Motorstrom zu hoch = Motordefekt ?
Hallo liebe RoboternetzerInnen :-P,
ich habe seit ein paar Monaten einen RP6 seit neustem kommt (beim Selftest) folgende Meldung:
#### TEST #8 ####
Automatic speed speed regulation test
### ATTENTION!!! DANGER!!! WARNING!!!
Make sure that the RP6 can __NOT__ move!
The caterpillar tracks should __NOT__ touch the ground!
(hold it in your hands for example...)
THE RP6 WILL START MOVING FAST! YOU CAN DAMAGE IT IF YOU DO NOT
MAKE SURE THAT IT CAN __NOT__ MOVE!
Make sure both crawler tracks are FREE RUNNING! DO NOT BLOCK THEM!
--> OTHERWISE THE TEST WILL FAIL!
### Enter "x" and hit return when TO START this test!
### Make sure the RP6 can not move!
# x
T: 000 |VL: 001 |VR: 000 |PL: 000 |PR: 000 |IL: 002 |IR: 000 |UB: 09.71V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 003 |IR: 000 |UB: 09.71V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 004 |IR: 000 |UB: 09.71V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 002 |IR: 000 |UB: 09.71V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 002 |IR: 000 |UB: 09.70V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 003 |IR: 000 |UB: 09.70V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 004 |IR: 000 |UB: 09.70V
T: 000 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 001 |IR: 000 |UB: 09.70V
Speed Left: OK
Speed Right: OK
T: 020 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 002 |IR: 000 |UB: 09.70V
T: 020 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 003 |IR: 000 |UB: 09.70V
T: 020 |VL: 000 |VR: 000 |PL: 000 |PR: 000 |IL: 004 |IR: 000 |UB: 09.71V
T: 020 |VL: 000 |VR: 000 |PL: 010 |PR: 010 |IL: 015 |IR: 005 |UB: 09.59V
T: 020 |VL: 000 |VR: 000 |PL: 020 |PR: 020 |IL: 049 |IR: 021 |UB: 09.53V
T: 020 |VL: 000 |VR: 000 |PL: 030 |PR: 030 |IL: 079 |IR: 028 |UB: 09.46V
T: 020 |VL: 000 |VR: 000 |PL: 040 |PR: 040 |IL: 111 |IR: 034 |UB: 09.39V
T: 020 |VL: 000 |VR: 000 |PL: 050 |PR: 050 |IL: 147 |IR: 040 |UB: 09.30V
####### Left: CURRENT CONSUMPTION IS TOO HIGH! ########
####### !!! WARNING WARNING WARNING !!! #######
####### !!! TEST FINISHED WITH ERRORS !!! #######
#### Please check motor and encoder assembly! ###
#### And also check Sensors for defects! ###
Auch ist der linke Motor sehr schwergängig. In meiner Panik habe ich auch den Spulenwiderstand des Motors gemessen, der linke hat 2 Ohm der rechte 6 Ohm. Ist das ein Defekt am Motor ? Wie heißt der Motor ? Bekomme ich den trotz rumlöten am RP6 auf Garantie ?
mfg Daniel
