Bascom Error 86 und 126
Hie Leute,
Ich habe gerade mal ein Programm für eine Beleuchtungssteuerung geschrieben :
$regfile = "attiny2313.dat"
$crystal = 4000000
Config Portb = Output
Config Portd.0 = Input
Config Portd.1 = Input
Config Portd.2 = Input
Config Portd.5 = Output
Config Timer0 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 1
Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 1
Enable Timer0
Enable Timer1
Start Timer0
Start Timer1
Dim Hochdimmen As Byte
Dim Hochdimmen2 As Byte
Dim Hochdimmen3 As Byte
Dim Hochdimmen4 As Byte
Dim Hochdimmen5 As Byte
Dim Runterdimmen As Byte
Dim Runterdimmen2 As Byte
Dim Runterdimmen3 As Byte
Dim Runterdimmen4 As Byte
Dim Runterdimmen5 As Byte
Helligkeit Alias Pwm0a
Helligkeit2 Alias Pwm0b
Helligkeit3 Alias Pwm1a
Helligkeit4 Alias Pwm1b
If Portd.0 = 1 Then
For Hochdimmen = 1 To 255
Helligkeit = Hochdimmen
Next Hochdimmen
Wait 10
For Runterdimmen = 1 To 255
Helligkeit = 255 - Runterdimmen
Next Runterdimmen
End If
If Portd.1 = 1 Then
Portb.0 = 1
Waitms 100
Portb.0 = 0
Waitms 100
Portb.0 = 1
Waitms 100
Portb.0 = 0
Waitms 100
Portb.0 = 1
Waitms 100
Portb.0 = 0
Waitms 100
Portb.0 = 1
Waitms 100
Portb.0 = 0
Waitms 100
Portb.0 = 1
Waitms 100
Portb.0 = 0
Waitms 100
Portb.0 = 1
Waitms 100
Portb.0 = 0
Waitms 100
Portb.0 = 1
Waitms 100
Portb.0 = 0
Waitms 100
Portb.0 = 1
Waitms 100
Portb.0 = 0
Waitms 100
Portb.0 = 1
Waitms 100
Portb.0 = 0
Waitms 100
Portb.0 = 1
Waitms 100
Portb.0 = 0
End If
If Portd.2 = 1 Then
For Hochdimmen2 = 1 To 255
Helligkeit2 = Hochdimmen2
Next Hochdimmen2
Waitms 40
For Runterdimmen2 = 1 To 100
Helligkeit2 = 255 - Runterdimmen2
Next Runterdimmen2
Waitms 100
For Hochdimmen3 = 1 To 255
Helligkeit3 = Hochdimmen3
Next Hochdimmen3
Waitms 40
For Runterdimmen3 = 1 To 100
Helligkeit3 = 255 - Runterdimmen3
Next Runterdimmen3
Waitms 100
For Hochdimmen4 = 1 To 100
Helligkeit4 = Hochdimmen4
Next Hochdimmen4
For Hochdimmen5 = 100 To 255
Helligkeit2 = Hochdimmen5
Helligkeit3 = Hochdimmen5
Helligkeit4 = Hochdimmen5
Next Hochdimmen
Wait 10
For Runterdimmen5 = 1 To 255
Helligkeit2 = 255 - Runterdimmen5
Helligkeit3 = 255 - Runterdimmen5
End If
End
Wenn ich jetzt auf "Compile program" klicke, steht unten in diesem Kasten :
Error : 86 Line : 10 Invalid parameter for CONFIG parameter or value [8] , in File : C:\PROGRAMME\MCS ELECTRONICS\BASCOM-AVR\SCHULPROJEKT.BAS
Error : 126 Line : 0 NEXT expected , in File :
Nun hab ich überhauptkeine Ahnung, was ich falsch gemacht habe... :-s :-s
Und vorallem in Line : 10 steht das gleiche wie in Line : 11 nur halt in 10 ist Timer0 und in 11 ist Timer1..
Und Line : 0 irritiert mich auch ein wenig.. Es gibt doch überhauptkeine Line : 0 ??!!
Hoffentlich könnt ihr mir helfen und mir sagen, was ich falsch gemacht habe.... :Haue
Mfg Yannik
also warum der mit dem Timer probleme hat weiß ich nicht, hab noch nie was mit nem Timer gemacht. Der andere Fehler liegt daran das du bei der letzten For-Schleife das "Next" vergessen hast.
Next expected = Next erwartet. Also irgendwo fehlt ihm eines. Und wenn ich das gerade so schnell gesehen habe ist es die letzte Schleife.
MfG Tretsch
Oh Okay!! Das mit dem Next war schonmal richtig..
Ich habe mal die Zeile mit dem Timer0 gelöscht.. Dann gabs keine Error Meldungen mehr.. Dann wieder reingemacht.. Und wieder den gleichen Error 86..
Hoffentlich weiß da einer Rat...
Mfg Yannik
Lass mal das PWM=8 weg, der Timer0 kann wohl eh nichts anderes.
Rolf
