Rechter Antrieb ohne Funktion
nachdem ich den RP6 ausgepackt habe, habe ich das Programm:
RP6Base_LightFollowing.hex
in den RP6 geladen, welches mit einem kurzen bewegen und anschliessendem aufleuchten von 4 roten LED´s quittierte.
Danach habe ich das Testprogramm:
RP6Base_SELFTEST.hex
durchlaufen lassen.
bei dem Test Nr.8 beendete das Programm den Ablauf mit einer Fehlermeldung des Rechten Antriebes.
RP6 Robot Base Selftest
### ATTENTION!!! DANGER!!! WARNING!!!
Make sure that the RP6 CAN __NOT__ MOVE!
The caterpillar tracks should NOT touch the ground!
(hold it in your hands for example...)
THE RP6 WILL START MOVING IN TEST 8! YOU CAN DAMAGE IT IF YOU DO NOT
MAKE SURE THAT IT CAN __NOT__ MOVE!
Make sure both crawler tracks are FREE RUNNING! DO NOT BLOCK THEM!
Please enter "x" and hit Enter to continue!
Hint: This program requires a newline character ("\n") at the end of
all input lines!
# x
######### RP6 Robot Base Selftest #########
######### HOME VERSION v. 1.3 - 25.09.2007 #########
##### Main Menu ######### Advanced Menu #####
# 0 - Run ALL Selftests (0-8) # s - Move at speed Test #
# 1 - PowerOn Test # d - Move distance Test #
# 2 - LED Test # c - Encoder Duty-Cycle Test #
# 3 - Voltage Sensor Test # #
# 4 - Bumper Test # #
# 5 - Light Sensor Test # #
# 6 - ACS (and RC5 receive) Test # #
# 7 - IRCOMM/RC5 Test # System voltage is: #
# 8 - Motors and Encoders Test # 08.22V #
# Please enter your choice (1-8, s, d, c)! #
# 8
#### TEST #8 ####
Automatic speed speed regulation test
Make sure that the RP6 can __NOT__ move!
The caterpillar tracks should __NOT__ touch the ground!
THE RP6 WILL START MOVING FAST! YOU CAN DAMAGE IT IF YOU DO NOT
--> OTHERWISE THE TEST WILL FAIL!
### Enter "x" and hit return when TO START this test!
### Make sure the RP6 can not move!
# x
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 002 |IR: 001 |UB: 08.21V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 003 |IR: 001 |UB: 08.21V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 001 |IR: 001 |UB: 08.21V
Speed Left: OK
Speed Right: OK
T: 020 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 002 |IR: 001 |UB: 08.21V
T: 020 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 003 |IR: 001 |UB: 08.21V
T: 020 |VL: 000 |VR: 000 |PL: 020 |PR: 020 |IL: 008 |IR: 001 |UB: 08.20V
T: 020 |VL: 000 |VR: 000 |PL: 040 |PR: 040 |IL: 023 |IR: 001 |UB: 08.18V
T: 020 |VL: 032 |VR: 000 |PL: 034 |PR: 060 |IL: 028 |IR: 001 |UB: 08.19V
T: 020 |VL: 019 |VR: 000 |PL: 032 |PR: 080 |IL: 025 |IR: 001 |UB: 08.19V
T: 020 |VL: 021 |VR: 000 |PL: 030 |PR: 100 |IL: 026 |IR: 001 |UB: 08.19V
T: 020 |VL: 019 |VR: 000 |PL: 033 |PR: 120 |IL: 031 |IR: 001 |UB: 08.18V
T: 020 |VL: 019 |VR: 000 |PL: 035 |PR: 140 |IL: 036 |IR: 001 |UB: 08.17V
Speed Left: OK
####### ERROR Right #######
####### !!! WARNING WARNING WARNING !!! #######
####### !!! TEST FINISHED WITH ERRORS !!! #######
#### Please check motor and encoder assembly! ###
#### And also check Sensors for defects! ###
Enter any character to continue!
Nach dieser Meldung leuchteten die 4 roten LED´s wieder auf.
Ich hoffe das mir jemand weiterhelfen kann, da ich in der Beschreibung unter Fehlersuche und hier im Forum nichts hifreiches gefunden habe.
Gruss
Sven
