NFC Shield + Arduino Uno Problem beim Schreiben
ich habe mir bei Seeedstudio.com ein NFC Shield gekauft, welches in an meinem Arduino Uno betreibe.
Nun, nachdem das mit dem Lesen eines NFC-Tags soweit klappt, möchte ich auch einmal einen beschreiben, dafür habe ich das Beispielprogramm her genommen und dieses ein bisschen modifiziert:
// This example writes a MIFARE memory block 0x08. It is tested with a new MIFARE 1K cards. Uses default keys.
// Note: Memory block 0 is readonly and contains manufacturer data. Do not write to Sector Trailer block
// unless you know what you are doing. Otherwise, the MIFARE card may be unusable in the future.
//Contributed by Seeed Technology Inc (www.seeedstudio.com)
#include <PN532.h>
#define SCK 13
#define MOSI 11
#define SS 10
#define MISO 12
PN532 nfc(SCK, MISO, MOSI, SS);
uint8_t written=0;
void setup(void) {
Serial.begin(9600);
Serial.println("Hello Jonas");
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print("Didn't find PN53x board");
while (1); // halt
// Got ok data, print it out!
Serial.print("OK!");
// configure board to read RFID tags and cards
nfc.SAMConfig();
void loop(void) {
uint32_t id;
// look for MiFare type cards
id = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A);
if (id != 0)
Serial.print("Card-Number:"); Serial.println(id);
Serial.println();
uint8_t keys[]= {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
uint8_t writeBuffer[16];
for(uint8_t ii=0;ii<16;ii++)
writeBuffer[ii]=42; //Fill buffer with 0,1,2....F
if(nfc.authenticateBlock(1, id ,0x07,KEY_B,keys)) //authenticate block 0x08
//if authentication successful
if(written == 0) //Not written
written = nfc.writeMemoryBlock(1,0x07,writeBuffer); // Write writeBuffer[] to block 0x08
if(written)
Serial.println("Write Successful");
uint8_t block[16];
//read memory block 0x08
if(nfc.readMemoryBlock(1,0x07,block))
Serial.println("Read block 0x07:");
//if read operation is successful
for(uint8_t i=0;i<16;i++)
//print memory block
Serial.print(block[i],HEX);
Serial.print(" ");
Serial.println();
delay(500);
Man sieht aber, ich habe eig. nur ein paar Werte verändert, sonst ist alles gleich geblieben.
Leider bekomme ich nur das :( (bei dem orginalen Beispiel, hats auch ned geklappt!
Hello Jonas
OK!Found 1 tags
Sens Response: 0x4
Sel Response: 0x8
0x62 0xF7 0x64 0x1BCard-Number:1660380187
Wo liegt mein Fehler?
Vielen Dank schon einmal!
Grüße,
Jonas
