Seite 4 von 5 ErsteErste ... 2345 LetzteLetzte
Ergebnis 31 bis 40 von 47
Thema: Asuro eigene Erweiterung
  1. #31
    Asuro with atmega32
    Hello,
    First of all sorry for my message in English but my german writing is mega terrible, and my English a little better . I was reading the post about a Asuro with another micro than the orginal. That inspired me to build something, i have made a expirimental board with a atmega 32, isp, rs232, and it is all working very nice. Look at the pics. Original i had very much problems programming the asuro by infrared, so my first goal was to replace the infrared for a ISP option, that worked very nice, but then i wanted more so i replaced the at8 for the at32, i had to rewrite the asuro.h and .c but now all is working very well.
  2. #32
    Issum
    Hello psDg,
    Es freut mich, daß Dich unser Thread dazu bewegt hat den Asuro zu erweitern.
    Sorry, aber ich hatte in der Schule nur Russisch und Englisch kann ich leider nur lesen
    Ich finde Deine Platine super, genau so hab ich mir das auch vorgestellt, nur halt den MEGA 32
    über dem Sockel von Asuro, um die Drahtbrücken zu vermeiden.
    Welchen Quarz hast Du eingesetzt ? auch 8 Mhz oder 16 ?
    Endlich mal ein Bild von dem ersten umgebauten ASURO , was hast Du mit den freien Ports vor?
    Bleibe dran, und Poste weitere Bilder wenn Du noch was erweitert hast.
    Gruß Sebastian
  3. #33
    Asuro
    Hello,
    I can read german perfectly so that´s no problem, perhaps you know a site where i can translate english or dutch to german. About the board it is still expirimental, i am currently working with a 16MHz crystal but i made a socket so that i can change the crystal easely, i also made a socket for the connection between asuro and the at32, in that way i can make asuro original in a flash when i wanted to. I want to try to make a I2C connection, and i wanted to connect a lcd display for debug info etc. Then perhaps make a nice proto pcb because now its all wired up. So you see so much work to do .
    gr
    Pim
  4. #34
    12°29´ O, 48°38´ N
    Hi psdg,
    mit soviel CPU-Power wie lange hält da wohl die Batterie/Akku, das sind noch die originalen AAA-size ?
  5. #35
    asuro
    I am still testing, the batteries are still holding after a week of intense use, but it is something to think about. The whole thing is just a start.
    gr
    Pim
  6. #36
    Großartig, so habe ich mir das vorgestellt. Tolle Leistung!
    Ich hoffe, ich werde meine Platine bis Montag fertig haben.
    Stefan
  7. #37
    Update
    Asuro mit, I2C, RS232, ISP und 3 Sharp gp2d12 sensoren. =D>
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken asuro_new2_204.jpg   asuro_new1_461.jpg
  8. #38
    Nürnberg
    Ja heeeeftig... da ist wirklich ein Asuro drunter? *staun*
  9. #39
    Diese Erweiterung ist nicht so spektakulär, wie oben, aber vielleicht einen oder den anderen wird diese auch interessieren.
    Nach einer Anregung von Sebastian habe ich einen Summer angelötet (PIND6)
    Jetzt ist das ein Polizei-Asuro
    Best wishes.
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken asuro_mit_einem_summer.jpg
  10. #40
    Braunschweig
    Tut sich hier noch etwas, bzw. hat sich hier noch etwas getan?
    Entschuldigung, dass ich diesen Thread ausgrabe, aber dieses Thema interessiert mich sehr stark =)
    Mit freundlichen Grüßen,
    Shadow²
