Hallo zusammen
Habe den mehre DS18BS20 an den ESP8266 angeschlossen und das Programm unten laufen.
Mein Probelm ist jetzt: Es werden nicht alle DS18B20 erkannt.
Frage: kann ich den Wiederstand jetzt 4.7 KOhme veränderen. In welchen bereich?
Und erreiche ich damit was?
Code:#include <OneWire.h> #include <DallasTemperature.h> // Data wire is plugged TO GPIO 4 #define ONE_WIRE_BUS 4 // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs) OneWire oneWire(ONE_WIRE_BUS); // Pass our oneWire reference to Dallas Temperature. DallasTemperature sensors(&oneWire); // Number of temperature devices found int numberOfDevices; // We'll use this variable to store a found device address DeviceAddress tempDeviceAddress; void setup() { // start serial port Serial.begin(115200); Serial.println(); // Start up the library sensors.begin(); // Grab a count of devices on the wire numberOfDevices = sensors.getDeviceCount(), DEC; // locate devices on the bus Serial.print("Locating devices..."); Serial.print("Found "); Serial.print(numberOfDevices, DEC); Serial.println(" devices."); // Loop through each device, print out address for (int i = 0; i < numberOfDevices; i++) { // Search the wire for address if (sensors.getAddress(tempDeviceAddress, i)) { Serial.print("Found device "); Serial.print(i, DEC); Serial.print(" with address: "); printAddress(tempDeviceAddress); Serial.println(); } else { Serial.print("Found ghost device at "); Serial.print(i, DEC); Serial.print(" but could not detect address. Check power and cabling"); } } } void loop() { sensors.requestTemperatures(); // Send the command to get temperatures // Loop through each device, print out temperature data for (int i = 0; i < numberOfDevices; i++) { // Search the wire for address if (sensors.getAddress(tempDeviceAddress, i)) { // Output the device ID Serial.print("Temperature for device: "); Serial.println(i, DEC); // Print the data float tempC = sensors.getTempC(tempDeviceAddress); Serial.print("Temp C: "); Serial.print(tempC); Serial.print(" Temp F: "); Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit } } delay(5000); } // function to print a device address void printAddress(DeviceAddress deviceAddress) { for (uint8_t i = 0; i < 8; i++) { if (deviceAddress[i] < 16) Serial.print("0"); Serial.print(deviceAddress[i], HEX); } }
Lesezeichen
