Thema: ATMEGA16 IIC Fehler beim Compilen
    und zwar will ich etwas mit dem IIC Bus des ATmega16 machen.
    z.B. serielles EEprom oder eine RTC ansteuern.
    Dazu habe ich mit eine routine aus dem Datenblatt geholt:
     .include "m16def.inc"
    .ORG 0x00
    	JMP	RESET 			; Reset Handler
    .ORG 0x02
    	JMP	UNUSED			; IRQ0 Handler
    .ORG 0x04
    	JMP	UNUSED			; IRQ1 Handler
    .ORG 0x06
    	JMP	UNUSED		; Timer2 Compare Handler
    .ORG 0x08
    	JMP	UNUSED		; Timer2 Overflow Handler
    .ORG 0x0A
    	JMP	UNUSED		; Timer1 Capture Handler
    .ORG 0x0C
    	JMP	UNUSED		; Timer1 CompareA Handler
    .ORG 0x0E
    	JMP	UNUSED		; Timer1 CompareB Handler
    .ORG 0x10
    	JMP	UNUSED   		; Timer1 Overflow Handler
    .ORG 0x12
    	JMP	UNUSED		; Timer0 Overflow Handler
    .ORG 0x14
    	JMP	UNUSED	; Serial Transfer Complete Handler
    .ORG 0x16
    	JMP	UNUSED	; USART0 RX Complete Handler
    .ORG 0x18
    	JMP	UNUSED	; USART0,UDR Empty Handler
    .ORG 0x1A
    	JMP	UNUSED	; USART0 TX Complete Handler
    .ORG 0x1C
    	JMP	UNUSED	; ADC Conversion Complete Handler
    .ORG 0x1E
    	JMP	UNUSED	; EEPROM Ready Handler
    .ORG 0x20
    	JMP	UNUSED	; Analog Comparator Handler
    .ORG 0x22
    	JMP	UNUSED			; TWI Handler
    .ORG 0x24
    	JMP	UNUSED			; IRQ2 Handler
    .ORG 0x26
    	JMP	UNUSED		; Timer0 Compare Handler
    .ORG 0x28
    	JMP	UNUSED		; SPM Ready Handler
    UNUSED:
      ret
    RESET:
    ldi r16,high (Ramend)
    out sph,r16
    ldi r16,low (Ramend)
    out spl,r16
    sei
    .def SLA_W = r20
    .def MT_SLA_ACK = r17
    .def MT_DATA_ACK = r18
    .def DATA = r19
    .def START = r21
    Main:
    ldi r16, (1<<TWINT)|(1<<TWSTA)|(1<<TWEN)  ; Send START condition
    out TWCR, r16
    wait1:                                  ; Wait for TWINT Flag set.
    in r16,TWCR                               ; This indicates that the
    sbrs r16,TWINT                            ; START condition has been
    rjmp wait1                                ; transmitted
    in r16,TWSR                               ; Check value of TWI Status Register.
    andi r16, 0xF8                            ; Mask prescaler bits.
    cpi r16, START                            ; If status different from
    brne ERROR                                ; START go to ERROR
    ldi r16, SLA_W                            ; Load SLA_W into TWDR
    out TWDR, r16                             ; Register. Clear TWINT bit in
    ldi r16, (1<<TWINT) | (1<<TWEN)           ; TWCR to start
    out TWCR, r16                             ; transmission of address
    wait2:		                  ; Wait for TWINT Flag set.
    sbrs r16,TWINT                            ; SLA+W has been transmitted,
    rjmp wait2                                ; and ACK/NACK has been received.
    andi r16, 0xF8	                 ; Register. Mask prescaler bits.
    cpi r16, MT_SLA_ACK                       ; If status different from
    brne ERROR                                ; MT_SLA_ACK go to ERROR
    ldi r16, DATA                             ; Load DATA into TWDR Register.
    out TWDR, r16                             ; Clear TWINT bit in TWCR
    ldi r16, (1<<TWINT) | (1<<TWEN)           ; to start transmission
    out TWCR, r16                             ; of data
    wait3:                                    ; Wait for TWINT Flag set.
    in r16,TWCR                               ; This indicates that the DATA
    sbrs r16,TWINT                            ; has been transmitted, and
    rjmp wait3                                ; ACK/NACK has been received.
    cpi r16, MT_DATA_ACK                      ; If status different from
    brne ERROR                                ; MT_DATA_ACK go to ERROR
    ldi r16, (1<<TWINT)|(1<<TWEN)|(1<<TWSTO)  ; Transmit STOPcondition
    out TWCR, r16
    rjmp Main
    ERROR:
    rjmp Error
    Gut mir ist klar,daß noch so sachen wie eine fehlerroutine,usw fehlen.
    Trotzdem sollte ich den Code schon compilen können.
    Nur leider bringt mein AVR Studio Fehlermeldungen.
    Siehe anhang.
    Hat jemand eine Idee woher der Fehler kommen könnte?
    Hier habe ich auch noch ein Problem für das ich bis jetzt auch keine Lösung gefunden habe:
    https://www.roboternetz.de/phpBB2/viewtopic.php?t=9972 !
    Hat vielleicht schon jemand in ASM einen fertigen Quellcode für eine IIC routine, oder weiss vielleicht eine Seite wo man die her bekommt?
    Gruß und danke schonmal
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken avrstundion.jpg
    Ok hab den Fehler schon gefunden.
    muß man so machen:
    .equ Start = ?
    .equ SLA_W = ? ( Wahrscheinlich das Adressbyte )
    .equ MT_SLA_ACK = ?
    .equ DATA = ? ( Datenbyte )
    .equ MT_DATA_ACK = ?
    jetzt muß ich nur noch herausfinden was die Konstanten für einen
    Wert haben.
    aber vielleicht hat hier ja jemand eine idee.
    So, noch eine Frage:
    Wie errechnet sich laut der Formel die Fscl?
    Fscl = CPU Clock frequency/ 16 +2 (TWBR) * 4 hoch TWPS
    4 hoch TWPS * TWBR * 2 = x
    dann CPU Clock frequency / x
    liege ich da richtig?
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken sclfreuquency.jpg
    So,
    in der oben genannten I2C routine vom Datenblatt fehlt doch was oder?
    ich habe vor das AT24C02 EEPROM von Atmel zu verwenden.
    http://www.atmel.com/dyn/resources/p...ts/doc0180.pdf
    um daten ins EEPROM zu schreiben muß ich doch ihm mitteilen das er gemeint ist.
    (The device address word consists of a mandatory one, zero sequence for the first four most significant bits as shown. This is common to all the EEPROM devices. The next 3 bits are the A2, A1 and A0 device address bits for the 1K/2K EEPROM.These 3 bits must compare to their corresponding hard-wired input pins.)
    das mach ich mit den A2,A1,A0 bits.
    nehmen wir an ich leg alle auf masse, dann schaut das adress Byte doch so aus: 0b1010000&1->für write.
    dann brauch ich ja aber noch eine adresse für das datenbyte!
    und das fehlt doch in der Routine oder?
    wie und wo füge ich das in meine routine ein?
    gruß
