
    Geändert von basteluwe (13.02.2018 um 10:38 Uhr)
  1. Unit 1.2 hängt sich auf
    Von Billy51 im Forum Open Source Software Projekte
    Letzter Beitrag: 06.03.2011, 13:52
  2. Timer hängt sich auf?
    Von Ineedhelp im Forum C - Programmierung (GCC u.a.)
    Antworten: 15
    Letzter Beitrag: 22.08.2008, 17:49
  3. Programm hängt sich auf
    Von martin66119 im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 07.10.2007, 22:06
  4. LCD hängt sich auf
    Von hotijack im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 30.05.2007, 17:47
  5. Lade Programm geht nicht (hängt sich auf)
    Von REX im Forum Robby CCRP5
    Letzter Beitrag: 11.09.2004, 05:19
